Archive 2019 · B&W Conversion
Shasoc
p.1 #1 · p.1 #1 · B&W Conversion
After struggling with the color version of this image I tried a B&W conversion, and finally this conversion gave me the mood I was looking for.
It made me realize that while a Black-and-white photograph may look simpler, the mood of the photo is more intense making it more emotional.
I believe the absence of color allows concentrating on the subject without any distracting elements which I tried to eliminate in the color version. Without color, the eye and mind immediately see the components, subject, mood.
What do you think?
Socrate
May 16, 2019 at 08:04 PM
visualpauses
p.1 #2 · p.1 #2 · B&W Conversion
Socrate, beautiful photo! The mood is perfectly conveyed.
Agree 100% with the thought-process of B/W, its something that I use myself when I feel that color is creating clutter. Minus the color, the lines and shapes take prominence.
May 17, 2019 at 01:08 PM
Shasoc
p.1 #3 · p.1 #3 · B&W Conversion
Thank you, Mahesh
Scrate
May 19, 2019 at 09:19 AM
beavens
p.1 #4 · p.1 #4 · B&W Conversion
Converting to mono can do a great job of 'calming' an otherwise busy scene!
I like what you've got here, Socrate. I think the toning is *nearly* there - I think it should use a little more massaging to catch that right 'dusty' feeling. Did you add additional blurring here? If so, I think that you could probably get slightly less aggressive and still maintain the isolation you're looking for.
Jeff
May 20, 2019 at 09:50 AM
sbeme
p.1 #5 · p.1 #5 · B&W Conversion
Excellent image, processing, with appropriate style and toning to match.
One nit, at least to me: I think the fade/negative vignette, whatever you did is a bit too strong over the foreground hoof, left image. I suppose it conveys walking the dusty trail, but the transition is stronger there and lower leg than elsewhere.
Scott
May 20, 2019 at 04:07 PM
Shasoc
p.1 #6 · p.1 #6 · B&W Conversion
Jeff
Scott
Thank you Jeff and thank you, Scott. I appreciate the comments and the critique. That is what I wanted to hear. I will play a bit more with the image trying to follow your directions.
Socrate
May 21, 2019 at 10:12 PM
