highdesertmesa Offline Upload & Sell: On
nehemiahphoto wrote:
I was interested in the original till I shot it and started processing the files. That sensor was noticeably behind current Sony/Nikon/Fuji sensors. Files were fragile, highlights blew easily.
If the Q has a better sensor, not just more res, I'll be very interested.
I don't find the files fragile as long as I don't pull the shadows more than a few stops or grossly over or under-expose the shot. Highlight recovery is not as good as my GFX, but I've never noticed it being an issue as long as I expose the shot well. And even the GFX with it's 14-stops of DR, if you pull the shadows enough the files still look "burnt"/over-processed to me. The only way to really do justice to a very wide dynamic range scene is with ND grads or multiple-exposure blends. Hopefully one day, but not today.
But like you, I am still quite interested an improved sensor, especially with the higher megapixel count. I often find myself preferring f/1.7 at MFD and cropping to 50mm over using the Macro mode, which is limited to f2.8.
