       2       3              30       31       end
Sony 24mm f/1.4 GM lens Image Thread
Admin
p.1 #1 · p.1 #1 · Sony 24mm f/1.4 GM lens Image Thread
Official Sony FE 24mm f/1.4 GM Image Thread
Full FM Review: https://www.fredmiranda.com/forum/topic/1568815
Pre-order links:
B&H Photo | Amazon | Adorama
Help support FM by using our links for your purchase! - Thank you!
___________________
Jul 04, 2019 at 02:12 PM
Dj R
p.1 #2 · p.1 #2 · Sony 24mm f/1.4 GM lens Image Thread
Pre-sale discussion and affiliate links: https://www.fredmiranda.com/forum/topic/1562697
a full review by @albertdros@ https://www.fredmiranda.com/forum/topic/1567353
keep exif!
tell us what you used for processing
etc!
don't be shy!
View previous versions
Oct 26, 2018 at 12:42 PM
Dj R
p.1 #3 · p.1 #3 · Sony 24mm f/1.4 GM lens Image Thread
no humans available today
just got it
no profile in LRCC yet
the mount is a good kind of tight, on the very tight side.
-size comparison
85GM 24GM 35ZA
-some Pez in the man cave
-my neighbor's stoop
Edited on Oct 26, 2018 at 04:10 PM · View previous versions
Oct 26, 2018 at 12:46 PM
GMPhotography
p.1 #4 · p.1 #4 · Sony 24mm f/1.4 GM lens Image Thread
No stinking cats okay.
Just joking, bring them on
Oct 26, 2018 at 01:28 PM
Jannik Peters
p.1 #5 · p.1 #5 · Sony 24mm f/1.4 GM lens Image Thread
We have the worst weather of the whole year currently.. Nothing to show and nothing to take pictures of.
Two more samples from my first outing with the lens.
Sony 24 GM by Jannik Reeve, auf Flickr
Oct 26, 2018 at 02:17 PM
ScottUPPSALA
p.1 #6 · p.1 #6 · Sony 24mm f/1.4 GM lens Image Thread
Took this moon image the other night. A7ii, 1/15 f2
https://flic.kr/p/2aZCKja
Oct 26, 2018 at 02:24 PM
stflbn
p.1 #7 · p.1 #7 · Sony 24mm f/1.4 GM lens Image Thread
I'm really falling in Like with the images I'm seeing from this lens.
Oct 26, 2018 at 03:41 PM
Dj R
p.1 #8 · p.1 #8 · Sony 24mm f/1.4 GM lens Image Thread
I had a quick shoot this afternoon and used only the 85 GM and this 24 GM
got a couple from the 24, mostly used the 85 as I'm a tele guy.
it's really small and light compared with my other stuff, I like the build a lot
the hood is really tight putting back on backwards, like oddly tight.
mount is super tight but not TOO tight.
didn't open the 85 files yet so I don't know if this lens matches it's color or not, maybe later, time to eat dinner
simple LRcc
available light
gloomy afternoon
Cheers
Have a great weekend everyone!
Edited on Oct 26, 2018 at 04:13 PM · View previous versions
Oct 26, 2018 at 04:07 PM
Dj R
p.1 #9 · p.1 #9 · Sony 24mm f/1.4 GM lens Image Thread
two
Oct 26, 2018 at 04:08 PM
jtra
p.1 #10 · p.1 #10 · Sony 24mm f/1.4 GM lens Image Thread
Hi,
I have visited a Sony day event in Prague today.
I played with borrowed Sony 24GM for about 25 minutes and compared it to my Sigma 24/1.4 F-mount on manual Novoflex adapter. For a few shots I have also compared with my Sony 28/2 FE.
Technical details: shot on A7III, all outdoor shots were ISO 100, AF-C on center (except for scene 3 where I focused a bit lower) for AF lenses. For Sigma, I focused manually with Focus magnifier at highest magnification. With Sigma on Novoflex adapter, I could stop down, but only guess aperture change based on how auto exposure changed because there are no marks on aperture ring so all aperture information for Sigma shots that are stopped down is only approximate (more likely to be stopped down more than indicated because vignetting impacts exposure).
I have placed DNG lossless compressed raws converted from 14 bit uncompressed ARW here:
http://jtra.cz/foto/20181027-sony24gm-vs-sigma24art-vs-sony28fe/dngs/
I will keep DNGs there for a few weeks.
Lens shading compensation that affects raws was off.
There are also converted JPGs http://jtra.cz/foto/20181027-sony24gm-vs-sigma24art-vs-sony28fe/jpgs/
I used LR 5.7. I set shadows +100, highlight -40, unified WB, adjusted exposure (images were a bit underexposed on purpose) to be about same in center.
For Sigma I have enabled "Remove chromatic aberration" setting (which reduced LaCA, but not LoCA). Sigma has LaCA of about two pixels on sides so it was helpful.
Sony 24GM has very weak LaCA. I have noticed that on Scene 5 the Remove chromatic aberration function was working badly, it was reducing LoCA in middle and increasing it on sides so I turned it off for that scene. I kept it for other scenes because it was improving image by a tiny bit (e.g. in Scene 1).
Sony 28/2 did not seem to benefit from CA reduction, but kept it enabled.
I did not use defringe tool to reduce other CA or PF. I did not use distortion correction (this older LR 5.7 does not force it).
Sony 24GM has more purple fringing than Sigma, pictures show it a bit, but in this heavy overcast day contrast was never big enough for PF to be strong. No pictures has shown as strong PF as in this f/2.8 image (near corners) from Chinese review https://www.mobile01.com/newsdetail/27303/sony-sel24f14gm-review Strongest PF can be seen on a lamp in top left corner of the last scene.
Last scene also includes bokeh comparison where I focused at 1m, but I have failed to set same aperture, Sigma is wide open while Sony 24 is at f/2. This makes it hard to draw a conclusion.
My long term experience with Sigma tells that it has busy background bokeh at far (more than 1m) focus distance (but then it is small anyway) and smooth background bokeh near close focus.
Generally, Sony 24 GM has smoother background bokeh than Sigma 24/1.4, but difference is not big. I felt that overcorrected spherical aberration that gives Sigma more busy bokeh also makes bokeh in background a bit bigger, but I could not control focus distance precisely to be sure.
I was surprised by Sony 24 GM in the last scene on focused picture that near right bottom corner the highlights in background have a star shape. Sigma has weird shape there too, but bit more convex.
Sony 24 GM is sharp in corners even wide open while Sigma needs f/4 to get sharp in corners. Sharpness in center is good on both.
While doing a lot of lens switching, I was bit annoyed by aperture ring on 24 GM which I was turning accidentally while mounting or unmounting. I don't have other lenses with the ring but I'm might get used to it holding it in different way.
You may notice some angle of view differences: 24 GM is a bit wider than Sigma.
Sigma has some barrel distortion, Sony 24 GM has weak pincushion distortion, Sony 28/2 has strong barrel distortion (when you correct it the worst corners are cut off).
Sigma is a bit more yellowish then two Sony lenses.
Oct 27, 2018 at 02:57 PM
ScottUPPSALA
p.1 #11 · p.1 #11 · Sony 24mm f/1.4 GM lens Image Thread
Loving the bokeh 😉
https://flic.kr/p/2ct1s7B
A7ii
ISO 100
1/6400
Oct 29, 2018 at 01:19 PM
maestrofilms
p.1 #12 · p.1 #12 · Sony 24mm f/1.4 GM lens Image Thread
ScottUPPSALA wrote:
Loving the bokeh 😉
A7ii
ISO 100
1/6400
Looks good but....
By any chance did you shoot this with EFCS on? If you did, that's why you have bokeh balls that are only half circles. If not, then that's just how the background (light between the branches) rendered.
Oct 29, 2018 at 01:34 PM
Dj R
p.1 #13 · p.1 #13 · Sony 24mm f/1.4 GM lens Image Thread
Gladwyne, PA
Edited on Oct 29, 2018 at 01:56 PM · View previous versions
Oct 29, 2018 at 01:44 PM
ScottUPPSALA
p.1 #14 · p.1 #14 · Sony 24mm f/1.4 GM lens Image Thread
maestrofilms wrote:
Looks good but....
Thanks for the question! I have the EFCS on. Maybe I'll try switching it off and do some testing? Thx Scott
Oct 29, 2018 at 01:45 PM
KarmaKramer
p.1 #15 · p.1 #15 · Sony 24mm f/1.4 GM lens Image Thread
I don't love 24mm for portraits,especially outdoors but I like the pez bokeh comparison lol
That bokeh is nice.
Oct 29, 2018 at 01:58 PM
Dj R
p.1 #16 · p.1 #16 · Sony 24mm f/1.4 GM lens Image Thread
That bokeh is nice.
we are brothers!
I don't either. I forced myself to shoot a few snaps with this on various projects this past weekend.
typically this will be my inside lens and night time social/reception lens.
you know what, you just have to get really close, and that is not advisable with humans
with these little kids, in this outtake shot, you can see it works ok though
I normally would have used my 35 or 50 along with my 85 outside!
cheers
the result from this , shot from my 85 GM: https://www.fredmiranda.com/forum/topic/1255248/953#14646404
Oct 29, 2018 at 02:06 PM
maestrofilms
p.1 #17 · p.1 #17 · Sony 24mm f/1.4 GM lens Image Thread
I expect you'll like the bokeh even more.
Oct 29, 2018 at 02:15 PM
KarmaKramer
p.1 #18 · p.1 #18 · Sony 24mm f/1.4 GM lens Image Thread
I like the term Pez Bokeh. That should catch on. Heard it here first.
Oct 29, 2018 at 02:36 PM
Dj R
p.1 #19 · p.1 #19 · Sony 24mm f/1.4 GM lens Image Thread
new title PEZ BOKEH MASTER
Oct 29, 2018 at 02:52 PM
GMPhotography
p.1 #20 · p.1 #20 · Sony 24mm f/1.4 GM lens Image Thread
5.6 seems brilliantly sharp across the frame.
Oct 29, 2018 at 04:15 PM
       2       3              30       31       end
       2       3              30       31       end
