girvincn Offline Upload & Sell: Off
geekcop wrote:
My eye goes right to the overly bright sky and skips the beautiful foreground. Otherwise I like the image.
Thanks for the constructive criticism! Now that I'm a few days removed from the emotional experience of shooting and editing a photo within a few hours, I look at the photo and can see you're absolutely right. The sky is certainly too bright!
lostinjapan wrote:
Very nicely done, but as geek cop said that one bright patch on sky distract/detracts from the rest of the image. Otherwise that much focus stacking had to be difficult, well done!
Ryan
Thank you for your kind words. I'll certainly agree the sky is too bright.
Mark Metternich wrote:
Awesome shot!!! So good, like others have suggested, I think it totally worth the work of a few small tweaks to master its presentation.
I hope you do not mind, but just as a quick test (since I do this for a full time living) I ran a test by duplicating a screen shot of the the image in PS, putting the Layer Blend Mode to "Color" so that brightness values can not change, only color.
I then dropped the Basic Hue/Saturation Master (all the colors) by 10pts, and then also the specific blues in the sky another 30pts.
Colors looked great with the reduction.
Then I flattened it and went to the Camera Raw Filter (on another duplicated layer but in "Normal" Layer Blend Mode) and pulled down the "Highlights" slider to the left all the way and then went to the "Split Toning" there and concentrated a little colorization in the highlights of the washed out areas of the sky to a little more organic orange/pink one might expect there. After hitting ok, I simply erased it with a soft brush into the localized sky area (mask/painting). It took maybe 2 minutes maximum. All of which could easily be done to the Raw file as well.
Next I deleted the image and wanted to give some helpful more specific feedback here.
I hope it helps.
...Show more →
Thank you, Mark! I really appreciate your input. It means a lot having an expert like yourself offer advice to weekend warriors like the rest of us. I'll continue playing with the image!
