Archive 2018 · Stone Cold
beavens
p.1 #1 · p.1 #1 · Stone Cold
From some pics I took for a friend while they were in town.
I'm not well-versed in portraiture - would more torso improve here?
Thanks for looking and C&C is welcomed.
Jeff
Jun 05, 2018 at 09:44 PM
cliphe
p.1 #2 · p.1 #2 · Stone Cold
I think the same look, but with him looking at the camera would greatly improve this shot. As it is, it looks like a snapshot (not meant to be a negative comment)
Jun 06, 2018 at 05:23 AM
beavens
p.1 #3 · p.1 #3 · Stone Cold
Thanks for the feedback, cliphe! Any thoughts on the torso cropping?
Jeff
Jun 06, 2018 at 06:10 AM
-rce-
p.1 #4 · p.1 #4 · Stone Cold
I like it, but, ... a couple of thoughts.
What does it look like if you added just a small number of inches down the torso and leave the space above the head the same?
Old school might dictate that a portrait be in portrait mode, not landscape. Have you tried looking at it from that perspective? That would eliminate a lot of 'vacant real estate' from the picture.
Rich
Jun 06, 2018 at 07:54 AM
beavens
p.1 #5 · p.1 #5 · Stone Cold
Rich
Rich,
Thanks for your thoughts! I want to say the issue here is that I didn't properly compose in-camera and that this is uncropped. My gut says that I need those few inches that you're suggesting.
I haven't tried a portrait crop, but that's a good idea that might help reduce the tightness on the bottom.
Jeff
Jun 06, 2018 at 07:58 AM
shekarn64
p.1 #6 · p.1 #6 · Stone Cold
Agree with Rich - little more on the bottom will look better. Also a square crop might be better too.
Jun 06, 2018 at 10:44 AM
beavens
p.1 #7 · p.1 #7 · Stone Cold
Thank you for the feedback! I'm definitely going to mess around with a vert/square crop as well see if a content-aware fill can buy a little more real estate.
Cheers!
Jeff
Jun 06, 2018 at 10:46 AM
p.1 #8 · p.1 #8 · Stone Cold
Many good points here Jeff! There is a way in CS6 that would allow you to expand the crop and use Content Aware Fill to fill the expanded crop to balance the image. I believe that the "portrait" mode might better display this young man. But that is just me. It is your photo and what you like, I like!
Personally I like the positioning of the boy in the frame. Most bust sculptures are from the position you display here! Why not a photo?
Jun 10, 2018 at 08:38 AM
beavens
p.1 #9 · p.1 #9 · Stone Cold
Dan - I must admit that I've been slacking!! Thanks for the nudge here so I can go back and add a little more to the torso and recrop to portrait.
I'll post the rework when I get back home in a few.
Thanks!!
Jeff
Jun 10, 2018 at 09:13 AM
gschlact
p.1 #10 · p.1 #10 · Stone Cold
Since this is the whole frame and you can't add torso, try a crop removing some of the deadspace above the head.
Jun 10, 2018 at 10:59 AM
p.1 #11 · p.1 #11 · Stone Cold
Jeff
No admission needed Jeff! U do what U do when U have the time!
Jun 10, 2018 at 11:02 AM
beavens
p.1 #12 · p.1 #12 · Stone Cold
Thanks for the tip!
Below is a rework with a portrait crop and a bit more room added on the bottom with a fill.
Thoughts, all?
Jeff
Jun 10, 2018 at 11:54 AM
