Archive 2018 · Tamron 70-200mm focus breathing
pr4photos
p.1 #1 · p.1 #1 · Tamron 70-200mm focus breathing
Can anyone that's got the Tamron 70-200mm G2 lens and has also got a Nikon 70-200mm or Nikon 80-200mm lens please do a comparison at 200mm for me please
Testing mine at 7ft on a tripod, at 200mm with the Tamron, I am at 150mm with the Nikon 80-200mm to fill the same amount of frame
At infinity they are both the same
Thats a lot of focus breathing at the shorter distance!
Jan 18, 2018 at 08:46 AM
Vcook
p.1 #2 · p.1 #2 · Tamron 70-200mm focus breathing
if you google I think matt granger did a test on this. Focus breathing was similar to nikon 70-200 vr2 but the MFD was shorter so you could fill the frame more at closer distances if needed.
Jan 18, 2018 at 09:51 AM
Warkari
p.1 #3 · p.1 #3 · Tamron 70-200mm focus breathing
This blog has a good comparison.
https://www.thepixelconnection.com/blog/Tamron70200G2/
Amit
Jan 18, 2018 at 04:11 PM
CanadaMark
p.1 #4 · p.1 #4 · Tamron 70-200mm focus breathing
The G2 is a lot better than the original Tamron 70-200 for magnification change at MFD.
The G2's maximum reproduction ratio is 1:6.1. The Nikon 70-200FL is the best of any 70-200 right now at 1:4.76. The Nikon 70-200 II is 1:8.33.
Note that a 70-200 lens by design has to reduce it's focal length down to about 160mm at MFD to AVOID breathing. If it keeps a focal length greater than that, it's actually still breathing, just in the opposite direction.
Jan 18, 2018 at 05:05 PM
pr4photos
p.1 #5 · p.1 #5 · Tamron 70-200mm focus breathing
OK, thats cool. Thanks for the explanations
Jan 19, 2018 at 05:08 AM
