BlueBomberTurbo Offline Upload & Sell: Off
idsurfer wrote:
Well, IMO one disadvantage of crop is low light situations. I switched from canon FF to a6500. While the AF works quite well in low light, I need to use higher ISO's to keep my SS's up which makes for a noisier image. So you might have to ask yourself if that trade off will work for you.
The A7's sensor is quite old, and is mostly matched by the A6300/A6500. The only noticeable difference would be the loss of the "full frame look". DOF will be a bit wider, and you'll lose the widest of wide angles. In exchange, you can use wider apertures without them becoming too shallow as fast, and you get greater telephoto reach.
If you were comparing the A7R/S to the A6500, then you'd be losing something IQ-wise, but there's no problem vs the A7.
