Archive 2017 · charging A7r via cigarette lighter?
Dustin Gent
p.1 #1 · p.1 #1 · charging A7r via cigarette lighter?
heading on a quick 5 day backpacking trip to the san juan mountains, and am making a list of things i might need. I have 5 Sony NP-FW 50 batteries, which may last me the whole trip - but may not. I do have a solar panel, but might take 100 years to charge and not the most dependable route to go.
my buddy is flying in, and he has an inverter - which i am sure he will bring. I also have access to a Goal Zero Yeti 100/400 charger, but last option.
I do have a cigarette lighter phone charger that has a fuse, but was wondering if that is a dicey way to go? I totally forgot that the A7r could be charged via USB. I came across this.... https://www.talkemount.com/threads/on-the-go-charging.14869/
Jun 26, 2017 at 09:49 PM
Charlie N
p.1 #2 · p.1 #2 · charging A7r via cigarette lighter?
works fine. If you want a more safe approach, you can use the cig lighter to charge wasabi dual battery charger. It's a super small charger, and nice to have 2 batteries topped at all times, I can just swap when I need to.
https://www.amazon.com/Wasabi-Power-Battery-Charger-NP-FW50/dp/B01M8L4NA0/ref=sr_1_6?ie=UTF8&qid=1498535574&sr=8-6&keywords=wasabi+dual+charger
I've had no issues charging via car charger designed for phones directly to a7r/a7rii
Jun 26, 2017 at 10:54 PM
Dustin Gent
p.1 #3 · p.1 #3 · charging A7r via cigarette lighter?
good to know. I have two different model Sony chargers as well. May take the Goal Zero just in case, but will see how the 12V charger will do
Jun 26, 2017 at 10:57 PM
notherenow
p.1 #4 · p.1 #4 · charging A7r via cigarette lighter?
That will work but will take longer.
This is what I would take (or a normal charger and maybe an AA charger too).
I wouldn't want to use it to charge a depleted battery but for topping up works a treat.
Jun 27, 2017 at 12:01 AM
Michel85
p.1 #5 · p.1 #5 · charging A7r via cigarette lighter?
Another option is to get a external power pack to provide the extra needed power just in case. The Anker Powercore 10000 for example will weigh less than 200 grams, cost you only aboud USD 25,=, and allows you to get approx 4 full NP-FW50 charges. It will also charge your phone or other electronic devices.
https://www.amazon.com/Anker-PowerCore-Ultra-Compact-High-speed-Technology/dp/B0194WDVHI
I'm heading on a 4 week trip without electricity and will rely on a small solar panel, onr 20.000 mAh powerpack, one 10.000 mAh powerpack and 8 NP-FW50 batteries.
Jun 27, 2017 at 10:18 AM
