DavidBM Offline Upload & Sell: Off
genji wrote:
My perception was that the bayonet mount on the A7II and A7RII is noticeably "tighter" than that of the A7 and A7R. However I've been able to use Novoflex and Rayqual adapters without problems on all models.
Ditto. All my Novoflex and Rayquals survived the transition from A7r to A7rII. Most but not all of the others.
I think that the others have a lot of variation, and I think the mount on the A7r and the other gen 1 models was intentiaoally averaged around a looser setting so more variation would be tolerated without things not fitting.
When they went to tighter tolerances on the II they were able to make them tighter without fear of anything not fitting.
Unless, of course, that thing was made to loose tolerances like cheap adapters, in which case the samples at one end wouldn't fit. I had two OM adapters of the same brand and age: one was fine on the rII, the other too tight.
This explanation is just speculation, I should emphasise..
