scrappydog Offline Upload & Sell: Off
kurt765 wrote:
Really? I guess I need to give it another try but I wouldn't say I've ever seen anything that remotely makes me think I could focus on a BIF with the IV and A7r2 and 100-400 II. In fact, in my recollection it couldn't even really focus at 400mm. Maybe I have some sort of setting wrong? Both this and the OP make me think I've got some kind of setting problem or something.
Can you guys give a rundown on what focus settings / Metabones mode gets you such good results with the 100-400 II?
I use the MB in Green mode (I think). I have a slightly older firmware (0.49 ). For any supertelephoto to AF fast on a Sony mirrorless, the lens must be near focus. If the lens is way off focus and an action shot develops, I will hand focus the lens to near focus and then engage the AF to fine tune the focus. Generally speaking, you want decent light and good contrast to help the AF system quickly find its target. Sony's AF system is tuned to vertical lines, so if you have the option between focusing on horizontally-oriented contrast and vertically-oriented contrast (e.g. shadow line around a bird's eye), select the latter for faster AF acquisition. Since Sony's tracking on the A7RII is not very good, I engage the AF in spurts. In the menu, make sure Phase Detection AF is selected. I usually leave my focus mode in AF-C, which is critical in BIF shots. I use back-button focus, which helps with engaging the AF system at will.
Generally, I keep the focus area in either small or medium zone. I don't use the large zone just because I don't find to be very precise. The small zone is the most precise and is very usable in the right conditions (e.g. good light, slow moving subject). In low light, the medium sized zone seems much more sensitive than the small zone, but the trade off is potentially the loss of some precision in the AF (e.g. the camera focuses on the wing rather than the eye). In BIF shots, I usually keep the camera on the medium zone. With BIF shots, you need to shoot at 1/800 shutter speed (in the minimum), and if you literally want to freeze a bird in action, shoot at 1/2000 or faster when using natural light (I rarely shoot with flashes).
If you'd like to see the results, check out my Flickr feed. I post a lot of shots in high-res.
