brockslinger Offline Upload & Sell: Off
Monika C wrote:
That's on my list, too. Need low water, don't you? Not that that's been a problem these last couple of years. Do you have a tighter crop? The foreground in #2 is, to my eye, anyway, not interesting enough to command half of the frame. While you got a bit of color in the sky in #1, it seems that it's the meandering water, reflection & rock walls/features that are the main subject.
Thanks for the reply Monika -
Yeah this is fairly low water but definitely not it's low point for the year. That usually happens in April; you would then see a spine in the middle that would carve out more twists.
If you've been to the spot you know there is little in the terms of foreground to add. It's mostly slickrock and there are a few dry desert plants here and there; I have a couple of comps with them in it but the lighting wasn't as good in those.
I will try to crop some of the sky for #1 but I wanted to include the entire water scene and still keep it a 2:3 ratio.
