       2       3              8       9       end
Archive 2016 · Canon 5D4 dynamic range analyzed from RAWs
cgarcia
p.1 #1 · p.1 #1 · Canon 5D4 dynamic range analyzed from RAWs
About 13.3 - 13.4 EV at ISO 100 (noise level about 3 DN).
This is about 0.1 EV less than 1DX2:
ISO 100 (793A6840.CR2): 13.38 EV (1dx2 was 13.55)
ISO 100 (793A6466.CR2): 13.29 EV
ISO 100 (793A6491.CR2): 13.29 EV
ISO 400 (793A7165.CR2): 12.88 EV (1dx2 was 12.83)
ISO 800 (793A7094.CR2): 12.32 EV (1dx2 was 12.58)
ISO 1600! (793A6463.CR2): 11.57 EV (1dx2 was 11.82)
ISO 3200 (793A7330.CR2): 10.65 EV (1dx2 was 11.28)
ISO 25600 (7A0A0098.CR2): 8.40 EV (1dx2 was 8.49, 1dx was 8.79)
About 1.60 EV above 5D mark III results, exactly just like 80D and 1DX2 which also are about 1.60 EV better than their predecessors.
The test image at ISO 1600 had no blown pixels, so the saturation level is assumed (but surely correct). All ISO levels seem to saturate at exactly DN 16383, the black level is 512 for ISO 100 (and likely ISO 200, but dpreview had not a single shot at ISO 200) and 2048 for the rest of the ISO levels.
The previous threads results (since the new Canon sensor era):
1DX2: https://www.fredmiranda.com/forum/topic/1421137
80D: https://www.fredmiranda.com/forum/topic/1419472/0
PS: I edit the initial post because the results were wrong: a saturation of 14380 (instead of 16383) was hardcoded in the tool, causing a general underestimation. I just have changed my impressions and comments in consequence... I apologise by the not-so-good initial news :-)
* * * * UPDATED * * * *
These are the final DR graphs, using the RAW samples from Imaging Resource. When there are several RAW for a given ISO level (e.g. 4 files for ISO 100) the file with the higher DR has been selected (but the differences are tiny).
Note how the 5D4 has different values for each color channel, specially at low ISO levels. This is a very rare feature:
https://lightful.github.io/talk/photo/sensor/DR_5D4_RGB.png
The 1DX2 sensor is "normal" in this regard:
https://lightful.github.io/talk/photo/sensor/DR_1DX2_RGB.png
The comparison uses the two greens channels combined on each camera. Had we used the combination of the 4 channels (RGGB) the result would almost 100% match that of the combined greens alone:
https://lightful.github.io/talk/photo/sensor/DR_5D4_vs_1DX2.png
The full data used for the graphs is here, for anybody interested on it:
https://lightful.github.io/talk/photo/sensor/DR_5D4_vs_1DX2.txt
Edited on Sep 05, 2016 at 04:11 PM · View previous versions
Aug 29, 2016 at 06:08 PM
EB-1
p.1 #2 · p.1 #2 · Canon 5D4 dynamic range analyzed from RAWs
How does that noise compare to 5D III at high ISOs 1600+?
Aug 29, 2016 at 06:12 PM
arbitrage
p.1 #3 · p.1 #3 · Canon 5D4 dynamic range analyzed from RAWs
DPReview has 5D4 in there comparison with RAWs to download at all ISOs now.
Thanks for doing this analysis.
Aug 29, 2016 at 06:19 PM
cgarcia
p.1 #4 · p.1 #4 · Canon 5D4 dynamic range analyzed from RAWs
Maybe tomorrow I'll take a look on them.
I have corrected my (wrong) initial results. The tool I use (https://github.com/lightful/hraw) is still manual (too much manual, editing by hand the values) and I made a mistake.
Fortunately, the 5D4 is just as good as the other Canons with the new generation of sensors. And the difference is consistent: +1.6 EV improvement at ISO 100 in all the new cameras.
Aug 29, 2016 at 06:44 PM
Tom_W
p.1 #5 · p.1 #5 · Canon 5D4 dynamic range analyzed from RAWs
About what I was (guardedly) expecting. A welcome improvement.
Aug 29, 2016 at 09:47 PM
Pixel Perfect
p.1 #6 · p.1 #6 · Canon 5D4 dynamic range analyzed from RAWs
Hey good work, thank you for proving what we had hoped for. Looks like the same process being employed sensor wide at Canon.
I wonder if this is what Canon will stick to for another 5-8 years or will keep pushing the DR over the next generations. Be nice to eventually see them push into the high 14EV for DR, but for now things are looking pretty good, no complaints on the sensor other than keeping the AA filter.
Aug 29, 2016 at 09:55 PM
phibes
p.1 #7 · p.1 #7 · Canon 5D4 dynamic range analyzed from RAWs
some interesting discussion over here:https://www.dpreview.com/forums/post/58260802
Aug 29, 2016 at 11:34 PM
robinlee
p.1 #8 · p.1 #8 · Canon 5D4 dynamic range analyzed from RAWs
Thanks for the good work, although I was anticipating the DR would be slightly better than 80D and 1Dx2 being a all rounder camera, but it is a welcome improvement
Aug 30, 2016 at 01:16 AM
PhilDrinkwater
p.1 #9 · p.1 #9 · Canon 5D4 dynamic range analyzed from RAWs
I think this is exactly what I was expecting.
I know it's not class leading but they have a 5 year head start, and at this level without banding I'm now happy for the very occasional shot that I would need it for.
Aug 30, 2016 at 01:37 AM
Bmxer241
p.1 #10 · p.1 #10 · Canon 5D4 dynamic range analyzed from RAWs
Great news. Sure not the same as competitor but they also have many other technologies they don't have... DPAF being one of them.
Will you be compiling this data into a graph like you did with the 80D. Thank you again for your work.
Aug 30, 2016 at 06:45 AM
charlesk
p.1 #11 · p.1 #11 · Canon 5D4 dynamic range analyzed from RAWs
How does this compare with the 5DS/r?
Aug 30, 2016 at 06:57 AM
alundeb
p.1 #12 · p.1 #12 · Canon 5D4 dynamic range analyzed from RAWs
Roughly 1 Ev better than the 5DS R.
Aug 30, 2016 at 07:07 AM
fplstudio
p.1 #13 · p.1 #13 · Canon 5D4 dynamic range analyzed from RAWs
I recall
5ds/r 12.4
6d 12.1
5d iii 11.7
Aug 30, 2016 at 07:10 AM
level1photog
p.1 #14 · p.1 #14 · Canon 5D4 dynamic range analyzed from RAWs
That's pretty promising. Not world leading but decent. If you can't take decent picture with modern camera, I don't think it's the camera fault.
I just wish the price is more competitive. I'll be happy with Canon 6D II with the same sensor around ~$2000
Aug 30, 2016 at 09:01 AM
Daan B
p.1 #15 · p.1 #15 · Canon 5D4 dynamic range analyzed from RAWs
Great news... and the files look very good too (contrast / colors). I noticed something similar with the 80D files. Not sure how to describe what I am seeing, but I really like it and it seems different than the previous generation Canon sensors. Now to get my hands on a proper profile to play with the RAW files.
Aug 30, 2016 at 09:13 AM
charlesk
p.1 #16 · p.1 #16 · Canon 5D4 dynamic range analyzed from RAWs
Thanks. I wish I had a better subjective feel for what actual impact that will have in the "real world".
Aug 30, 2016 at 09:18 AM
dhachey
p.1 #17 · p.1 #17 · Canon 5D4 dynamic range analyzed from RAWs
Very good, thanks for making these measurements. I think we are at the point where LCD panels and print are now the limiting steps in photography. No doubt the pixel noise performance is much improved too. Time to upgrade I think.
Aug 30, 2016 at 09:53 AM
RustyBug
p.1 #18 · p.1 #18 · Canon 5D4 dynamic range analyzed from RAWs
Look at the 80D files ... there's your clue
Aug 30, 2016 at 09:54 AM
PhilDrinkwater
p.1 #19 · p.1 #19 · Canon 5D4 dynamic range analyzed from RAWs
That number surprised me.
I know you can't always tell 1/2 stop in reality, but when I compared the normalised ISO3200 studio shots from DPReview, I couldn't see a half stop difference. I even raised the exposure on both and still couldn't see a difference.
I guess time will tell...
Aug 30, 2016 at 01:41 PM
Schlotkins
p.1 #20 · p.1 #20 · Canon 5D4 dynamic range analyzed from RAWs
Interesting. Didn't think it would be that much worse that the 1DxII at high ISOs. Regardless, better but still probably a stop behind Sony...
If the 5DsR had these values... I'd be in. Come on Canon. Do a quickee update.
Aug 30, 2016 at 01:54 PM
       2       3              8       9       end
       2       3              8       9       end
