DavidBM Offline Upload & Sell: Off
p.1 #6 · p.1 #6 · Sony 90mm f/2.8 Macro G OSS - is this normal behavior? | |
smpetty wrote:
I have the 90 macro and an A7RII. I am struggling with focusing this lens.
Settings:
Focus Area - Lock-on AF Center
Focus Mode - AF-C
Face Detect - Off
Drive Mode - Continuous (slow)
Pre-AF - Off
Phase Detect Area - On
Aperture Priority
The image sort of bounces, pulsing in and out rapidly, when I try to focus. Sometimes the focusing settles in and behaves, but most of the time it bounces and never achieves good focus. This is happening in full sun or bright overcast - plenty of light. Setting the lens focus range (0 - infinite, 0.5m - infinite, or 0.28m - 0.5m) makes little difference.
Is this normal behavior? Am I doing something wrong?
Thanks,
Scott...Show more →
This happens with continuous AF and relatively close focussing distances with a number of lenses.
Think of it this way: Continuous is always trying to adjust the focus. If something is close to you, the slightest hand tremor will get you out of focus, so it has to adjust. But by the time it's adjusted, it has to do it again.
Can be made worse by low light (because each adjustment takes longer) or small apertures (because effectively less light and the the camera is less good at telling if it needs to readjust)
Single AF will take it away: but of course what you can tell is that you may not get exact focus this way, because by the time you take the exposure you may be a few mm closer or further away from the subject. Of course it is likely OK; but this phenomenon is a kind of warning that even if you have the shutter speed for hand held, for ideal sharpness you need a tripod.
