Archive 2016 · Elakala Falls with thanks to Kee Woo Ree
TimMc
p.1 #1 · p.1 #1 · Elakala Falls with thanks to Kee Woo Ree
I would not even had known about this falls without the post and great picture from Kee about three months ago. Thanks Kee, we really enjoyed the falls
https://c2.staticflickr.com/8/7348/27733589785_c8d5ef9e9a_b.jpg
Jul 28, 2016 at 11:04 AM
jforkner
p.1 #2 · p.1 #2 · Elakala Falls with thanks to Kee Woo Ree
Sweet!
Jul 28, 2016 at 11:22 AM
dbehrens
p.1 #3 · p.1 #3 · Elakala Falls with thanks to Kee Woo Ree
Yes - I have a catalogue of FM spots as well. Nice pic. I think it would be a stronger comp if you would crop out the bridge. Dave
Jul 28, 2016 at 12:09 PM
TimMc
p.1 #4 · p.1 #4 · Elakala Falls with thanks to Kee Woo Ree
Dave-I agree with you and started that way. In landscape mode I ended up with a two shot pano that I really like, but, in fairness, also too close to Kee's great shot. I went to portrait mode and started with the bridge above the top of the frame. But what is below the circular pattern gets to be an eyesore. I then zoomed in to crop the bottom out and found the transition from the upper to lower pool another eyesore. Finally I angled up to include the bridge and zoomed out to what you see to minimize the impact of that ugly transition area.
I have maybe 15 shots of this area but then ran out of clouds and the sunlight took over. Hopefully I get back this fall. Different flow conditions, fall color and great light may yield a different composition. And just maybe I will have time to try different shutter speeds so that I can argue with Jim Fox about "best" shutter speed.
Thanks for the comment
Jul 28, 2016 at 06:07 PM
p.1 #5 · p.1 #5 · Elakala Falls with thanks to Kee Woo Ree
This is excelent Tim
Jul 28, 2016 at 06:39 PM
JimFox
p.1 #6 · p.1 #6 · Elakala Falls with thanks to Kee Woo Ree
Hey Tim,
Very nice work here. I like that swirl in the foreground.
It will be interesting to see your experiment with shutter speeds. Bear in mind that with water swirls, those are exceptions to the normal sweet spot for water, typically they require 1 sec to 5 secs depending on the amount of bubbles in the water and the speed of the water.
Jim
Jul 28, 2016 at 08:08 PM
TimMc
p.1 #7 · p.1 #7 · Elakala Falls with thanks to Kee Woo Ree
Morris & Jim--thank you
Jul 29, 2016 at 05:51 AM
Jim Dockery
p.1 #8 · p.1 #8 · Elakala Falls with thanks to Kee Woo Ree
Very nice as is, but I agree with dbehrens that it would be stronger cropping out the bridge, but I'm a nature boy and prefer just seeing that without human artifacts.
Jul 29, 2016 at 09:27 AM
