tshore Offline Upload & Sell: On
After years of screwing up macro shots, here is what I have settled on:
1. Use a flash. A popup flash is better than nothing, but an add-on flash like a 430 ex will be better. Then, use a diffuser. It's fun and instructive to create your own, but in my experience a mini softbox works decently and is cheap.
2. Set the flash on auto.
3. To have a workable DOF, you need a narrow aperture (f/11 to f/16). It also helps to have a reasonably fast shutter speed, to avoid ghosting, so set your camera on M mode, the aperture to say f/14, and the SS to 1/200 for a 100mm macro lens.
4. If your subject is in the sun, set the ISO to 100. If your subject is in shade, 400 or so. Combined with the above, this should result in your subject being correctly exposed, with about 50% of the exposure coming from the flash, and 50% from ambient light. The background will typically be about 1 stop underexposed (depending on the distance from the flash) , so your subject will stand out, but the BG will not be dark or black.
5. If you find the BG too dark, increase the ISO, if too light, decrease it.
6. Don't bother trying to auto focus if your subject is very close (i.e. near the minimum focusing distance for the lens). For hand-holding, best idea for getting very-near subjects in focus is usually to set the focal distance manually, then move the camera back our up until the focal plane is where you want it to be. What you see in your viewfinder will be the focus at f/2.8, so you will have more DOF than what appears in your viewfinder, but focus is still a challenge. Be prepared to take multiple shots to get one that is in focus, particularly for bugs, where you want to get the eye sharp.
7. Practice!
Hope this helps.
