Archive 2015 · A7ii or A7Rii for MF glass.
goosemang
p.1 #1 · p.1 #1 · A7ii or A7Rii for MF glass.
Looking to grab an A7 for manual focusing purposes. I have no need for a 42 MP body, but I'm wondering if there are other important differences between these two bodies that I'm missing. My primary concerns would be the quality of the EVF and annoying shutter mechanisms. Any input?
Dec 29, 2015 at 11:07 PM
TheEmrys
p.1 #2 · p.1 #2 · A7ii or A7Rii for MF glass.
Well, the a7rII has better coatings on the EVF (Zeiss T*), and has a silent shutter mode (has issues with fluorescent lights). Both have Electronic Front Curtain Shutter, but can have problems at 1/1000 or faster.
Dec 29, 2015 at 11:28 PM
arduluth
p.1 #3 · p.1 #3 · A7ii or A7Rii for MF glass.
The main advantages of the A7RII are the resolution, slight high ISO improvement, and better AF, especially with Canon EF and A mount lenses. If those don't matter, go with the A7II.
Dec 29, 2015 at 11:58 PM
Viramati
p.1 #4 · p.1 #4 · A7ii or A7Rii for MF glass.
From a MF POV I find the A7r II to be better (I have both)
Advantages of A7rII
1. EVF better in low light (though not as good as A7s) make focussing easier
2. Focus magnification view appears to give more detail
3. Silent shutter when needed (has colour banding issues with fluorescent lights)
4. Hardly any difference in shutter sound but I wouldn't call it annoying as it is quite well damped
Apart from this for manual focussing they are about the same
Dec 30, 2015 at 03:53 AM
Michael Everet
p.1 #5 · p.1 #5 · A7ii or A7Rii for MF glass.
Advantages of A7rII
How does the sound of the shutter compare to the A7 and A7s? I am thinking of going to the A7II from the A7 to get the IBIS because I shoot mostly MF. My main problem with the A7 is the shutter noise, because I often shoot classical concerts.
Dec 30, 2015 at 11:48 AM
Charlie N
p.1 #6 · p.1 #6 · A7ii or A7Rii for MF glass.
shutter is quieter if comparing to the A7r vs A7ii and A7rii (sound virtually the same). The silent shutter however, is truly silent, like no noise at all. Full electronic shutter.
i dont own the a7, but do a7r and a7rii, the shutter of the new one is half as loud if I had to guess. Put on electronic first curtain, and it halves the duration of the shutter as well.
Dec 30, 2015 at 12:29 PM
Samonrajabnik
p.1 #7 · p.1 #7 · A7ii or A7Rii for MF glass.
STABILIZATION!!!!
It really is a major difference. Handhold a 50mm lens and shoot reasonably at 1/3 of a second... pretty major advantage. I think of the stabilization as affording about 2 additional stops of light - as far as shooting in low light situations go.
Jan 04, 2016 at 04:22 PM
akclimber
p.1 #8 · p.1 #8 · A7ii or A7Rii for MF glass.
I use both an A7II and A7RII with manual focus lenses and agree with Viramanti's post but I think it's a pretty close call. 2 other differences I've noticed: 1) I think the 42MPs of the A7RII tend to stress the capabilities of the older lenses in the corners - with some of my manual focus lenses (mostly standard length primes 50-85mm) the corners on the A7II seem better than on the A7RII (but who knows - it could just be how the adapters are sitting on each mount, etc.) and 2) high ISOs on the A7RII seem better, amazingly enough. I don't think you would go wrong with either choice but the A7II is substantially less expensive.
Good luck!
Jan 04, 2016 at 05:44 PM
dukeman1234
p.1 #9 · p.1 #9 · A7ii or A7Rii for MF glass.
I don't know how the 7ii does in this regard, but the 7rii's bsi sensor has gotten rid of color cast issues that plagued the original 7r.
Jan 04, 2016 at 07:02 PM
Mike Ganz
p.1 #10 · p.1 #10 · A7ii or A7Rii for MF glass.
The major advantage with the A7R2, in my opinion, is the IBIS stabilization. Every piece of legacy glass now has the advantage of in-camera stabilization.
Jan 07, 2016 at 12:34 PM
jonrock
p.1 #11 · p.1 #11 · A7ii or A7Rii for MF glass.
It sounds roughly similar but the A7II might be slightly more quiet. I just upgraded myself from the A7 to an A7II. The IBIS is very helpful. I'm routinely getting 2.5 to 3 stops of stabilization. Also, if you do use a few AF lenses, the AF is slightly better compared to the A7 but not as good as the A7RII.
Jan 07, 2016 at 01:36 PM
Jman13
p.1 #12 · p.1 #12 · A7ii or A7Rii for MF glass.
The A7 II is also stabilized.
As to the note about AF, especially with Canon lenses: AF itself is very similar between the two with Canon glass. The only major difference is that the A7R II has wider coverage of PDAF points. The A7 II's are in the center 50% of the frame while the A7R II's cover most of the frame.
Jan 07, 2016 at 02:18 PM
Mike Ganz
p.1 #13 · p.1 #13 · A7ii or A7Rii for MF glass.
Oops...missed that. I thought the question was between the A7R and A7R2.
Jan 07, 2016 at 05:20 PM
