timballic Offline Upload & Sell: Off
I just received my A7 830nm conversion back from Protech Photographic (UK) a week ago. It hasn't stopped raining since, so no way of testing! :o(
In reply to my question, " is The Sony A7 a pain to convert cf. other makes? I believe its construction is far more modular than Canons or Nikons, which should make it easier?"
Kelvin at Protech replied:
"Having repaired cameras for well over 35 years I would say that Sony is not built like a "conventional" camera ie body casting with parts attached to it.
With the A7 you have to remove 80-90% of the cameras internals to get to the sensor - the LCD panel, rear cover, board, top cover, a couple of frames, few metal mounting brackets and more screws than I cares to count!
We have converted A7, A7II and A7R and they all employ the same method of mounting the sensor glass, the self cleaner (removed) is in a plastic frame with a metal retainer and the frame and the other filter are stuck to the surface of the sensor with tape.
The camera's although similar in construction do not come apart the same!
Still keeps things interesting....
Kelvin.
Interesting that the custom WB done by Kelvin is B&W with Live View setting effect ON, but goes magenta if I turn setting effect OFF. I'm wanting some sun lit grass to see if I can get a custom WB that turns it B&W in OFF too.
The real challenge is getting the lenses right, without any hot spots. I know that the FE 55/1.8 and FE 28/2 are supposed to be good in IR (not the FE 35/2.8 though), but mixed reports about the FE 24-70, that I'm hoping to use.
