Archive 2015 · Yosemite fall2014
nugeny
p.1 #1 · p.1 #1 · Yosemite fall2014
This was from last year. 2 hours after sunrise.
Nov 02, 2015 at 12:55 PM
nugeny
p.1 #2 · p.1 #2 · Yosemite fall2014
Just turned my back to get this
Nov 02, 2015 at 12:59 PM
dswiger
p.1 #3 · p.1 #3 · Yosemite fall2014
I think the 2nd one has the most appeal but it appears over-exposed a bit.
The first is really tilted to the left a lot.
Thanks for posting
Nov 02, 2015 at 02:33 PM
stanparker
p.1 #4 · p.1 #4 · Yosemite fall2014
I like #2 as well, but I think I would darken the water a bit.
Nov 02, 2015 at 02:44 PM
nugeny
p.1 #5 · p.1 #5 · Yosemite fall2014
Thanks for posting
It was a rather foggy morning. I like the fog. If I darken the water, I am afraid I would reduce the fog in the process. I may not quite follow you. You are welcome to work on this picture. I would appreciate seeing your vision.
Nov 02, 2015 at 04:22 PM
dswiger
p.1 #6 · p.1 #6 · Yosemite fall2014
Bob, I would use a curves adjustment on a layer. When you select a contrast (light/med,etc), it will darken the shadows tones & lift the highlights a bit. You can tune it too taste.
Nov 02, 2015 at 08:04 PM
stanparker
p.1 #7 · p.1 #7 · Yosemite fall2014
Bob, Rather than post changed photos, let me offer two modifications you can easily and quickly try to see if you like either. 1,) Using the burn tool set to 30% exposure in PS, run over just the water to darken it a bit. Repeat to taste. (Once seemed enough to me). 2.) Make a layer and do a blending change to soft light, then set opacity to taste. This simply increases contrast.
I like the second technique, but you may feel differently.
Nov 04, 2015 at 01:24 PM
