Kris Sproul Offline Upload & Sell: Off
Thanks for your thoughts, everyone! I really appreciate all the feedback. To answer a few specific points:
docsmiles17 wrote:
Well, I like the pilings of the prior shot but the bridge better in this shot. It would have been great to see the entire bridge. Can you edit the bright light you are speaking of?
….Sounds like you are quite in tune with critiquing your own work which is hard to do and nice to hear
I tried editing out the bright light, but the light expanded so much into the surrounding area that it was very difficult to do it well. In the end, it seemed much cleaner to just crop it out. I do have a few earlier shots that include the whole bridge before the close streetlight turned on, but I didn't like those shots nearly as much as the twilight ones.
Thanks for your feedback and comments on critiquing my own work. I'm always looking to improve, and I really respect the opinions given on this forum, which is filled with amazing photographers.
jemark wrote:
Have you considered cropping off the left side of the above, image to balance the crop of the right? Maybe on a line somewhere between those two rocks lower left corner? I am not sure the left two inches add to the photograph.
Just a thought.
Thanks for the ideas. I did consider cropping it a bit more on the left, but I didn't want to chop off any of the bridge on the left side or any of the left rock. I may play around with the crop a bit more, but in general, I was pretty happy with how that side came out. I appreciate the thought though!
hrossm wrote:
I'll go with version one but (dumb question warning!) could you have got a bit to the left to draw the rock a little more into the shot?
I moved around a lot when taking these shots, so I don't recall if I could've moved further to the left at that particular point, depending on how close the water was. However, if I could have, it would've moved the shoreline itself too far to the right, bringing it more toward the center of the photo, which wasn't really what I was going for. I'll keep that thought in mind the next time I'm at this location though, since it sounds like a couple of you don't really like the extra space to the left of the bridge. Thanks!
Fred Miranda wrote:
It's so sharp! I really like the 2:1 crop. It's just simple, keeping all desired elements for the comp.
Best,
Fred
Thanks, Fred! This was actually the first shot I tried focus stacking on. I'm going for shots that I can use to do large fine art prints from, so having sharpness from front to back is important to me. I only combined two shots for this one, but I really did help keep full sharpness in both the foreground rocks and the bridge. I appreciate your comments!
Kris
