Michael Marsh Offline Upload & Sell: Off
Justin Grimm wrote:
I’m not sure if you are looking for advice on stacking, or comments on the final result, but here are some general stacking tips.
When focus stacking with a composition like this, your biggest issues will show up around the flower edges. With the huge amount of distance between the flowers and trees, you will end up with big blurry silhouettes surrounding the closest subjects. This is simply caused by the out of focus flower bokeh spilling out into your in focus trees. I would try and avoid such large changes in distance when composing your shot, but if you cant avoid it you will need to clone in a lot of stuff around each hard foreground edge. This is even more pronounced in macro photography, so even the small distance between an insect's leg in front of it's body can be a HUGE pain to clean up. A smaller aperture will help reduce the amount of blurry edging, but may slow your shutter speed which can cause other problems. Fun fun fun
Ive never used Zerene, but the over sharpening may be caused by your output settings. You should be able to find a tutorial with some good general settings though.
Keep practicing, it’ll get easy pretty quick!
...Show more →
Hi Justin,
Yes, and yes, I was certainly look for some input on stacking and comments on the final results. Thank you for your help. This shot was more an experiment than anything else. I am starting to get back into photography after a break and will hopefully be posting more images
As far as critiquing my stuff. I have always very much appreciated helpful input, even if the input was very harsh. I have a think skin and my feelings cannot be hurt. I would rather have one person tell me what is wrong with the shot then 10 folks tell me it is nice.
Mike
