Archive 2013 · Sea Stack Sunset (Edited)
Lee Wiren
p.1 #1 · p.1 #1 · Sea Stack Sunset (Edited)
This image may not do it for many... I have been going for a softened painterly affect lately....
Went to Bandon last week hoping to get Wizard's Hat at sunset... the sky was quite thick with clouds and the POV I had wasn't offering a sunset behind that rock... so I got this one of some sea stacks with a sunset. It was extremely windy and I tried to use my body to block most of the wind... C&C if you choose, I know that 1. this is not the most perfect of shots (wind) & 2. the PP is not going to be to many's liking, just thought i'd share.
I have added this new image into the original post so you don't have to scroll all the way to the bottom to see the new one.... I left the original so that you can see the differences that are being discussed.
First image is the new, edited version, 2nd image is the old, original version.
http://www.onthewallphoto.net/Art/Fine-Art/i-4QSSBpv/0/X2/Sea%20Stack%20Sunset%2020x30-X2.jpg
Edited on Mar 17, 2013 at 12:13 PM · View previous versions
Mar 15, 2013 at 12:39 AM
JimFox
p.1 #2 · p.1 #2 · Sea Stack Sunset (Edited)
Hey Lee,
This pretty cool looking, I like the vibrant colors you got. You will want to check the dimensions of this, the widest side should be a max of 850pix wide. But otherwise, I like what you came up with.
Jim
Mar 15, 2013 at 01:22 AM
Lee Wiren
p.1 #3 · p.1 #3 · Sea Stack Sunset (Edited)
Thanks Jim, tried to fix the size for you.
Mar 15, 2013 at 02:23 AM
Camperjim
p.1 #4 · p.1 #4 · Sea Stack Sunset (Edited)
I usually do not like images which have been over processed and over saturated. I do, however, like this one. The colors are obviously not real but help create a mood and add to the appeal of the image. I like that part. I also like the painterly look of the water. I think this would be much better if you used a mask and left the sharpness of the outline and detail in the rocks.
Mar 15, 2013 at 09:44 AM
Jglaser757
p.1 #5 · p.1 #5 · Sea Stack Sunset (Edited)
Colors a re great,,love them,,but it looks like the rocks are blurred a little bit,,was it that windy?
Mar 16, 2013 at 05:38 PM
plasticmotif
p.1 #6 · p.1 #6 · Sea Stack Sunset (Edited)
Did you miss focus? Otherwise, the soft effect isn't working - IMO. If you only took the one shot and you missed focus, shame on you! That light is lovely!
Mar 16, 2013 at 06:10 PM
Mark Metternich
p.1 #7 · p.1 #7 · Sea Stack Sunset (Edited)
Umbrella! Great shot but wish it was not blurred. Good reason to go back out!
Mar 16, 2013 at 07:20 PM
skibum5
p.1 #8 · p.1 #8 · Sea Stack Sunset (Edited)
fantastic (athough the sea stacks look blurred? OOF, tripod shake?, handheld shake? oh well)
Mar 16, 2013 at 07:22 PM
MDBarrett
p.1 #9 · p.1 #9 · Sea Stack Sunset (Edited)
I like the colors and except for the stacks being blurry which was already mentioned I think it turned out nicely.
Mar 16, 2013 at 07:42 PM
Lee Wiren
p.1 #10 · p.1 #10 · Sea Stack Sunset (Edited)
Thanks to all, YES, it was that windy.... enough to make wielding an umbrella precarious.. but as I am a S.N.O.B. (State Native Oregon Born), I don't believe in the use of umbrellas.
I went back through my shots and discovered one that the wind must not have effected as much and I think comes out much better... for those of you still looking at the thread, here is my 2nd try, not as much processing but I think it still has a painterly look to it.
Mar 17, 2013 at 12:34 AM
alatoo60
p.1 #11 · p.1 #11 · Sea Stack Sunset (Edited)
Like the second version, especially reflections on a sand.
Mar 17, 2013 at 12:37 AM
Jglaser757
p.1 #12 · p.1 #12 · Sea Stack Sunset (Edited)
still loooking and much better!!!!
Mar 17, 2013 at 11:16 AM
JimFox
p.1 #13 · p.1 #13 · Sea Stack Sunset (Edited)
Hey Lee,
Your second version is even better. Being sharper is good. You need to edit your title to indicate an Edit or such so others know to look again at this. And since you only had one photo in your original post, you might want to just edit that post and add this photo with a comment to it so people see the different shot right away. But either way, what cool skies you had that night.
Jim
Mar 17, 2013 at 11:51 AM
