       2       3              6       7       end
Archive 2012 · 7D 2.0 any problems?
Ian.Dobinson
p.1 #1 · 7D 2.0 any problems?
Ok guys I know there are a couple of threads on this fw but I thought a thread that could list any issues that any of you have come across might be a good idea.
Like many people the 7D is my only camera . And as firmware is not reversabel I don't really feel I want to junk it and then possibly go thru sending the body in to be sorted .
If it appears the firmware is solid then there would be very few post to this thread I guess
Aug 08, 2012 at 06:26 AM
Imagemaster
p.1 #2 · 7D 2.0 any problems?
Do you really need any of the features of the new firmware? If not, why install it?
Aug 08, 2012 at 08:50 AM
akin_t
p.1 #3 · 7D 2.0 any problems?
No problems here.
Honestly though, I don't understand this line of reasoning.
If you trust the engineers who brought you the original 7D firmware, and the incremental updates thus far ... Why wouldn't you trust them with this?
These people know what they're doing. They have several $$$ invested into verification and validation, they will not put out a firmware that hasn't been thoroughly tested.
Aug 08, 2012 at 09:12 AM
pKai
p.1 #4 · 7D 2.0 any problems?
No issues of any kind after several hundred shots. The new firmware works great. No reason not to update. The buffer increase and the ability to limit Auto-ISO are more than worth the price of admission --- which is about 3 minutes of your time. The rest of the updates are gravy, IMHO.
The only "issue" I ran into was that the update wiped out my date and time. Had to reset them. All other camera settings including user and copyright info were preserved.
mco_970
p.1 #5 · 7D 2.0 any problems?
No issues whatsoever. Just. Do. It!!!
Aug 08, 2012 at 09:26 AM
glockss
p.1 #6 · 7D 2.0 any problems?
Maybe one.
I'm not sure, long time ago i used 7D.
But i have trouble to upload Peripheral Illum Correction for all my lenses thru EOS Utility 2.11.4
I can only update one at a time and only then lens is on the body, i believe that in 1.2.5 you could upload up to 20 or more, I can to do that with 5D3.
Aug 08, 2012 at 09:43 AM
Ian.Dobinson
p.1 #7 · 7D 2.0 any problems?
Well the increased buffer (especially for the raw+jpeg) will be a real bonus.
I will install it. I just didn't want to rush in if there was to be a ver 2.01 to clear up any issues.
Aug 08, 2012 at 09:44 AM
sritri
p.1 #8 · 7D 2.0 any problems?
No issues what so ever on mine. 22+ RAW on a Transcend 533x 32g card and 71 L JPEG
Aug 08, 2012 at 09:46 AM
Ian.Dobinson
p.1 #9 · 7D 2.0 any problems?
akin_t wrote:
No problems here.
Well how many times have you trusted engineers before and got bitten.?
I know there have been firmware releases to various bodies that have caused issues , and additional firmware releases were required to fix .
Ok my worst experience was not with canon but I installed a new update to my Samsung galaxy s phone that was supposed to be the best thing since sliced bread. It caused me major headaches the worst of which was the phone would not communicate with the GENUINE Samsung car dock . Samsung's response was that there was no problem they knew of (even denied the existance of the car dock) and that there was nothing I could do to revert to the old firmware.
But as it seems that 7D 2.0 has no real issues I'm just about to install it.
Aug 08, 2012 at 09:53 AM
Monito
p.1 #10 · 7D 2.0 any problems?
Here is the 7D firmware 2.0 thread active at the top of the index at the time you started this duplicate thread:
https://www.fredmiranda.com/forum/topic/1138170
Aug 08, 2012 at 10:06 AM
M Lucca
p.1 #11 · 7D 2.0 any problems?
Yes. Big problem!
No 7D2 in the near future!!!!
Aug 08, 2012 at 12:20 PM
Gochugogi
p.1 #12 · 7D 2.0 any problems?
Yes, there is a huge problem: FW2.0 has transformed the 7D into a freakin' captain of light, AKA, the 7D Mark II...
Aug 08, 2012 at 12:46 PM
dcimages
p.1 #13 · 7D 2.0 any problems?
After loading the 2.0 firmware the date time window appears, What is the little "sun" or" light' symbol just before the city name for? It can be changed to on or off /
What is it for ??
Also is there a new manual to exlpain the new functions ?
Aug 10, 2012 at 04:49 PM
Ian.Dobinson
p.1 #14 · 7D 2.0 any problems?
What is it for ??
Pressumably Daylight saving time.
I pressure you have it as well when the clock goes forward an hour in the summer and back in the winter.
I presume the little sun indicates summer time so that when the date of the hour rolls back comes you won't have to do it manually .
I've now done the change, and can report no issues
I did notice a slight change in the behaviour of the buffer though, which makes me think it was artificially held back previously and that this fw just frees what was always there .
I used a pretty slow ultra2 card . Before the update i tried raw+jpeg and it would shoot 7 or 8 shots (6 in the VF) and then stop for a tiny bit and the would go in 2 shot bursts .
After the update the buffer was much bigger (18) but once the buffer was filled it would draw along at 1fps or less. Defiantly not 2 frame bursts .
Anyway alls good
Aug 10, 2012 at 05:00 PM
matt4626
p.1 #15 · 7D 2.0 any problems?
Yes alway trust the engineers...plus I have a little swamp land in Florida I'm sure you'll like
Aug 10, 2012 at 05:02 PM
uz2work
p.1 #16 · 7D 2.0 any problems?
The first time I used the camera after installing 2.0, I powered up the camera so that I could set the ISO, shutter speed, and aperture for what I wanted to use. I didn't take any shots for a while, and the camera went to sleep (as I had it set to do). A few minutes later, when I was ready to start shooting, I tried to wake the camera up with a half shutter press, and it was unresponsive. I then saw a generic ERR in the top LCD. I was able to clear the error and power up the camera only by pulling both batteries from the grip and reinserting them. Considering that I've had the 7D for just a few weeks under 3 years and had never had a single error code or lock up, I was concerned that I had my first such issue before taking my first shot with the new firmware. I've subsequently shot with the camera for 3 days without any further issues. Thus, for the moment, I'm going to assume that the error was a freak coincidence, but, until I've used it a few more times, I won't be completely at ease.
Les
Aug 10, 2012 at 05:04 PM
Fred Meebley
p.1 #17 · 7D 2.0 any problems?
Working good for me,
Aug 10, 2012 at 05:12 PM
Jim Healey
p.1 #18 · 7D 2.0 any problems?
What is it for ??
Download the most recent manual from the Canon site --> eos7d-im5-en.zip.
You'll find two documents inside the zip file:
1. An index to the new 2.0 features (eos7d-im-rm-en.pdf)
2. The updated manual (eos7d-im5-en.pdf)
Flip to page 43 for instructions on the new date/time & daylight saving feature
Aug 10, 2012 at 05:17 PM
racoll
p.1 #19 · 7D 2.0 any problems?
I've had my 7D for the same length of time and had the exact same experience after loading the firmware. Never ever had any issue prior to the firmware.
Andy
Aug 10, 2012 at 05:53 PM
uz2work
p.1 #20 · 7D 2.0 any problems?
Andy
Now, you have me concerned that the error right after installing the new firmware may not have been a coincidence.
Les
Aug 10, 2012 at 06:08 PM
       2       3              6       7       end
       2       3              6       7       end
