Archive 2012 · Telling the shot count on a D3??????
papageno
p.1 #1 · p.1 #1 · Telling the shot count on a D3??????
A friend is trying to sell me his d3, Can't figure out how many shutter actuations it has, but in cruising the mountain of exif date I got this:
<aux:LensID>120</aux:LensID>
<aux:ImageNumber>128273</aux:ImageNumber>
<aux:ApproximateFocusDistance>71/100</aux:ApproximateFocusDistance>
Does this mean it has 128273 actuations as of the image this was taken from?
Thanx!
Jun 06, 2012 at 01:16 PM
thedruid
p.1 #2 · p.1 #2 · Telling the shot count on a D3??????
Google EXIF Viewer, download it shoot in jpg, drop the jpeg on the viewer icon and scroll down to shutter clicks, viola!
Jun 06, 2012 at 01:44 PM
Chris Dees
p.1 #3 · p.1 #3 · Telling the shot count on a D3??????
On a Mac it's even easier.
Open a NEF or JPG in Preview, select info and Exit, go to the bottom and look at "Image Number".
Jun 06, 2012 at 02:00 PM
papageno
p.1 #4 · p.1 #4 · Telling the shot count on a D3??????
There are apparently a number of exif viewers out there. Tried one but did not get a shutter actuation count.
To repeat, is the image number the count?
Jun 06, 2012 at 02:31 PM
Craig Yannuzzi
p.1 #5 · p.1 #5 · Telling the shot count on a D3??????
wondering the same thing....
I have a mac but tried the exif viewer and here are my results:
File name: DSC_9594-3.jpg
File size: 4651639 bytes (0x0, infbpp, 0x)
EXIF Summary: 1/640s f/2.8 ISO1600 14mm (35mm eq:14mm)
Camera-Specific Properties:
Equipment Make: NIKON CORPORATION
Camera Model: NIKON D3
Camera Software: Adobe Photoshop Lightroom 3.5 (Macintosh)
Maximum Lens Aperture: f/2.8
Sensing Method: One-Chip Color Area
Color Filter Array Pattern: 758
Focal Length (35mm Equiv): 14 mm
Image-Specific Properties:
Horizontal Resolution: 240 dpi
Vertical Resolution: 240 dpi
Image Created: 2012:06:06 16:49:46
Exposure Time: 1/640 sec
F-Number: f/2.8
Exposure Program: Aperture Priority
ISO Speed Rating: 1600
Exposure Bias: 0 EV
Subject Distance: 0.32 m
Metering Mode: Spot
Light Source: Unknown
Flash: No Flash
Focal Length: 14.00 mm
Rendering: Normal
Exposure Mode: Auto
White Balance: Auto
Scene Capture Type: Standard
Gain Control: High Gain Up
Contrast: Normal
Saturation: Normal
Sharpness: Normal
Subject Distance Range: Unknown
Other Properties:
Resolution Unit: i
Exif IFD Pointer: 216
Compression Scheme: JPEG Compression (Thumbnail)
Horizontal Resolution: 72 dpi
Vertical Resolution: 72 dpi
Resolution Unit: i
Offset to JPEG SOI: 928
Bytes of JPEG Data: 11872
Exif Version: 2.30
Image Generated: 2012:06:06 16:49:38
Image Digitized: 2012:06:06 16:49:38
Shutter Speed: 1/640 sec
DateTimeOriginal Second Fraction: 80
DateTimeDigitized Second Fraction: 80
File Source: Digital Still Camera
Scene Type: Directly Photographed
Digital Zoom Ratio: 1
Jun 06, 2012 at 02:52 PM
Mescalamba
p.1 #6 · p.1 #6 · Telling the shot count on a D3??????
Thanx!
Yes, its exactly like that. It should last around 150k exposures. They sometimes tend do die sooner, but thats same for pretty much every manufacturer. Its not super expensive to replace it. Tho I would most likely price it according to that number (eg. lower it for around price of new shutter or at least half of it).
Jun 06, 2012 at 03:01 PM
trenchmonkey
p.1 #7 · p.1 #7 · Telling the shot count on a D3??????
No. It'll SAY "shutter count" that's the last card # it's reading
Kids, you're making this WAY too complicated. Download Jeffery's Exif Viewer...it's the best.
Hell, it'll even tell ya what you had for breakfast Onna Mac I still like REVEAL, drop any pic in
and it'll give ya the count (provided it wasn't stripped)
update: I just tried Picasa (Properties) yup...works a charm too!
Jun 06, 2012 at 03:12 PM
brianric
p.1 #8 · p.1 #8 · Telling the shot count on a D3??????
That can't be thet card reading as my card reading resets to 0 after going to 9999.
Jun 06, 2012 at 05:32 PM
papageno
p.1 #9 · p.1 #9 · Telling the shot count on a D3??????
Jeffery unloads a mountain of data to wade through. Sadly, shutter count is not one of them to my old eyes.
I scrolled through so many lines of image data I'm dizzy--twice. No shutter count.
Ideas?
Jun 06, 2012 at 06:11 PM
Avi B
p.1 #10 · p.1 #10 · Telling the shot count on a D3??????
Copy and paste the results in here. Our "younger" eyes might pick it up.
Remember it has to be JPEG straight out of camera...
Jun 06, 2012 at 06:18 PM
mfletch
p.1 #11 · p.1 #11 · Telling the shot count on a D3??????
I'm not sure about all of the different exif viewers, but I have always used Opanda. With this reader, it clearly labels one line near the bottom of the data as "Total Number of Shutter Releases for Camera".
If you are converting a NEF file, you will usually lose this data. It should be an in camera JPEG shot.
Jun 06, 2012 at 06:24 PM
NightOwl Cat
p.1 #12 · p.1 #12 · Telling the shot count on a D3??????
http://myshuttercount.com/
Upload a photo.
Jun 06, 2012 at 06:25 PM
DavidM5
p.1 #13 · p.1 #13 · Telling the shot count on a D3??????
D3 is rated for 300K actuations not 150K!!
Jun 06, 2012 at 07:03 PM
papageno
p.1 #14 · p.1 #14 · Telling the shot count on a D3??????
Am using an in camera jpg image
Actually, I thought the d3 was rated for 400,000 shots.....
Not OCDC about this, more irked that I can't dig it out....
Will try myshuttercount next
Jun 06, 2012 at 09:08 PM
papageno
p.1 #15 · p.1 #15 · Telling the shot count on a D3??????
Turns out it is the image number as noted above.
Myshuttercount did it painlessly...
Curious as to what the monkey meant about the card?
Jun 06, 2012 at 09:13 PM
Avi B
p.1 #16 · p.1 #16 · Telling the shot count on a D3??????
No D3 is rated MTBF for 300K shutter actuation (naturally it can fail before that - as well as after that).
Jun 06, 2012 at 09:28 PM
Mescalamba
p.1 #17 · p.1 #17 · Telling the shot count on a D3??????
My bad, thought its 150k. Maybe cause most failures occur at that number. If it survives 300k, than its pretty amazing..
Jun 06, 2012 at 10:01 PM
robby521
p.1 #18 · p.1 #18 · Telling the shot count on a D3??????
i tried Jeffery's Exif Viewer,its awesome.in the XMP section just a little down from picture is has image number 60021 for my d300.
Jun 07, 2012 at 01:29 AM
