Jim Levitt Offline Upload & Sell: Off
I recently acquired a 50/1.2L. I knew I'd have to stick to just the center point on the 5D2 with the lens wide open. I expected the 5D3 would allow me to utilize outer focus points, especially the cross-types, and thus avoid focus-recompose or cropping workarounds.
If I use the center point on the 5D3, the 50L focuses accurately at f/1.2. If I shift to an outer focus point (the furthest out cross-type sensors in landscape orientation) and use that to focus on the same target, the result appears to be front focused. I was testing by focusing on the spine of a book in a bookshelf, about 4 feet away, at about 45 degrees. With the centerpoint, focus was accurate and repeatable. Same technique, same target, but using an outer focus point, focus was not accurate.
Even if the lens has some amount of field curvature, should an outer focus point produce a properly focused image, if there's no focus-recompose involved?
Does the 50L always behave like this? If so, how do you use it for a shallow depth of field off-center portrait?
