davidearls Offline Upload & Sell: Off
>>There used to be a guy called Son Phin something on this forum but is not active anymore? I heard he had solutions for different sorts of lenses.
I think you mean Pham Minh Son, who was very active on this forum up until three or four years back. He made C/Y-EOS adapters, among other things. I have one of them.
His adapters are very thin - 1.3mm vs 1.6mm for Big-IS or Fotodiox, so they wouldn't help this problem, since it sounds as if one of the tabs protruding from the back of the lens is fouling on the mirror box. Try stopping the lens all the way down when it's off the camera. Mount it on the camera and open the aperture. Remove the adapter/lens. If the fouling is occurring, you should see a slight smudge on the inside of the mirror box inside the body of the camera.
I encountered this problem with my first alt, a C/Y 28 f2.8. Knowing the lens would never again be mounted on a Yashica body, I taped over the back of the lens and filed the tab down. Obviously you don't want any metal filings inside the lens.
The good news here is that nothing is fouling on the mirror itself. If that were occurring, the mirror would be getting hung when you released the shutter.
FWIW, I don't normally use this adapter much any more. Pham's adapters are very, very tight on the lens and almost impossible to remove if the lens barrel is the same width or wider than the adapter.
