Steve Spencer Offline Upload & Sell: Off
Yes, those mtfs look good, but given how high the 10mm and 20mm lines are in the f/8 graph, it looks to me like they are theoretical rather than actual measurements. Even if they are actual measurements the microcontrast (i.e., the 40mm line) in the outer third of the image doesn't look zeiss-like stopped down to f/8, although the center looks excellent. Let's see how the lens performs. My guess from the mtfs is that it will be a very good, but not quite excellent lens, it will be better for portraits (where corner and edge sharpness are less important) than landscapes (where edge to edge sharpness is often important), and the mtfs look promising for bokeh as well. There is a lot you can't tell from an mtf, however.
