Archive 2011 · Fisheye and Barrel Distortion Photos
Gunzorro
p.1 #1 · p.1 #1 · Fisheye and Barrel Distortion Photos
I've recently gotten interested in fisheye effect, after laying off it for about 30 years (Sigma 16/2.8 -- the Canon is much sharper, even wide open).
The effect can be over-used, just like anything else, making it trite and banal.
But I'm sure there are a lot of "bulbous" shots out there that will make us all proud.
Here are a few from today.
Canon 1Ds2, EF 15/2.8 FE, processed in LR3.
http://i25.photobucket.com/albums/c80/gunzorro/036N7943-2.jpg
http://i25.photobucket.com/albums/c80/gunzorro/036N7944-2.jpg
http://i25.photobucket.com/albums/c80/gunzorro/036N7945-2.jpg
http://i25.photobucket.com/albums/c80/gunzorro/036N7947-2.jpg
http://i25.photobucket.com/albums/c80/gunzorro/036N7954-2.jpg
http://i25.photobucket.com/albums/c80/gunzorro/036N7962-2.jpg
Jul 18, 2011 at 01:28 AM
Dan Grisez
p.1 #2 · p.1 #2 · Fisheye and Barrel Distortion Photos
Very cool! #1 and #4 are my favorites.
Jul 18, 2011 at 08:09 AM
Ed Sawyer
p.1 #3 · p.1 #3 · Fisheye and Barrel Distortion Photos
yes, done right a fisheye is a pretty useful lens. I use them for landscape often. If you keep the horizon level and centered, the effect can be pretty subtle, depending on the features of the landscape.
Mainly I use the RZ67 37mm fisheye, which like the canon 15/2.8, is a great sharp lens, even wide-open. A little color fringing on both in the corners, but it's pretty minor.
-Ed
Jul 18, 2011 at 09:18 AM
Gunzorro
p.1 #4 · p.1 #4 · Fisheye and Barrel Distortion Photos
Ed -- Thanks for your input. I agree on the fringing -- I use -30 on the red/green in LR to fix it pretty nicely.
I've always drooled over the FE for the RB67 and the Pentax 67, but never gotten one. I can see definite architectural and landscape uses.
Any advice on good de-fishing software? I use LR, but it doesn't do well (if any) at interpolating the corners/edges, which become excessively soft when stretching in straightening.
Jul 18, 2011 at 10:32 AM
kakomu
p.1 #5 · p.1 #5 · Fisheye and Barrel Distortion Photos
In general, you won't find the corner will do well with defishing software. Most of the time, you'll have to crop, yielding a significantly smaller FoV. It's the nature of the beast considering fisheye lenses tend to compress a lot of data into the corners.
As for defish software, fisheye hemi is pretty good for some uses. It doesn't work well in all situations. It mostly faltered when the camera was close to the camera, or the fishy effect was very pronounced.
You can use PTGui (Paid) or Hugin (free) to defish your images. Both programs have similar GUIs. PTGui is a little more user friendly, but Hugin is free. The big difference is that Hugin uses Panorama Tools, whereas PTGui used to use PT, but has since been rewritten to be stand alone (though, apparently you can still use PTGui as a front end for Panorama Tools).
Here's an example of a photo I took with a fisheye lens that has been defished with PTGui or Hugin (can't remember off the top of my head, but they both perform a similar function). You'll see the original fisheye photo, the defished photo in rectilinear projection at maximum resolution and a crop from the 2nd image.:
http://www.kakomu.com/gallery/imagegallery.php?folder=14
Jul 18, 2011 at 11:04 AM
carstenw
p.1 #6 · p.1 #6 · Fisheye and Barrel Distortion Photos
Wouldn't that be most of the time?
Here is my fishy shot, Nikon D3 w/ Nikkor 16/2.8D:
http://throughthelensdarkly.com/forums/CW_20110407_NikonD3_37300.jpg
Jul 18, 2011 at 03:13 PM
Gunzorro
p.1 #7 · p.1 #7 · Fisheye and Barrel Distortion Photos
kakomu -- Thanks for your examples -- that's pretty much what I've found from LR3 as well. I'll post some soon with some before/after on the de-fishing.
carsten -- Terrific shot! Great color and detail! That's part of my hope too, to get some architecture and twilight use out of the lens. I did find the lens has some minor, but noticable, coma in night shots with stars, but otherwise seems to be quite sharp. You obviously have a good sample.
Jul 18, 2011 at 04:33 PM
Gunzorro
p.1 #8 · p.1 #8 · Fisheye and Barrel Distortion Photos
The fisheye lens can certainly be challenging -- and rewarding! Lots of great uses for landscape and architecture -- dramatic and fun.
Certainly it can be overdone, just like ultra-bokeh and a pin-point of sharpness. But that is the risk with any "alternative" angles of view or focus.
Here are a few shots showing the images in a somewhat altered state. I offer unretouched jpg out-of-camera (resized), examples of the LR3 lens profile with its version of "de-fishing", and more examples of partial defishing done with the manual profile adjustment under Distortion (not completely corrected).
As you will see, any defishing with LR lens profile (turning the image into rectalinear style, with crop) severely impacts the sharpness of the edges/corners, well into the main image. Still, even cropped, the images are extremely wide angle.
All shots at f/8 on 1Ds2.
OOC jpg
http://i25.photobucket.com/albums/c80/gunzorro/036N8266web.gif
LR profile defished
http://i25.photobucket.com/albums/c80/gunzorro/CowboyDogs-8266-2.jpg
Manually adjusted, with PP
http://i25.photobucket.com/albums/c80/gunzorro/CowboyDogs-8266-3-2.jpg
OOC jpg
http://i25.photobucket.com/albums/c80/gunzorro/036N8314web.jpg
PP'ed
http://i25.photobucket.com/albums/c80/gunzorro/CowboyDogs-8314-2-2.jpg
OOC jpg
http://i25.photobucket.com/albums/c80/gunzorro/036N8164web.jpg
Manually adjusted (not really defished, PP'ed
http://i25.photobucket.com/albums/c80/gunzorro/CowboyDogs-8164.jpg
OOC jpg
http://i25.photobucket.com/albums/c80/gunzorro/036N8310web.jpg
LR profile defished, PP'ed
http://i25.photobucket.com/albums/c80/gunzorro/CowboyDogs-8310.jpg
Jul 21, 2011 at 11:12 AM
Gunzorro
p.1 #9 · p.1 #9 · Fisheye and Barrel Distortion Photos
Here's a 15mm FE shot with three options for viewing. Landscape was shot close to a middle horizon, for least distortion.
First is the shot as it comes from camera.
http://i25.photobucket.com/albums/c80/gunzorro/036N9977-2.jpg
Second is slight "de-fishing" by using LR manual distortion adjustment at +100.
Slight PP on shadow areas and cropping due to the inward reverse barrel distortion.
http://i25.photobucket.com/albums/c80/gunzorro/036N9977.jpg
Finally, the auto de-fishing effect of using the LR lens profile.
http://i25.photobucket.com/albums/c80/gunzorro/036N9977-3.jpg
Although distorted, the second version provides an extremely wide angle of view, and viewers/clients may accept the slightly odd look, since it takes in areas that may have importance.
The third de-fished version is obviously lacking in details where it has been stretched in the corners. Perhaps there is software that can interpolate these areas to look sharper?
Jul 31, 2011 at 05:42 PM
kiddik
p.1 #10 · p.1 #10 · Fisheye and Barrel Distortion Photos
Carsten, best use of fisheye I've seen I think
Gunzorro, car photos are great, and furthermore - thank you for giving me an excuse to post a photo from my Zeiss F-Distagon 16mm!
How Graduated Neutral Density Filters Work by Kiddi Kristjáns, on Flickr
This is a 100x150mm Lee Graduated Neutral Density filter held almost directly in front of the glass of the lens. If it weren't for the bent filter, I guess the photo wouldn't pass as a fisheye.
Jul 31, 2011 at 06:42 PM
Gunzorro
p.1 #11 · p.1 #11 · Fisheye and Barrel Distortion Photos
Kiddik -- What a great descriptive photo for grad ND filters! Terrific looking shot.
Jul 31, 2011 at 11:32 PM
carstenw
p.1 #12 · p.1 #12 · Fisheye and Barrel Distortion Photos
Thanks kiddik! Unfortunately I can only think of one such place in Berlin One of these days I will have to just go out with my D3 and the 16mm mounted and see what I get.
That is a pretty unique use for a grad filter! Very neat demonstration.
Aug 01, 2011 at 03:04 PM
Jman13
p.1 #13 · p.1 #13 · Fisheye and Barrel Distortion Photos
I use a fisheye quite a bit. Not enough to dominate my photography, but I use it where it is called for. Here are some of my fisheye shots:
With Panasonic 8mm:
http://www.jordansteele.com/2011/huntington_park-n.jpg
http://www.jordansteele.com/2011/pnc-park.jpg
http://www.jordansteele.com/2011/sage_altar.jpg
http://www.jordansteele.com/2011/statehouse_lines.jpg
http://www.jordansteele.com/2011/statehouse_light_dome.jpg
http://www.jordansteele.com/2011/palace_vert.jpg
With Sigma 16mm filtermatic:
http://www.jordansteele.com/forumlinks/hocking_fish.jpg
http://www.jordansteele.com/forumlinks/mainst_fish_river.jpg
With Sigma 15mm f/2.8:
http://www.jordansteele.com/forumlinks/millrun_waterfall_L.jpg
http://www.jordansteele.com/forumlinks/worthington_bridge_highkey1.jpg
http://www.jordansteele.com/forumlinks/twin_rr_bridges.jpg
http://www.jordansteele.com/forumlinks/worthington_bridge2.jpg
With Tokina 10-17:
http://www.jordansteele.com/forumlinks/basilica_dome.jpg
http://www.jordansteele.com/forumlinks/soldiers_pushing.jpg
Aug 01, 2011 at 03:41 PM
Gunzorro
p.1 #14 · p.1 #14 · Fisheye and Barrel Distortion Photos
Jordan -- Great stuff! I particularly like the second baseball stadium at twilight.
I'm going to try to make it up to Hollywood Universal Studios' City Walk this Saturday night and get some FE shots of their lights and tourist crowds.
Aug 01, 2011 at 06:05 PM
Gunzorro
p.1 #15 · p.1 #15 · Fisheye and Barrel Distortion Photos
Jordan -- Ah! the old Sigma 16mm Filtermatic! I used to have one in the 80s for my Canon film bodies.
I haven't owned one since then, till now.
Shot with Canon 5D.
http://i25.photobucket.com/albums/c80/gunzorro/IMG_0072.jpg
http://i25.photobucket.com/albums/c80/gunzorro/IMG_0067.jpg
http://i25.photobucket.com/albums/c80/gunzorro/IMG_0119.jpg
http://i25.photobucket.com/albums/c80/gunzorro/IMG_0132.jpg
Aug 07, 2011 at 12:50 PM
carstenw
p.1 #16 · p.1 #16 · Fisheye and Barrel Distortion Photos
Three more from me. It turns out that my FM Meet Berlin shots were also largely fisheye shots, and these are the best three, from the government quarter of Berlin.
http://throughthelensdarkly.com/forums/CW_20110806_NikonD3_34.jpg
http://throughthelensdarkly.com/forums/CW_20110806_NikonD3_79.jpg
http://throughthelensdarkly.com/forums/CW_20110806_NikonD3_122.jpg
Aug 07, 2011 at 03:07 PM
deadwolfbones
p.1 #17 · p.1 #17 · Fisheye and Barrel Distortion Photos
Nikon 16/2.8 Ai-s on D700:
http://deadwolfbones.smugmug.com/Other/16mm-f28-FISHEYE/i-gdHnVFT/0/XL/DSC9766-XL.jpg
http://deadwolfbones.smugmug.com/Other/16mm-f28-FISHEYE/i-SVPQkLM/0/XL/DSC9767-XL.jpg
http://deadwolfbones.smugmug.com/Other/16mm-f28-FISHEYE/i-g6fTmRr/0/XL/DSC9772-XL.jpg
http://deadwolfbones.smugmug.com/Other/16mm-f28-FISHEYE/i-SQLKR9s/0/XL/DSC9789-XL.jpg
http://deadwolfbones.smugmug.com/Other/16mm-f28-FISHEYE/i-PpXVW4d/0/XL/DSC9805-XL.jpg
http://deadwolfbones.smugmug.com/Other/16mm-f28-FISHEYE/i-2P8hcgm/0/XL/DSC9823-XL.jpg
http://deadwolfbones.smugmug.com/Other/16mm-f28-FISHEYE/i-gXVxLJm/0/XL/DSC9828-XL.jpg
Aug 08, 2011 at 12:31 AM
Gunzorro
p.1 #18 · p.1 #18 · Fisheye and Barrel Distortion Photos
From tonight.
Canon 15/2.8 FE on 1Ds2. 4 seconds at f/5.6, ISO 400.
Moon and Jupiter, inside ice ring.
http://i25.photobucket.com/albums/c80/gunzorro/036N4253.jpg
Nov 10, 2011 at 01:23 AM
jhg photo
p.1 #19 · p.1 #19 · Fisheye and Barrel Distortion Photos
I will join with two shots from Piazza dei Miracoli, Pisa, Italy.
A serious one from inside the dome
http://www.jhg-photo.de/fm/tosc18446a.jpg
and fish eye fun portrait outside
http://www.jhg-photo.de/fm/tosc18371a.jpg
Both with the Sigma 2.8 15 mm
Nov 11, 2011 at 06:44 AM
jhg photo
p.1 #20 · p.1 #20 · Fisheye and Barrel Distortion Photos
And another two, this time from San Gimigniano, Italy.
The Piazza di Duomo from bottom up (spots are swallows, not sensor dust!)
http://www.jhg-photo.de/fm/tosc18019a.jpg
and the same place from the tower looking down on our small world
http://www.jhg-photo.de/fm/tosc18066a.jpg
Nov 11, 2011 at 06:56 AM
