kbarrera Offline Upload & Sell: Off
When I'm using the sidekick, I'm actually using an L bracket that I custom built to fit the sidekick. The action is much more fluid and smooth, especially with a heavy tripod. I bought the long lens head to use when shooting from the window of my truck. There is no room for a Gimbal with this set-up. I'm not one to go out and buy specialty equipment for specialized purposes. Usually I will go out to my shop and fabricate what I need.
Actually, since I began this thread, I went out to my shop and made a detent pin for the Acratech LLH which prevents the head from moving past 90 degrees. Problem solved. The Acratech, after some modifications is now capable of handling a gimbal and a window mount. It will handle my 500 f/4,and then some. All it took was some drilling, tapping, threading and grinding.
Al
