Archive 2011 · Canon Lens recommendations
steve keating
p.1 #1 · p.1 #1 · Canon Lens recommendations
I recently had a robbery and therefore I need to purchase some new camera equipment and I would like your suggestions on the following lens combinations. I take primarily wildlife and portrait pictures on a full sensor camera body ( 1d mk 2) and I was thinking of getting one of the following 2 combination L series
1) 1 24 -105 lens and a 100-400
Or
2) 1 24 -70 lens and a 70 -200
Or
3) I need more help then you can give and neither of these will do
I would appreciate any recommendations you might have regarding this combination.. Please keep in mind that I also intend to build upon this basic setup as the financial situation improves and will be also be getting a backup camera body probably one that is not full frame and a flash etc… so if you have the time, I would also appreciate any recommendations you have on these well.
Thanks
Jun 30, 2011 at 08:41 AM
Jonathan Huynh
p.1 #2 · p.1 #2 · Canon Lens recommendations
For full sensor camera body . 24 -70 and 70 -200 .
Jun 30, 2011 at 08:45 AM
Kenneth Farver
p.1 #3 · p.1 #3 · Canon Lens recommendations
I had the 24-70 on my 1D MKIIN but moved to the 24-105 for the 5D MKII.
Figured the 1.3 crop vs. FF that the 24-70 wouldn't have the reach.
Picked the 5D and 24-105 for a vacation camera as it drew less attention than the 1D and 24-70 F2.8
I never liked the 5.6 on the 100-400 so I had the 70-200. You may want the reach of the 400 though.
Jun 30, 2011 at 08:46 AM
timbop
p.1 #4 · p.1 #4 · Canon Lens recommendations
for wildlife the 100-400 is a gem, although for portraits the 70-200 is the cat's meow. Consider the following, as it gives you a really nice portrait lens, wildlife lens, and a wide-short tele option for about the same money: 100-400, tammy 28-75, and 85/1.8 or 100/2
Jun 30, 2011 at 09:36 AM
rachelsdad
p.1 #5 · p.1 #5 · Canon Lens recommendations
I like option 1 with the 24-105 being a great portrait lens and the 100-400 giving you some reach. Steven
Jun 30, 2011 at 09:40 AM
Jos Tesseract
p.1 #6 · p.1 #6 · Canon Lens recommendations
70-200 is a definite must.
I've been not saving for a 24-70... I need to get back on track with that. The 24-70 is pretty much the defacto Journalism lens. Very versatile.
The 70-200 F4L is my go-to lens... mainly cause it's my best, but mainly because its unbeatable in its versatility.
I snapped this at Detroit's Electronic Music Festival "Movement", this is Fatboy Slim at the end of his set. I was about 100-150 feet away for this shot (at least)
http://farm4.static.flickr.com/3447/5795112076_4e9201aa32_z.jpg
Jun 30, 2011 at 09:47 AM
kakomu
p.1 #7 · p.1 #7 · Canon Lens recommendations
What were your previous lenses before the robbery?
Jun 30, 2011 at 09:49 AM
DLP
p.1 #8 · p.1 #8 · Canon Lens recommendations
24-70
70-200
Jun 30, 2011 at 10:32 AM
tanglefoot47
p.1 #9 · p.1 #9 · Canon Lens recommendations
I use my 100-400 much more than the 70-200 but my style of shooting is wildlife and need a long lens. But the lens I really miss is the 70-200 2.8 IS MKII I now have the non IS and it's a fantastic lens but once you had the taste of the MKII not another 70-200 can touch it
Jun 30, 2011 at 10:36 AM
StarNut
p.1 #10 · p.1 #10 · Canon Lens recommendations
I have the 24-105, the 70-200 f/2.8 IS II, 1.4x II and 2x II.
If you're only going to pick one from column A and one from column B, I can endorse this as a very reasonable compromise. As you save more pennies, you can get a longer lens.
Just food for thought.
Jun 30, 2011 at 10:50 AM
retrofocus
p.1 #11 · p.1 #11 · Canon Lens recommendations
24-70 for portrait, 70-200/4 IS for the rest (you can add later an used 1.4x teleconverter II for more reach if necessary).
Other option might be 17-40/4 (landscapes), and 85/1.8 (portraits), and 100-400.
Jun 30, 2011 at 11:57 AM
Patrick Cox
p.1 #12 · p.1 #12 · Canon Lens recommendations
Mike, did you sell the Mk II? I thought you were going to hold onto that one!
Jun 30, 2011 at 12:30 PM
Ian.Dobinson
p.1 #13 · p.1 #13 · Canon Lens recommendations
nope he sold it his got a gear bag lined with TEFLON
Jun 30, 2011 at 12:33 PM
schlotz
p.1 #14 · p.1 #14 · Canon Lens recommendations
If you are hand holding, the 25-105 IS comes in handy for obvious reasons. If most or the majority of your work is using a tripod then I would pick the 24-70. While the 100-400 is very versatile it has its limits dealing with light and speed in the field. The 70-200 is a workhorse but depending on what wildlife you are shooting may be too short in reach. As usual, welcome to photography and the world of compromise.
Regards,
Matt
Jun 30, 2011 at 12:56 PM
adamrose13
p.1 #15 · p.1 #15 · Canon Lens recommendations
for wildlife... 200mm is not enough.
Jun 30, 2011 at 01:02 PM
Jeff Nolten
p.1 #16 · p.1 #16 · Canon Lens recommendations
Your option 1 are my most used lenses. The 24-105 is the best general purpose lens I've used. The 100-400 usually lives on a 7D but I often use it traveling on a 5D with great results. I think it makes a decent portrait lens to supplement the 24-105. When you get out beyond 100 mm or so a relatively shallow DOF doesn't require a fast aperture. Add some specific primes as you can afford them.
Jun 30, 2011 at 01:58 PM
Dragonfire
p.1 #17 · p.1 #17 · Canon Lens recommendations
I purchased the 24-105L IS for the 1DsIII and the lens is amazing, sharper and much less barrel distortion than the 24-70L I use on the 1DIII.
24-105L IS and 100-400L IS would be my choise.
Jun 30, 2011 at 02:12 PM
steve keating
p.1 #18 · p.1 #18 · Canon Lens recommendations
First I want to thank everyone for there input. After reading everyone's input and talking to other people My thought is to get the 24-105 and the 70 - 200 2.8 now with the 2x extender and that will basically give me what the 100 -400 does but with the versatility. The general consensus is that the new 70-200 IS 2.8 lens is a fantastic lens in everyway.
Jun 30, 2011 at 02:21 PM
steve keating
p.1 #19 · p.1 #19 · Canon Lens recommendations
My previous lens was a 24 - 105 and 28-300 that I purchased as I was doing a lot of traveling and only wanted one lens to deal with. Afterwards I purchased the 24-105 as the 28-300 is abit heavy and cumbersome
Jun 30, 2011 at 02:24 PM
oldrattler
p.1 #20 · p.1 #20 · Canon Lens recommendations
For wildlife it would seem #1 is the best chose...
Jun 30, 2011 at 02:27 PM
