Archive 2011 · Dry & gray rubber on Focus Ring?
beauport
p.1 #1 · p.1 #1 · Dry & gray rubber on Focus Ring?
I didn't see anything on this so I thought I'd ask. I pulled out my 35L which I haven't used in a while and the focus ring is not the usual black but a few shades lighter of gray. Had it not been sitting peacefully in a dark closet I'd suspect it had been subject to a lot of sun or heat. Regardless, do any of you use any product on the rings to keep them from drying out and discoloring?
Thanks.
Edit - found a suggestion that worked. Simply took an old clean toothbrush (dry) and scrubbed the rubber ring in the direction of the ridges and the gray went away.
May 08, 2011 at 04:13 PM
BrianO
p.1 #2 · p.1 #2 · Dry & gray rubber on Focus Ring?
beauport wrote:
...Simply took an old clean toothbrush (dry) and scrubbed the rubber ring in the direction of the ridges and the gray went away.
Yep, that's a good remedial action, and one I have suggested here from time to time.
For prevention, I like a small amount of 303 Protectant.
May 08, 2011 at 08:44 PM
Gochugogi
p.1 #3 · p.1 #3 · Dry & gray rubber on Focus Ring?
Wish that technique worked on me. Dad burn fountain 'o youth!
May 08, 2011 at 08:58 PM
eos-m42guy
p.1 #4 · p.1 #4 · Dry & gray rubber on Focus Ring?
More suggestions here:
https://www.fredmiranda.com/forum/topic/986311/0?keyword=rubber#9357941
... Don
May 08, 2011 at 09:06 PM
