waybourn Offline Upload & Sell: Off
p.1 #16 · 645D Review - 2nd Impressions and a longer play | |
Canon 5DII (left) and Pentax 645D (right) Comparison.
Ok, what I did isn't all that scientific, but I set up both cameras with as similar lens (85mm on the 5D and 55mm on the 645D), same tripod, same distance, same format (RAW) same lighting (available), same exposure, etc., wherever possible.
At first glance, the 5DII image on the left appears to hold its own with the 645D, but only until you increase the size does the difference become so apparent. As it should, obviously the strength of the 645D pixels far surpass those in the 5DII. Is it worth $5000, I can't say. If you are going to print large images, then the 645D is a no brainer.
There are other areas where the 645D really outscored the 5DII, again just as it should. The one surprise was on the back of the camera. I presume both cameras use jpgs for review copies, and the review images in the 645D were "right on" re the actual color of the statue whereas I had to guess at the color in the 5DII, as it was not reflective of the actual color. That probably saved me some time, as I trusted the 645D's reading more quickly than the 5DII and took half as many shots.
You have to decide for yourself. I love my 5DII and won't be selling it, but I have to say shooting with the 645D is a dream. After this test, I position the 645D for a quickie self-portrait and you can see how it performed.
