2 end
Archive 2010 · Ski camera bag suggestion
sunpole
p.1 #1 · Ski camera bag suggestion
Hi,
I am searching for a backpack for ski slopes. I am only planning to bring 5D2 + 24-105 or maybe another short prime like 35, 85 or 100.
Nothing else, more important I don't want it to get in my way with skiing. So compact size is a must. I am considering lowepro fastpack 100 or flipside 200, what do you think?
Currently I have the flipside400 and I like it, but too big for my purpose.
Any tips would be appreciated.
Thanks.
Feb 28, 2010 at 04:32 AM
Roger.Hong
p.1 #2 · Ski camera bag suggestion
I think you're ballsy as hell bringing that kind of equipment up the slopes and risk damaging them. But then again odds are you're a way better skiier than I am and won't wreck it in a yard sale.
Feb 28, 2010 at 06:19 AM
sunpole
p.1 #3 · Ski camera bag suggestion
lol I usual go easy on a slope when carrying equipments. I think with some proper protection, they should be fine. But that brings up a good point, cushion should also be a point for consideration.
I am leaning towards sling bags, since it let you switch the bag the front easily without taking off your shoulder.
And did some more research, now my decision is either on Velocity 6 and 7 for ultimate portability or Kata 3in1-10 for some spare capcity and maybe better cushion?
Feb 28, 2010 at 06:31 AM
Todd Warnke
p.1 #4 · Ski camera bag suggestion
I tried a Velocity a couple of years ago and really didn't like it for that use. For me an easy to slip on and off backpack works best - easier to ski with, not much more hassle to get into, and better protection in the standard fall.
Peace,
Todd
Feb 28, 2010 at 06:46 AM
sunpole
p.1 #5 · Ski camera bag suggestion
So you don't really like the sling idea for this use? or just the velocity series in particular?
What do you think about the Kata bag vs. Lowepro flipside 200?
Feb 28, 2010 at 07:05 AM
Dpic_arctic
p.1 #6 · Ski camera bag suggestion
I cross-country ski regularly with the Lowepro Micro Trekker 200. It works great for cross-country skiing, but I've never gone downhill skiing with it. It can be "mounted" on you very securely, and it has a small profile.
Feb 28, 2010 at 07:17 AM
Bifurcator
p.1 #7 · Ski camera bag suggestion
Same here. I never fall.
I just tuck mine inside my powder jacket though. Strap around the neck, no extra lenses. That way I can get it out fast when someone awesome is in the 1/2 pipe or speeding over the moguls. If I had it in a bag or pack I would pretty much be limited to lift shots and shooting trees. I've found that even a lens cap is slow and difficult to deal with on the slopes - let alone a bag or pack.
Feb 28, 2010 at 07:37 AM
sunpole
p.1 #8 · Ski camera bag suggestion
yea but I use 5D2, it is not weather proof. While I don't really fall, but I don't like get my gear scratched for whatever reason. I usually shoot staged shots or sceneries. But i'd be nice to snap whenever there is some nice actions.
Micor trekker 100 looks like a good fit to me. Wonder how long does it take you to get your gear out of that bag, and do you find it is a hassle to take off your bag "snap" put it back in, etc?
Feb 28, 2010 at 08:02 AM
Todd Warnke
p.1 #9 · Ski camera bag suggestion
My issues with the Velocity were partly due to the design itself. I found that the radiused design made it somewhat less efficient for a given size than other slings, so the Velocity I ended up with had a significantly larger external shape than the slings I have from other makers. That made it a bit less convienent and bit heavier. Plus, when I rotated it, it always seemed too high and tight on my body to comfortably use. OTOH, riding high like that made it pretty easy to use while actually skiing as it rode on my back without much movement. Still, adding it all together I realized that it was only marginally quicker to get into than a well designed pack, less stable and less efficient, and so I switched back to a pack.
Peace,
Todd
Feb 28, 2010 at 05:43 PM
gfiksel
p.1 #10 · Ski camera bag suggestion
I don't care about the camera or the lens. It's what they could do with your ribs if you fall hard enough....
Feb 28, 2010 at 10:47 PM
hfgarris
p.1 #11 · Ski camera bag suggestion
Perhaps a Think Tank "Change Up" or "Multimedia" bag worn in the chest-pack configuration?
-howard
Mar 01, 2010 at 03:01 AM
Bifurcator
p.1 #12 · Ski camera bag suggestion
Well, i've brought good equipment up like that hundreds of times. Never any scratches and the (zipperless) powder-jacket stays cold so nothing fogs up. I used to work on the slopes once upon a time. In Utah (Park City and Snowbird) and in California (Snow Summit, and Goldmine).
Against my chest I have full control (with my pecks) to keep the camera in a solid position where it won't swing around and etc. It's as safe as a new-born baby in it's mother's arms.
The main problem with a bag/case is the gloves. You want to be able to get the camera to your face, half-press and snap all without taking off the gloves. Taking off the gloves has a strong tendency of fogging up the lens - breathing too much too.
With a powder jacket you just lift it up over the camera, grab the camera, and you're in business.
Not meant as a put-down but if someone is so lame that they still fall (even occasionally) then they should either go up and down on the lift/gondola or leave the camera down the hill - but shouldn't be skiing with their equipment. Even a great skier will have the good sense to take it really easy if they've got a camera with them.
Anyway, sunpole, sure, try bags and stuff if you can work out a nice system and feel secure with it.
Mar 01, 2010 at 04:11 AM
sunpole
p.1 #13 · Ski camera bag suggestion
thanks for all the suggestions. Going to try the powder jacket before buying this backpack...
Mar 01, 2010 at 05:30 AM
Bifurcator
p.1 #14 · Ski camera bag suggestion
Here's what I was talking about (basic style) in case you weren't sure:
Anyway, this is the general idea. This image is kinda lame and I think this one is a girl's but I guess you get the idea.
These go for $30 ~ $150 depending.
Mar 01, 2010 at 05:42 AM
Steezus
p.1 #15 · Ski camera bag suggestion
Bifurcator, what was your job at the resorts? I use to operate snowcats at Deer Valley for a while and one year doing the same thing at Alta. Best job I ever had.
I would look into the Dakine Mission pack for your ski stuff. It is built to hold a snowboard, but it hugs your body well enough to carry a lot of heavy photo gear and still be able to be maneuverable on the trails. I love it and it isn't that expensive. If you were going to get into the back country, the snowboard lashing would double as an avy shovel holder as well.
Mar 01, 2010 at 09:19 AM
rugby49
p.1 #16 · Ski camera bag suggestion
A few years ago I was looking for the same type bag. Eventually I went with a messenger bag and used a Billingham insert in it. The advantage I found with the messenger bag is it naturally made to swing onto your back/side. Real easy to rotate to the front and open. I was carrying a 20D, now 7D, and 1 or 2 lenses. When I get on the lift it just swings around to the front. Works quite well and the Billingham insert has sufficient padding
Jim Kelly
Mar 01, 2010 at 09:50 AM
LDR99
p.1 #17 · Ski camera bag suggestion
I ski a lot with camera gear, and have tried lots of different bags. What works by far the best for me is a LowePro Top Loader worn in front and clipped with carabiners to the D rings on the front of the shoulder straps of my small, ski specific back pack that I always wear. I have three Top Loaders (small 65, medium 70, and large 75). The 65 is too tight for a 1D size camera but works well with a 5D. My "go to" set up is Top Loader 70 with a 1D3 and a 70-200 F4. I will add a third carabiner to the bottom of the bag clipped to my back pack's waist belt when I am skiing aggressively and it keeps it from swinging out on the bumps.
Wearing the bag in front clipped to the straps creates a nice counter balance with the back pack carrying my usual back country gear. I have the camera bag with me lift skiing inbounds and back country skiing.
The beauty of the system is the TopLoader's top zips open away from you giving quick access to the camera. It even creates a bit of a shelf on your chest if you need to fuss with the gear. Good size pulls on the TopLoader allows me to open and close with large gloves on.
This really is a good system FOR ME! I have recommended it to everyone that skis. Some love it. Some hate it. Some think it is crazy to ski with gear on your chest. For me it is the most natural feeling, least restrictive set up I have found. I ski hard and fast in all conditions and on all terrain and I have the gear with me always and I love this system. But it might not be for everyone. YMMV.
Lorin
Mar 01, 2010 at 08:46 PM
LDR99
p.1 #18 · Ski camera bag suggestion
Here are two lousy shots with lots of noise, but you can see the bag set up.
Works for me.
Sorry--Can't seem to get the photos to load. It's been a while since I have posted photos. I need to give myself a tutorial. Will try again later.
Lorin
Mar 01, 2010 at 08:54 PM
LDR99
p.1 #19 · Ski camera bag suggestion
Another try:
I give up! My image doesn't load. I'm stumped.
Mar 01, 2010 at 09:03 PM
LDR99
p.1 #20 · Ski camera bag suggestion
Another try:
Mar 01, 2010 at 09:15 PM
LDR99
p.1 #21 · Ski camera bag suggestion
It works!
Mar 01, 2010 at 09:16 PM
tanglefoot47
p.1 #22 · Ski camera bag suggestion
How about a Dakine mission photo I have one and love it and it's made for people who do snow boarding
Mar 01, 2010 at 10:11 PM
rjk55425
p.1 #23 · Ski camera bag suggestion
Sounds strange but I prefer a fanny pack. I hate to think about falling on a rig strapped to my back. Plus you have to take it on and off with lifts plus you can't get to it quickly when you might want to shoot. My pack will carry a large gripless body and I will occasionally take a 24-70. Still a smaller prime is the way to go. Lately have been taking D700 and 60 AFS macro.
Mar 02, 2010 at 01:10 AM
sunpole
p.1 #24 · Ski camera bag suggestion
LDR99 wrote:
Another try:
Like it how you are carving the snow...
What do you use to secure the bottom of the toploader? What do you use to prevent it moving up and down?
Mar 02, 2010 at 01:12 AM
LDR99
p.1 #25 · Ski camera bag suggestion
Thanks. IMO, that's the highest compliment you can give to an old school skier.
You can barely see in the first picture, but there is a third carabiner that hooks the bottom of the bag to the waist belt of the back pack. It keeps it from bouncing (and from falling into your face when you are doing up the bindings). That's all that I have needed.
Probably not for everyone. But a great system for me.
Lorin
Mar 02, 2010 at 01:21 AM
2 end
