2 end
Archive 2010 · Things that can go wrong
Zenon Char
p.1 #1 · Things that can go wrong
I have posted a few threads on lighting preparing for a few weddings. I've been doing night shots outdoors, indoor shots, outdoor in overcast (on Saturday) in full manual, AV mixing up putting the flash on ETTL and Manual. I'm even setting color temperatures for the light conditions. I'm getting planned, repeatable results which is my goal.
Today was sunny and warm so I decided to go out start checking out fill flash. I had no people but you can work work objects. I would do two shots, one without flash and one with. Every flash shot I took was nuclear. A person would have gone blind.
So I got home and for hours I'm trying to figure out what went wrong. Finally I got it. I was in AV and when I metered my shutter speed was at 1/640 with the flash off. Then the second shot which lit the city was at 1/200. In DPP it does not show if I had HSS on or off but I can only predict it was off. It had to have been on off. The only reason I am posting this is I don't recall seeing the meter change but it must have. It should have correct? I took about 20 sets of images and they were all the same. Maybe I was not paying attention because I had the first exposure set.
I'm glad this happened. Good to make these mistakes now. Anyway I'm going to go out tomorrow again.
Feb 09, 2010 at 03:08 AM
BrianO
p.1 #2 · Things that can go wrong
Zenon Char wrote: Today was sunny and warm so I decided to go out start checking out fill flash. I had no people but you can work work objects. I would do two shots, one without flash and one with. Every flash shot I took was nuclear. A person would have gone blind.
What metering mode were you using? (Matrix, center-weighted, etc.)
Zenon Char wrote: ...So I got home and for hours I'm trying to figure out what went wrong. Finally I got it. I was in AV and when I metered my shutter speed was at 1/640 with the flash off. Then the second shot which lit the city was at 1/200. In DPP it does not show if I had HSS on or off but I can only predict it was off.
Yes, it was probably off, so the camera defaulted to the max sync speed of 1/200. If you didn't change the aperture that would result in overexposure.
For fill flash outdoors or in large spaces one trick that will help is to set the meter for the smallest area your camera is capable of, center the subject in the frame, and press the FEL (flash exposure lock) button. The camera will fire a metering flash and lock it in, then you can recompose to put your subject wherever in the frame you want him or her, and when you take the shot the flash will fire with the predetermined power, rather than trying to light up whatever is now in the center of the frame.
I also usually dial in -1/3 to -1/2 FEC (flash exposure compensation) when shooting outdoors, because I think it gives a more natural, less "flashed" look to people pictures.
BTW, with High Speed Sync, you can leave it on and if your shutter speed is at or below sync speed it will fire normally, only going into HSS mode if your shutter speed goes over sync.
Feb 09, 2010 at 04:59 AM
Zenon Char
p.1 #3 · Things that can go wrong
Spot for this one but I use both evaluative (matrix) or center.
I'll give the FEL a try.
When I did my weekend test and todays I did have it set between -1 and -2 but I'll try - 1/2 as well.
Feb 09, 2010 at 05:26 AM
cgardner
p.1 #4 · Things that can go wrong
You said the flash was "nuclear" but actually it was the ambient light at 1/200th which was the culprit in the over-exposure more than the flash.
As Brian suggests the best strategy for setting flash outdoors is to just leave it in high speed mode and let it switch as needed.
To avoid surprises in flash power when the flash slips into high speed mode use the camera in M mode not Av. That way you will know for certain whether you are below sync limit or not at all times. With all that snow correctly exposed highlights are a no brainer if you simply use the overexposure warning in the playback to tell you when and exactly where clipping is occurring in both the ambient background and the flash lit foreground.
What you did do ideally in the shots is shoot into the shadow side of the ambient. Flash can't reduce contrast if it overlaps sunlit highlights. But to avoid a flat look in the fill you need to raise the flash above the camera on a bracket. Its a perceptual thing. Because we see things lit from above most of the time we consider a downward angle / pattern to be more natural. The fill from the sky comes from overhead and to get a seamless match of natural and artificial you'll want the angles of both to be similar. Its particularly important in portraits for creating natural looking 3D shape on the face.
Feb 09, 2010 at 12:17 PM
Zenon Char
p.1 #5 · Things that can go wrong
I use it in M mode when the flash is the main source. I put it in AV for fill flash. Without flash I always shoot in AV as it saves me using two adjustments to meter for ambient. I guess I'm a little lazy but I certainly have learned the benefits of manual in the last month. I recently purchased the RRS wedding bracket which I will use. I use all there plates and quick release clamps.
Well I'm going to head out to that post again today if it is sunny and try in both AV and M. All in prep to shoot people in about 6 weeks when everything warms up.
Feb 09, 2010 at 01:38 PM
Zenon Char
p.1 #6 · Things that can go wrong
Sorry had to drive my wife to work. I did see that overexposure warning was blinking on other shots as well. I tried everything and nothing made sense. I powered the flash down to 1/128 in M, - 3 on ETTL. I should have been a little quicker on my feet. Today I'll take my sunglasses off so I can see what I'm doing. Bright outdoor light bugs me. They will definitely be off for an important shoot. I'm glad this happened. Better now.
Feb 09, 2010 at 02:17 PM
cgardner
p.1 #7 · Things that can go wrong
See my tutorial on high speed flash (click the WWW button).
What I've found with Canon evaluative metering for flash is that it expects the ambient highlights to be below clipping. That makes sense because if the ambient is already clipping the highlight then adding flash will clip them more.
Conventional wisdom for outdoor portraits when the subject's back is to the sun is the let the hair become a nuclear halo, but that's exactly what throws off the flash metering. What I do when shooting in Av mode with flash is use the OEW to get the ambient highlights below clipping first before adding flash which in backlight usually requires about -2 EC because exposing for the highlight detail on the backlight subject doesn't match what the metering algorithms are programmed to expect.
But once the ambient is reeling in below clipping with the minus 2 EC the flash evaluative flash metering performs quite brilliantly at the default FEC = 0 setting.
Something else not mentioned in the thread is ISO used. Outdoors in bright light you want to use ISO 100. Higher ISO make it more difficult to keep the ambient highlights below clipping.
Manual is always better when using flash outdoors because it eliminated the variable of the camera's control of the ambient part of the exposure mucking up the works. Sunlight is very consistent. Its really just as easy to put the camera in M, pick the f/stop desired for DOF, then adjust shutter speed to get the background below clipping. Its just a matter of turning a wheel, just as done with EC, to arrive at the same result.
When using high speed flash in Av mode its better to shoot at wider apertures due to the power drop. For example if shooting at f/11 in conventional mode flash range will be significantly reduced if you simply open a stop to f/8 and trigger the shift to high speed mode. Better to open to f/4 or f/2.8 where the drop in flash performance will be offset by the fact not much flash power is needed if shooting at f/2.8
Its just a matter of understanding how the different pieces of the exposure puzzle fit together.
Feb 09, 2010 at 05:50 PM
Zenon Char
p.1 #8 · Things that can go wrong
Thanks. I just book marked your tutorial. I had better day today. Before I went out I checked my 5D2 C.Fn. In C.Fn 1.7 I had it on 2. 1/200 to 1/60 Auto. It is do to with low light. I put it back to 1: Auto before I went out. Not sure if that effected me yesterday but I more than likely did not have HSS on.
I shot in AV but will shoot in M next time. I started to post something but I found something interesting. If I don't do a pre fire will the camera adjust my shutter speed on it's own on AV? If it does this changes everything. Is this what you all have been trying to tell me? I did not change any settings except turn the flash on. Look a the changes in shutter speed. Only when I pre fired did it go lock to the ambient reading. I had it at ISO 100 and Spot Meter. I checked my focus point and it was consistent between shots.
By the way thanks for everyones help on this. I'm very grateful.
Without flash - 5.6 - shutter = 400
With flash - 5.6 - shutter = 320 - no pre fire
Second shot with flash - 5.6 = shutter = 500 no pre fire
With flash - 5.6 - shutter = 400 with pre fire. I did a few in a row with pre fire and the shutter was consistent.
Feb 09, 2010 at 11:03 PM
Zenon Char
p.1 #9 · Things that can go wrong
You probably were wondering what I was talking about. I messed myself up and it was due to the focal length change and the flash. Separate issues. Even without the flash on, if I had been paying attention to the shutter speed between shots I would have seen the difference in shutter speeds.
Once I set up my first shot I never checked the second or third one. I thought because I was in spot it should have been the same but spot metering is not pin point and I was changing focal lengths due to lens creep while chimping. I have always known as soon as you move your camera over even a bit and press the shutter button the shutter speed changes.
Then I started wondering what was my camera was doing? I thought it was making adjustments on me during exposure. When I set up in AV and let's say it is F 5.6 and the shutter is 400 I never check to see if it recorded those numbers I had seen in the viewfinder. I just check the histogram. Viewing them at home I was expecting the shutter speeds to be the same and they were not so it threw me off.
Someone pointed out this NEVEC to me which probably did not help.
http://eosdoc.com/manuals/?q=NEVEC
Edited on Feb 11, 2010 at 06:14 AM · View previous versions
Feb 11, 2010 at 04:50 AM
rogie
p.1 #10 · Things that can go wrong
this was my concern in a previous post about hss only turning on after the camera has exceed max sync speed. also, what is the difference between the flash symbol with the H and the triangular arrows pointing right in hss mode? i have found that i am only able to achieve hss fp with the arrow symbols.
Feb 11, 2010 at 05:46 AM
BrianO
p.1 #11 · Things that can go wrong
rogie wrote: ...what is the difference between the flash symbol with the H and the triangular arrows pointing right in hss mode? i have found that i am only able to achieve hss fp with the arrow symbols.
You should have HSS when the H symbol is lit. I don't know why it's not working for you.
Feb 11, 2010 at 06:28 AM
rogie
p.1 #12 · Things that can go wrong
i have my camera set to second curtain sync. is this why?
Feb 11, 2010 at 06:36 AM
BrianO
p.1 #13 · Things that can go wrong
rogie wrote: i have my camera set to second curtain sync. is this why?
Yes. If the camera is set to 2nd curtain sync then the flash must also be set to 2nd curtain sync, because the camera won't be sending a first curtain sync signal.
(I always use 2nd curtain sync. At high shutter speeds it makes no difference, but at low shutter speeds any ghost trails will follow a moving subject naturally. So I just leave it on all the time so I don't have to remember to change it.)
Feb 11, 2010 at 06:46 AM
rogie
p.1 #14 · Things that can go wrong
so in order to achieve the hss fp i must turn off second curtain sync in camera and switch flash to the H symbol? or does it still give the same hss fp with second curtain sync mode on flash but the only difference being that i might get ghosting trails at lower shutter speed. is this correct? the only differentiator between the two modes is the method of exposure?
Feb 11, 2010 at 07:43 AM
BrianO
p.1 #15 · Things that can go wrong
rogie wrote: so in order to achieve the hss fp i must turn off second curtain sync in camera and switch flash to the H symbol?
You know, I've never tried using HSS and 2nd curtain sync at the same time. I don't know if it's possible or not. I suspect not.
rogie wrote: ...or does it still give the same hss fp with second curtain sync mode on flash but the only difference being that i might get ghosting trails at lower shutter speed.
When using high speed sync or any other "continuous" light source (including the sun) you won't get a sharp image plus ghost trails; you'll just get motion blur. That's because the subject will be equally lit in all positions.
Feb 11, 2010 at 07:53 AM
rogie
p.1 #16 · Things that can go wrong
according from what i was doing last night (experimenting with hss), i dont remember getting anything above 1/250th in hss mode with second curtain sync enabled on camera. ill check again tonight just to make sure when i get out of work.
Feb 11, 2010 at 07:58 AM
BrianO
p.1 #17 · Things that can go wrong
rogie wrote: ...i dont remember getting anything above 1/250th in hss mode with second curtain sync enabled on camera. ill check again tonight just to make sure when i get out of work.
In order for both to be active, you'd need to see both the H icon and the triple-triangle icon at the same time.
I don't think that's possible.
Feb 11, 2010 at 08:09 AM
wickerprints
p.1 #18 · Things that can go wrong
HSS and SCS are intrinsically incompatible. HSS works by repeatedly firing the flash in rapid succession while the curtains travel across the frame. As such, it is only effective for exposures faster than the x-sync speed. The HSS setting is ignored at or below x-sync.
SCS works by firing the flash just prior to the closure of the second curtain, rather than immediately after the opening of the first curtain. Thus it only applies to exposures slower than the x-sync speed, since if the shutter speed is faster, the second curtain has already begun to close before the first curtain has fully opened.
Feb 11, 2010 at 08:44 AM
BrianO
p.1 #19 · Things that can go wrong
wickerprints wrote: HSS and SCS are intrinsically incompatible.
...SCS works by firing the flash just prior to the closure of the second curtain, rather than immediately after the opening of the first curtain. Thus it only applies to exposures slower than the x-sync speed, since if the shutter speed is faster, the second curtain has already begun to close before the first curtain has fully opened.
Why would that make HSS incompatible? HSS always works when the shutter curtains are chasing each other in a slit; that's the whole point of HSS. Even with first curtain sync, at any speed above normal sync the second curtain begins to close before the first curtain has fully opened.
If HSS didn't start firing until the first curtain was fully open -- which is what 1st-curtain sync does -- then you wouldn't get complete coverage of the frame at 1/500 to say nothing of 1/8000.
Feb 11, 2010 at 09:14 AM
wickerprints
p.1 #20 · Things that can go wrong
I'm not talking about HSS in that paragraph. I'm talking about SCS, and explaining why it cannot be implemented when the shutter speed is faster than x-sync. In such a case, the second curtain has already begun to close before the first curtain is fully open, which means there is no way to fire the flash once without causing uneven exposure. You could fire it multiple times as in HSS but then you can't call it SCS anymore, since in order to get even exposure, you are firing the flash before the first curtain has even had a chance to expose the entire frame.
My point is that HSS is unnecessary when slower than x-sync, and required faster than x-sync, whereas SCS can only occur slower than x-sync, and would result in uneven exposure when faster than x-sync. The two can't be combined in any meaningful way.
Feb 11, 2010 at 10:29 AM
rogie
p.1 #21 · Things that can go wrong
YES! i understand this now. ok im home now and threw the 580 on the 1dii and turns out when in second curtain sync, it wont go past max sync speed however with H mode it will. during the hss the second curtain will follow the first while the flash is spitting out multiple pulses to even out the exposure where as with scs, the first curtain fully opens, flash fires and second curtan follows after. limiting this operation to shutter speeds only slower than max sync of the camera...correct?
Feb 11, 2010 at 03:01 PM
cgardner
p.1 #22 · Things that can go wrong
On a 580ex High Speed and Second Curtain are set with successive presses of the same button which has three modes:
• Off (normal single burst sync as sensor is fully exposed)
• High speed FP sync
• Second curtain (single burst while shutter is fully exposed, just before end of the exposure).
Thus it is physically impossible to enable high-speed sync and second curtain sync on the flash at the same time. Secondly, second curtain, like normal sync, because it is a single burst mode and is subject to the same sync speed limit as normal flash.
Second curtain is typically used in situations where where the shutter can be dragged for 1-2 sec., giving a subject moving linearly across the frame time to create the blur trail behind the subject against a sharp background before the shutter freezes the foreground action. The problem with second curtain is the opposite of x-sync: getting long enough shutter times in the range of (1-2 sec. needed) to create the blur. Getting the shutter that slow requires a darken room indoors, or the use of ND filters on the lens.
An alternative to second curtain to achieve a similar illusion of motion in a still photo is panning the camera, which can be done without flash. It is a technique used for photographing fast moving objects like race cars. The difference vs second curtain is that the background is blurred, which is an effective way to isolate the foreground from the background clutter.
If shooting a waiter carrying a tray of food across a crowded room where the context of the background is important then second curtain would be the most effective technique. On the other hand if you wanted to convey the waiter as a cool and calm amidst the chaos of the crowded space you might instead choose to pan the camera, with or without second curtain flash, so the waiter is isolated on a blurred background. Start with the goal for the message of the shot, the then apply the technique most effective at creating the underlying perceptual reaction which will convey it.
Zenon:
With regard to your latest set of tests they all look artificial for two reasons: 1) the foreground is brighter than what would be seen by eye in similar lighting, and 2) the direction of the flash fill is flatter (coming form a lower angle) than the natural lighting.
To get results which appear more natural start with an ambient only shot which is exposed for the background. It will make the foreground darker than perceived by eye because the camera sensor can't handle the contrast, but you will be able to see the pattern the natural fill light from the OVERHEAD skylight. What you then need to do is just add enough flash to bring the shaded side up to the level you perceived by eye (i.e. the baseline for normal) while at the same time retaining the direction of the natural fill from the sky. You need to raise the flash on the camera so its angle is more similar to the downward direction of the sky fill to avoid the flash creating a flat looking foreground.
I did the edit below in Photoshop from your last photo (right) to show how would need to be illuminated with the raised frontal flash to make in more natural; like the ambient only shot fill direction, only brighter to overcome the physical limit of the sensor:
The biggest difference in the edit is the darkening of the gap between the posts which by virtue of the flat near axis lighting sends the clues that the lighting is artificially low, not naturally downward.
Its a matter of developing the ability to see past the physical limits of the camera to pre-visualize the final desired result using the natural fill lighting from the sky as the foundation and augmenting it, not overpowering it, with the flash to the point were what the camera records (and what you can do in Photoshop) matches what was perceived by eye. That's straight out of the Ansel Adams playbook, but with a new twist: using flash, not negative development, to match scene to final image.
Feb 11, 2010 at 04:20 PM
Zenon Char
p.1 #23 · Things that can go wrong
That does look better much better. I'm familiar with raisning the flash techinque. How will this look when there is a bride there instead of the piers. How would I meter for skins tones when using fill flash?
I have been finding all types of information on this. No need to answer unless you want to. It is very welcomed. This was not covered in detail in my class. I understand the concept metering for ambient, flash for subject and have done it succesfully but with objects which have more latitude. I want to make sure when people are involved I'm getting the ambient and flash exposures correct.
Edited on Feb 11, 2010 at 08:15 PM · View previous versions
Feb 11, 2010 at 05:38 PM
BrianO
p.1 #24 · Things that can go wrong
wickerprints wrote: ...I'm not talking about HSS in that paragraph. I'm talking about SCS, and explaining why it cannot be implemented when the shutter speed is faster than x-sync. In such a case, the second curtain has already begun to close before the first curtain is fully open, which means there is no way to fire the flash once without causing uneven exposure.
The same is true in 1st curtain sync. That's why HSS is needed at high shutter speeds.
wickerprints wrote: ...SCS can only occur slower than x-sync, and would result in uneven exposure when faster than x-sync. The two can't be combined in any meaningful way.
I think the opposite is true.
If HSS worked by using 1st curtain sync, which fires the flash when the 1st curtain is fully open, the second curtain would already have travelled most of the way across the frame, resulting in uneven exposure.
Instead, I think it's more accurate to say that HSS always uses 2nd curtain sync, starting the flash as soon as the 2nd curtain starts to move. As such, it is not neccesary to set 2nd curtain sync manually; thus the same button is used to set either.
Another possibility is that HSS used an entirely different trigger, starting the flash just before the shutter fires, for example. But it definitely couldn't be a true first-curtain sync for the reason I have shown.
Feb 11, 2010 at 07:31 PM
Garry Burton
p.1 #25 · Things that can go wrong
Thanks guys, I've been going nuts trying to workout why all of a sudden I haven't be able to obtain HSS all of a sudden (doh).
I'd needed 2nd curtain and simply didin't change back. That's why you can only set either HSS or 2nd curtail on the 580, I would of thought you could have both worlds with the camera mastering the lot but NO.
Cheers Gaz
Feb 11, 2010 at 07:46 PM
2 end
