2 end
Archive 2010 · Help choosing 1Ds II or 1D III
schristie11
p.1 #1 · Help choosing 1Ds II or 1D III
I need help choosing which camera body will for my needs best.
I have now a 1D II and love its speed and image quality.
I used to use a 5D and it was toooooo slow for me, shutter lag and AF lag was my main complaint, IQ was worse than my 1D II too, even though 5D had larger sensor and better high iso.
However, I want some slightly larger resolution photos for enlargements and for viewing on large LCD screens.
I'm offering customers a CD with slideshows they can view HD like photos on their large screen TV's.
I know the 1Ds II has a much larger sensor and therefore larger images than my 1D II.
I think I might be very happy with a 1Ds II but have never used one.
However, I do shoot some action photography and wonder if I will miss the 8.5FPS.
In fact I’d love to have even more 10fps like the 1D III has.
I don’t shoot a LOT of sports with the shutter held down though; I’m usually using single shots.
The response time of the 1D II is so fast I can usually tap the shutter and get the image on the first try.
It is hard for me to decide to let go of high FPS speed.
The 1D III had a 10mpixl vs. my 8.5mpixl; but the image sizes are almost the same 3700x2400.
The files it saves are larger though, 8mb vs 12mb.
How does this translate, if at all, to a larger image?
Feb 08, 2010 at 08:25 PM
Beowulfenator
p.1 #2 · Help choosing 1Ds II or 1D III
I bought a 1Ds mk II and could not be happier. I absolutely love the shallow DoF of a full-frame sensor and the AF is just great! My old 40D now spend most of its time in the closet
Feb 08, 2010 at 09:21 PM
4x4rock
p.1 #3 · Help choosing 1Ds II or 1D III
If you already have the 1D MKII then the 1dsMKII seems right. They share the same menu, same batteries, same charger, etc...
While the 1DMKIII maybe better in ISO department and frame rate, the 1Ds MKII files at 16.7MP is really nice for push/pull as well as cropping.
Feb 08, 2010 at 09:44 PM
joezasada
p.1 #4 · Help choosing 1Ds II or 1D III
The 1D3 has 14-bit colour info in the RAW files, that is gonna make for the larger file sizes.
I use a 1Ds2 as my main body, and carry a 1D2 as a second body. The AF and response time of the 1Ds2 is pretty much identical to the 1D2. The framerate is slower, but I still have the 1D2 if I need it (usually I don't).
I shoot sports and live events (e.g. weddings) with both cameras and can move between the two without much thought...
I am very happy with my 1Ds2
rick300d
p.1 #5 · Help choosing 1Ds II or 1D III
If you are planning to keep your 1D mkII, I'd suggest going with the 1Ds MkII. It is a pain traveling with 2 different types of batteries/chargers.
If you are upgrading then it would depend on what you are looking for - ultimate image quality or higher iso performance/live view capability/FPS/AF improvement - evolutionary, not revolutionary.
The 1Ds II is a great camera but the 1D III is better at higher ISO which eventually was the deciding factor for me. The larger screen and live view also became very useful when I started using manual focus lenses.
However, I did miss the 1Ds MkII full frame quality. So have just recently upgraded to the 1Dds MKIII.
Were it not for the different battery types, I would still have the 1Ds II along with the mkIII.
Feb 08, 2010 at 10:03 PM
mttran
p.1 #6 · Help choosing 1Ds II or 1D III
You will love 1ds2 even more than 1d2. 1ds2 IQ is much better then 1d2/3. 1ds2 iso is underrated - low iso noise is better - high iso noise is about the same as newer bodies w/ a tiny touch of NR. AF is the best portrait AF i have used - back lids objects won't fool its AF at all so great for most fast primes.
Feb 08, 2010 at 10:26 PM
schristie11
p.1 #7 · Help choosing 1Ds II or 1D III
I had a feeling this would be the case, it's good to hear from another source.
Thanks!
Feb 08, 2010 at 10:31 PM
mttran
p.1 #8 · Help choosing 1Ds II or 1D III
I've posted this before: Custom WB from a small table lamp on the right. All default from 1ds2 & 5d2 w/ NR disabled - DPP then resize in CS2 then post. Tested with 85L & 85LII:
5d2 -100
1ds2 -100
5d2 -800
1ds2-800
5d2-1600
1ds2 - 1600
5d2 -3200
1ds2 -3200
Feb 08, 2010 at 10:54 PM
schristie11
p.1 #9 · Help choosing 1Ds II or 1D III
I'm not sure what the 5D II comparison was about, but thanks for your effort. It showed me the 1Ds II and 5D II have a nice ability to take a photo. I kind of knew that though. The extra noise at iso 1600-3200 on the 1Ds II and 5D II clean up easily in PP. Personally, I don’t shoot at those high ISO levels ever, I would disable anything over ISO-800 when the body has the feature to limit iso expansion. That's one feature I love on the Canon 1D IV and the Nikon D700; the min and max variable ISO can be customized fully.
I think I've pretty much decided to geta 1Ds II unless I can wait longer for the 1Ds III prices to drop.
Edited on Feb 08, 2010 at 11:36 PM · View previous versions
Feb 08, 2010 at 11:30 PM
joezasada
p.1 #10 · Help choosing 1Ds II or 1D III
schristie11 wrote:
I'm not sure what the 5D II comparison was about, but thanks for your effort. It showed me the 1Ds II and 5D II have a nice ability to take a photo. I kind of knew that though. The extra noise at iso 1600-3200 on the 1Ds II and 5D II clean up easily in PP. Personally, I don’t shoot at those high ISO levels ever, I would disable anything over ISO-800 when the body has the feature to limit iso expansion. That's one feature I love on the 1D IV and the D700.
I routinely shoot at high ISO - stick to RAW and with a little bit of processing almost all of my clients are pretty much amazed at how good the images look...
Feb 08, 2010 at 11:35 PM
schristie11
p.1 #11 · Help choosing 1Ds II or 1D III
I agree and do the same when necessary but, I have the luxury of having plenty of light and am shooting from ISO 100 - 400 most times.
Feb 08, 2010 at 11:37 PM
mttran
p.1 #12 · Help choosing 1Ds II or 1D III
I don't have 1ds2 vs 1d3 data anymore - so thinking this 1ds2 & 5d2 set can be used a snapshots to show how 1ds2 iso compared with 1d3. They are pretty close. It is nice to get 1ds3 than 1ds2 for sure.
Feb 09, 2010 at 12:23 AM
EvilZardoz
p.1 #13 · Help choosing 1Ds II or 1D III
Owning both a 1D Mark III and a 1Ds Mark II and considering your situation, I'd go the 1Ds Mark II. It works identically to your 1D II and offers a far superior resolution, better IQ and so on. It's the same camera you love but with the specifications you require. You can't lose. The AF is solid, it's predictable, especially if you already have the 1D II. The antialiasing filter on the 1Ds II is also strong which can result in some soft images when viewed 1:1 - this can be fixed up with unsharp mask filters in post - but your 1D II is already like that anyway.
The 1D III works a bit differently. I do prefer the colours out of the 1D III and the extra features (bigger screen but same res.. sigh, brighter but not bigger viewfinder etc). I will say one thing about the 1D III (and the 5D II and other newer Canon cameras) - I seem to get about an extra stop of highlight retention on overexposed areas vs. my 1Ds Mark II and 5D. I also prefer the jpegs straight out of the camera on the mark III - but I rarely work with just the jpegs anyway. External speedlite control is something I'm warming to, especially when using multiple flash units off-camera.
Buy the 1Ds Mark II and see how you go as it seems to be the best for your needs.
Otherwise, you might be able to pick up a deal on a cheap 1Ds III.....
Feb 09, 2010 at 03:23 AM
SLD
p.1 #14 · Help choosing 1Ds II or 1D III
Any cameras you mentioned are good enough for produced images for the purpose of showing on so called large LCD screen only.....
And if you need the 10 FPS frame rate and high ISO performance, 1D Mark III is your choice.
Otherwise 1Ds Mark II is the best camera Canon ever manufactured so far, reliable, great IQ, better handling and responding etc., and it's cheap for an used one...
Feb 09, 2010 at 03:38 AM
Imagemaster
p.1 #15 · Help choosing 1Ds II or 1D III
Odd, my 5D produced much better IQ than my 1DMk2.
Unless they have a computer feed to their TV, or a Blue-Ray DVD player, the slideshow will not appear as HD on their TV's.
Tony
Feb 09, 2010 at 04:40 AM
Dick Snyder
p.1 #16 · Help choosing 1Ds II or 1D III
Go for the 1Ds II. Wonderful camera.
Dick
Feb 09, 2010 at 08:00 AM
schristie11
p.1 #17 · Help choosing 1Ds II or 1D III
Wow I see 1Ds II for $1800 E+ on KEH.com and 1D III for about $1800 also
I'm still on the fence.
Feb 09, 2010 at 09:48 AM
mspringfield
p.1 #18 · Help choosing 1Ds II or 1D III
I have a 1DII, a 1DsII and a 1DIII. When it comes to out and out picture quality I reach for the 1DsII every time. For colors, DOF, IQ, I reach for the 1DsII every time. The only thing that the 1DIII has is higher ISO performance, battery life and lighter weight. If I could only keep one it would be the 1DsII.
Michael
Feb 09, 2010 at 10:27 AM
PaulB
p.1 #19 · Help choosing 1Ds II or 1D III
As you are used to the ergonomics of the 1DMkII then either body would be easy to transfer to.
But the 1DMkIII only gives you a small resolution increase over the MkII whilst the 1DsMkII doubles the resolution you already have.
The 1DMkIII is still a 1.3 sensor and the 1DsMkII is FF.
If you buy the 1DMkIII then your MkII is surplus to your needs and has to go.
If you buy the 1DsMkII you keep the 1DMkII for sport and action and the 1DsMkII for "more considered" shooting.
Conclusion? Buy a 1DsMkII and keep the 1DMkII as well.
Which is exactly what I did.
Feb 09, 2010 at 10:32 AM
hardlyboring
p.1 #20 · Help choosing 1Ds II or 1D III
1ds2 is the bees knees
it is so sweet and really not that much different than the 1d3
Doug
Feb 09, 2010 at 11:01 AM
Jman13
p.1 #21 · Help choosing 1Ds II or 1D III
I had a 1D II for a short while and bought the 1Ds II right after. There might have been one occasion where I wanted the 8.5 fps back, other than that, the 1Ds II smokes it. Amazing image quality, incredible dynamic range, wonderful noise handling (though likely not as good at the pixel level as the 1D III, but I'd bet pretty close for a print). It just makes beautiful images. I think, all things considered (time of release, etc), it's Canon's finest SLR. Sure, the more modern SLRs like the 1Ds III and 5D II offer better resolution, dynamic range and noise control, but very incremental, IMO, and the 1Ds II still easily holds its own among any of the newcomers, which is amazing for a 6 year old DSLR.
Feb 09, 2010 at 11:38 AM
PetKal
p.1 #22 · Help choosing 1Ds II or 1D III
1DsII is a great camera with a small LCD.
However, if you need a fast action camera, 1DsII is not it. Neither the frame rate nor burst depth is there.
Feb 09, 2010 at 12:28 PM
PaulB
p.1 #23 · Help choosing 1Ds II or 1D III
OP already has a 1DMkII.
Feb 09, 2010 at 03:06 PM
OntheRez
p.1 #24 · Help choosing 1Ds II or 1D III
As lideson noted earlier "Otherwise 1Ds Mark II is the best camera Canon ever manufactured so far". I believe this sentiment is widely held. I doubt that this will ever be said about the 1DIII I certainly agree with it. I have been shooting a 1DII and a 1DsII until recently when the 1DII went on a "5-finger vacation." Sigh.
Anyway, the advantages of using the same batteries and gear and already knowing how to use the 1DsII have been mentioned. The 1DIII beats the 1DsII in shot buffer, ISO, and a more refined user interface. I can't image that anyone will claim that its IQ can touch that of the 1DsII. The images I get out of mine are often just amazing and allow for significant manipulation when necessary.
Finally, I regularly shoot sports with my 1DsII. I have, on occasion, gotten 6 fast shots but it does take awhile for the buffer to clear. I very rarely feel the need to just machine gun away. Admittedly most of my work is pro bono for middle school programs, but the 1DsII does an excellent job.
Bluntly, buy the 1DsII. You will not be disappointed.
Robert
Feb 09, 2010 at 03:24 PM
Jeff
p.1 #25 · Help choosing 1Ds II or 1D III
schristie11 wrote:
I need help choosing which camera body will for my needs best. I have now a 1D II and love its speed and image quality.
I used to use a 5D and it was toooooo slow for me, shutter lag and AF lag was my main complaint, IQ was worse than my 1D II too, even though 5D had larger sensor and better high iso. However, I want some slightly larger resolution photos for enlargements and for viewing on large LCD screens.
I can understand complaining about AF speed, but shutter lag and image quality? The shutter lag should be *virtually* the same as any other camera out there; I doubt most people could tell much of a difference. I've heard few people complain about the image quality of the 5D, especially compared to a 1D MkII. Perhaps your 5D had a problem?
I'm offering customers a CD with slideshows they can view HD like photos on their large screen TV's. I know the 1Ds II has a much larger sensor and therefore larger images than my 1D II. I think I might be very happy with a 1Ds II but have never used one.
I'm sure you'd be very happy with a 1Ds MkII. However, that being said, the increased resolution of the 1DsII won't be significantly better for your purposes as stated above, unless you tend to crop heavily. Most 6MP DSLRs would be fine for an HD slide show, assuming of course you had the ability to produce one (it currently isn't very simple to produce a 1920x1080 slideshow that most people can view on their HD TVs).
However, I do shoot some action photography and wonder if I will miss the 8.5FPS. In fact I’d love to have even more 10fps like the 1D III has. I don’t shoot a LOT of sports with the shutter held down though; I’m usually using single shots. The response time of the 1D II is so fast I can usually tap the shutter and get the image on the first try. It is hard for me to decide to let go of high FPS speed.
If you are mostly using "single shots", then the 10 FPS vs. 8.5 FPS shouldn't matter in the least; I can tell you from experience that the difference is minimal. In fact, a 7D would suit your purposes, as its AF is adequate, and it is higher resolution than the 1D MkII you currently have.
The files it saves are larger though, 8mb vs 12mb. How does this translate, if at all, to a larger image?
It doesn't, necessarily. The larger file of the 1D MkIII is also due to the 14-bit files (I believe), in addition to the modest increase in resolution.
I personally would not want to be without a backup camera, and your 1D MkII is a great body for the sports you shoot. Why replace it? Although the 1Ds MkII is admittedly a great camera, do you really need (or even want?) two 1-Series bodies? I find it convenient to have one smaller body for dragging around when I don't need a pro-grade camera, and it seems to me that adding a 7D to what you've got fits your needs on several levels, and probably saves you a few bucks (unless you have to sell the 1DII to finance something else).
Feb 09, 2010 at 04:21 PM
2 end
