2 end
Archive 2010 · Keeping the eyecup on
ryansphoto
p.1 #1 · Keeping the eyecup on
Anyone have a better way to keep the eyecup on? I tend to lose mine all the time and it really ticks me off. I have no clue who they keep falling off.
Feb 07, 2010 at 10:59 PM
dcains
p.1 #2 · Keeping the eyecup on
I get some heavy black thread and wrap it around the groove the eyecup slides on to. Just a few times around does the trick, although it will vary with the thickness of the thread you've got. When you slide on the eyecup, the little tangs will grab the thread fibers and it will stay in place.
Others have used black silicone glue, or gaffers tape. They all seem to work OK.
Feb 07, 2010 at 11:15 PM
Zander Alberts
p.1 #3 · Keeping the eyecup on
Gaffer tape.
Feb 07, 2010 at 11:36 PM
ryansphoto
p.1 #4 · Keeping the eyecup on
Guess what?? I post this, go on an assignment to photograph people watching the Super Bowl, and I LOST my new eyecup. lol I think I jinxed myself.
Feb 08, 2010 at 12:36 AM
jrhoffman75
p.1 #5 · Keeping the eyecup on
Use a small piece of paper to wedge one of the hooks on the eyepiece so it is less likely to deflect.
Feb 08, 2010 at 12:50 AM
retrofocus
p.1 #6 · Keeping the eyecup on
A plastic piece of the fairly cheap built eyepiece of my Rebel XT came off and this lead to a constant loosening of the eyepiece. I just used some drops of glue to permanently fix it in place.
Feb 08, 2010 at 01:54 AM
omarlyn
p.1 #7 · Keeping the eyecup on
Zander Alberts wrote:
Gaffer tape.
+1...A little strip running along the top helps alot!
Omar
Feb 08, 2010 at 02:30 AM
jkurkjia
p.1 #8 · Keeping the eyecup on
Another vote for gaffer tape!
BTW, it's funny how we all have our little "issues" related to how we insert/remove equipment from the bag. I've never lost an eyepiece but the mode dial on my xxD bodies invariably moves out of position and my first reaction to this is "OMG, my camera has gone kaput." Finally after many heart attacks from a moving mode dial I've resorted to gaffer tape and my little problem is solved.
Regards,
Joe Kurkjian
Feb 08, 2010 at 02:32 AM
jay tieger
p.1 #9 · Keeping the eyecup on
Wrapping a bit of plastic from a shopping bag around the eyepiece frame before replacing the rubber eyecup did the trick for me....
Feb 08, 2010 at 03:25 AM
Dawei Ye
p.1 #10 · Keeping the eyecup on
+1 on gaffer - I tape up my whole damn cameras, sick of the mode dials changing, caps coming loose and whatnot
Use only Permacel Professional Grade though, the cheap brands suck
Feb 08, 2010 at 04:03 AM
Matt OHarver
p.1 #11 · Keeping the eyecup on
/me knocks on wood.
I've never had an eyepiece come off, or lost one. Been shooting Canon for several years and had many new and used cameras. Heck most times I have trouble getting it off the camera when I want to wipe down the view finder.
Matt
Feb 08, 2010 at 04:42 AM
STARRIDER
p.1 #12 · Keeping the eyecup on
glue it on..you wont lose it then..why would ever need to take it off..
Feb 08, 2010 at 08:18 AM
retrofocus
p.1 #13 · Keeping the eyecup on
As I mentioned above, yes, I also glued the eyepiece on my Rebel XT camera. But there is one reason why you might reconsider doing this - I evaluated options to convert my older Rebel camera for IR shooting. It is recommended here to remove the eyepiece to open the camera body. In the end it was no issue for me since the conversion would have costed a lot more than this camera is worth meanwhile.
Feb 08, 2010 at 12:59 PM
Chris Beaumont
p.1 #14 · Keeping the eyecup on
In theory you're supposed to slide the eyepiece off and use that little rubber bit of the Canon strap whenever you're using a tripod as "stray light entering the eyepiece can affect the metering" - however having never had an issue with this and being on my 7th eyepiece for my 2 year old 40D, I can confidently say that, for me, the PiTA factor of losing it comprehensively outweighs the tiny little theoretical benefit of being able to take it off.
Feb 08, 2010 at 02:54 PM
STARRIDER
p.1 #15 · Keeping the eyecup on
Good work Chris..thats what i mean,glue the little devil and forget about it..think i'm gonna go take some photo's now..
Feb 08, 2010 at 03:05 PM
tintinb
p.1 #16 · Keeping the eyecup on
Probably pointless for the newer bodies with live-view ... but the one I use for macro shots frequently - almost never has the eyecup on. I put the angle-finder pretty frequently there.
Feb 08, 2010 at 03:25 PM
Andrew J
p.1 #17 · Keeping the eyecup on
Put a rubber band around the slot before sliding the cup on. Then snip off the extra.
Feb 08, 2010 at 10:20 PM
Ariel Bravy
p.1 #18 · Keeping the eyecup on
Gluing it on is a pretty bad idea, IMHO. Consider that over time, the eyecup pad will crack open, rendering it sharp and painful to rest your eye against. Also the hard plastic strip that lines the bottom of the eyecup may break off and you'll want to replace it. I've had this break on one eyecup and actually protrude forward towards the eyeball. Yikes...
So yeah, keeping it on is very important (I have yet to still find an adequate solution, but I like the black thread trick) and I've lost a good 4 or 5 different eyecups, both Canon and third party. Gaffers tape doesn't seem to be enough. Something more fixed but not quite as permanent as glue would be ideal.
Feb 08, 2010 at 10:38 PM
p.1 #19 · Keeping the eyecup on
Gaffer tape. You can see a piece on each side of my 1DsIII eye cup, below. If I don't tape 'em, I loose 'em.
Feb 08, 2010 at 10:45 PM
jkurkjia
p.1 #20 · Keeping the eyecup on
For starters, you might want to attach an Angle Finder C.
Regards,
Joe Kurkjian
Feb 09, 2010 at 12:50 AM
mh2000
p.1 #21 · Keeping the eyecup on
I've just gotten used to none of my Canon bodies having an eyecup...
Feb 09, 2010 at 03:33 AM
11210
p.1 #22 · Keeping the eyecup on
In addition to what has been said also often rain covers come with different eyecups.
Oh but yeah gaffer's tape is the way to go.
Feb 09, 2010 at 03:35 AM
helimat
p.1 #23 · Keeping the eyecup on
Matt OHarver wrote:
/me knocks on wood.
Matt
+1 Is this really a common issue?
Feb 09, 2010 at 03:51 AM
mh2000
p.1 #24 · Keeping the eyecup on
give it a few more years... you'll lose one too.
Feb 09, 2010 at 04:37 AM
Gochugogi
p.1 #25 · Keeping the eyecup on
I shot EOS since 1990 and have never had problems with the rubber eye frame thingie coming off. I tried to remove mine and it was so tight I thought it was going to break. However I make sure my camera fits a bit loose in the bag for easy extraction. Not so the eye frame doesn't rub the back of the bag, but so I get a sure grip on the camera and thus have less chance of dropping it on a fast draw.
Another common complaint is photog beer guts pressing the rear buttons. I've not had that problem either. I suppose a daily workout might help that problem.
Feb 09, 2010 at 04:38 AM
2 end
