2 3 end
Archive 2010 · AF on D700
jamesdaniels21
p.1 #1 · AF on D700
Been shooting D90 for a little over three years now. Just bought a D700, and used it to shoot a basketball game tonight coupled with a 70-200 sigma ver II. The only way I could get the camera to focus at a half descent speed with to use center weighted and 3D. Can anyone help me. I was counting on being able to shoot at very hight ISO and around at least 320ish, F3.2 for the games. I am not able to. Went in and changed all the focus vs release on the menu. Still not to much luck.
Is it the lens? thanks
Jan 19, 2010 at 03:35 AM
Jammy Straub
p.1 #2 · AF on D700
Don't use 3D 51pt tracking for very fast moving subjects like that, IMHO it can't keep up very well. Stick with something like 9pt dynamic area and turn off your AF tracking delay.
Bump your exposure up while you're at it. Try those settings and see how it works, if you're still not getting what you desire, then the Sigma is limiting you.
Jan 19, 2010 at 05:27 AM
fusiongt
p.1 #3 · AF on D700
3D auto tracking isn't so great for at least my D300 (which I assume the D90 is as good as... or almost as good as in focus speed). The only time I like it is shooting birds in the blue sky. It tracks well there but with anything else moving or busy (like grass) it gets lost.
You're better off just moving your camera to focus
Jan 19, 2010 at 05:47 AM
trenchmonkey
p.1 #4 · AF on D700
Probably the lens and some camera settings as previously mentioned. This was shot at f4, ISO2000, 1/250th and spot metering
f2.8 would have given you 1/500th, see the motion blur on her legs....then there's the whole WB thing. I prefer native
ISO's ie: 1600/3200. The D700 loves this stuff, so keep at it.
Jan 19, 2010 at 10:53 AM
Makten
p.1 #5 · AF on D700
How is this picture an example of bad AF? The girl with the ball is in focus, right? She's blurred because of too low shutter speed, but that has nothing with AF accuracy to do.
Seems like someone needs to read the manual.
Jan 19, 2010 at 11:14 AM
Len Shepherd
p.1 #6 · AF on D700
Adding to this shutter speeds of 1/320 or slower are unlikely to stop subject movement blur with action like this.
1/1000 of faster is better.
Jan 19, 2010 at 12:01 PM
jamesdaniels21
p.1 #7 · AF on D700
I cant use 1/1000 without totally loosing any details in the face, etc. I tried that. But I will try and try again. thanks for all the assistance.
Jan 19, 2010 at 03:57 PM
Avi B
p.1 #8 · AF on D700
Try 1/500th, ISO3200, f/2.8 as a starting point (320 is too slow to freeze most action) And 9point or something less. Also, your WB is way out of whack.
Jan 19, 2010 at 04:15 PM
jamesdaniels21
p.1 #9 · AF on D700
OK will try. Understand WB issue. Working it. I had switched from N to Vivid and didnt realize it.
Jan 19, 2010 at 04:17 PM
Avi B
p.1 #10 · AF on D700
I dont know what that has to do with your WB issue. Your WB is set too high (which is why it's too blue) probaby it's at sunshine or something when it should be either custom WB or at the very least fluoroscent...
Jan 19, 2010 at 04:20 PM
jamesdaniels21
p.1 #11 · AF on D700
Correct. Just looked at settings. WB was set Auto but I had moved it to the left in the grid a bit too much. Thanks for the tips Avi. appreciate all assistance.
Jan 19, 2010 at 04:24 PM
Doug Weasner
p.1 #12 · AF on D700
On my D90, my Sigma 70-200 HSM II AF's ok, but IQ is mush at f2.8. f4 is great to excellent. Haven't gotten around to sending it to Sigma.
Test the lens live view focused at f2.8, f4, and f5.6. If it looks ok at f4, but doesn't at f2.8, a trip to Sigma for optical adjustment is in order. If it looks ok at f2.8, then tweak AF to the best of your ability after study of the manual and info on the 'Net. If it still doesn't get it done, you can try the AF adjustment on your D700 and/or sending the lens (possibly with the body) to Sigma for calibration.
Jan 19, 2010 at 04:37 PM
jamesdaniels21
p.1 #13 · AF on D700
Went at it again tonite trying to apply the suggestions given to me on the forum yesterday. No perfect by any means, but what do you think compared to yesterdays upload? thanx so much for all your mentoring. James
  NIKON D700    70 mm    f/2.8    1/500 sec    3200 ISO    0.0 EV
  NIKON D700    200 mm    f/2.8    1/500 sec    3200 ISO    0.0 EV
Jan 20, 2010 at 05:54 AM
ishootsports3
p.1 #14 · AF on D700
1/1000 is far more than needed
i consider 1/500 to be the working shutter speed floor, and then work from there using your lens wide open and iso to get correct exposure
Jan 20, 2010 at 06:06 AM
jamesdaniels21
p.1 #15 · AF on D700
So should I go even higher then 32oo with ISO to get shutter speed increased.
Jan 20, 2010 at 06:11 AM
ishootsports3
p.1 #16 · AF on D700
like i said stick your shutter at 1/500 put the lens at 2.8 and go wherever the iso needs to go, i often use settings up to 6400 and have made sooc sales of shots around 5000ish
Jan 20, 2010 at 06:19 AM
daleroy
p.1 #17 · AF on D700
You're still under exposed by a good stop. Either change metering modes or push the EV comp by a stop or so.
Jan 20, 2010 at 10:11 AM
jamesdaniels21
p.1 #18 · AF on D700
thanks Dale. Will continue to work on it.
Jan 20, 2010 at 02:34 PM
jamesdaniels21
p.1 #19 · AF on D700
Took another "whooping" in the gym last night. Hum, a physical whooping may have been better then a camera whooping. Anyway, had fun, and was able to use a couple remote strobes for the last quarter of the game. It was fun and I enjoyed trying something new. Posting a couple more pics for your reviews and comments. Still having hard time, but making baby steps. First pic was strobed. Other two available light.
  NIKON D700    70 mm    f/16.0    1/250 sec    6400 ISO    0.0 EV
  NIKON D700    78 mm    f/3.2    1/320 sec    3200 ISO    0.0 EV
  NIKON D700    92 mm    f/2.8    1/320 sec    4000 ISO    0.0 EV
Jan 24, 2010 at 02:01 AM
jamesdaniels21
p.1 #20 · AF on D700
Can you take a look at the recent pic posts and tell me what you think? thanks.
Jan 24, 2010 at 09:58 PM
James Burden
p.1 #21 · AF on D700
Still a bit soft for me...have you tried setting auto-ISO to say max - 6400 with shutter speed at 1/500 minimum?
Jan 24, 2010 at 10:19 PM
jamesdaniels21
p.1 #22 · AF on D700
Too soft for me too. I have tried setting 6400 and 1000 shutter speed and loose all the detail in the face. I thought from all the reading I would be able to do that with the D700. The gym has really bad lighting so some of its as a result of that. Wonder if its the sigma 70-200. It is a DG lens, sooo, using it on FF camera anyone out there shooting a sigma 70-200 on their D700 (or other lens) indoor sports and getting good results, if so, please post and provide data? Preferably shoots inside very bad lit high school gym so I can compare and learn from. THanks.
Jan 25, 2010 at 01:21 AM
Filipinoise
p.1 #23 · AF on D700
Maybe it's the Sigma's IQ that's causing the slightly soft-looking photos? Or even motion blur? Because the D700's High ISO is extremely good and supposed to preserve a lot of detail even at 3200 and such. Maybe sell the Siggy and get a Nikon 80-200/2.8 AF-D? I've gotten great results on a D90 shooting HS basketball, although one of the gyms I shot at was a college gym and the lighting was superb.. USF.
If I were using a D700 when I took those shots... Oh dear.
Both with D90 + 80-200/2.8 AF-D @ ISO 1600, f/2.8, and 1/500sec.
Jan 25, 2010 at 01:38 AM
jamesdaniels21
p.1 #24 · AF on D700
thinking the same thing on the siggy. Hate it becuase its a nice lens. Love your pics and that is the exact quality I was expecting at 3200 on the D700. Thanks for the post. A couple more questions for you ref your shooting. Were you using Standard - Neutral or Vivid. What were the setting within, and, were you shooting auto D-lighting? Or, just tell me what all your settings were for comparision. I need to figure out the issue becuase it keeps costing me money. ha thanks. James
Jan 25, 2010 at 01:48 AM
jamesdaniels21
p.1 #25 · AF on D700
Was that with or without flash (remote??)
2 3 end
