Archive 2009 · CS3 Bridge and LR 2.5?
Golferdude1977
p.1 #1 · CS3 Bridge and LR 2.5?
I used Bridge CS3 to crop some pictures right after I took them. Then a couple of weeks later I decided to try LR again, LR 2.5. I imported the pictures into LR. THen when I go into LR, the rendered pictures are somewhat blurry. Plus it tells me the picture is either off line or missing. If I go into the Develop module, then the photo looks good again. Is this because I am using LR 2.5 but first used Bridge CS3? Oh, not sure it matters but LR 2.5 is the 64-bit version and CS3 Bridge is the 32-bit version. Any ideas?
Thanks,
Jimmy
Nov 25, 2009 at 12:31 PM
UCSB
p.1 #2 · CS3 Bridge and LR 2.5?
You might try rerendering your previews for the files in LR.
Nov 25, 2009 at 02:55 PM
flash
p.1 #3 · CS3 Bridge and LR 2.5?
It's because LR only has acces to a cached preview of the file. You will need to point LR to the actual location of the file to get the high quality preview. It has nothing to do with CS3, Bridge etc.
Gordon
Nov 25, 2009 at 09:25 PM
