       2       3              14       15       end
Archive 2009 · 3-D "effect" from non pro bodies?
saaketham
p.1 #1 · 3-D "effect" from non pro bodies?
Just to refute the argument that only pro bodies can produce that famed "3-D Effect", would you care to post some of your images that make the subject "pop", taken using non-pro (Rebels, xxD) bodies? I'd like to see if there's any truth to this or if it's all in the head of the people who keep saying such things. Not to diss any pro or pro body, but crop bodies need defending, IMHO. Please mention the lens used as well.
Recently, I read someone's post in another thread that 1 series bodies produce an image that has an "almost 3-d effect" and is unmatched by any crop. I asked whether that has more to do with the lens or the body and I posted a photo I took with my lowly 30D, which I think kinda shows this so-called "makes the subject pop" effect. His reply was "yeah, that's why the 30D is the top model picked by pros". While that is funny, I believe a good lens and a capable person can produce equally good photos with even a D30. That's why I'm curious to see if anyone else thinks that a pro body has a different quality that makes subjects "pop" or gives an "almost 3-D effect" or if it is just a matter of the lens, the DOF and the subject-background distance, etc?
Thanks.
Edited on Nov 25, 2009 at 03:41 PM · View previous versions
Nov 24, 2009 at 10:17 AM
saaketham
p.1 #2 · 3-D "effect" from non pro bodies?
Hope to see better ones than what I post from more skilled photographers
Canon 30D + Canon 85mm f/1.2 L
http://light.smugmug.com/People/Friends/UthkalaUrubail/IMG2996/719651199_UySuU-X2.jpg
Edited on Nov 29, 2009 at 10:00 PM · View previous versions
Nov 24, 2009 at 10:28 AM
Kolor-Pikker
p.1 #3 · 3-D "effect" from non pro bodies?
Hmm, I suppose this might qualify:
400D + 70-200 f4 is
http://i418.photobucket.com/albums/pp263/ThisIsHey/camelnose.jpg
http://fc01.deviantart.net/fs46/f/2009/151/7/3/Camel_eye_by_Kolor_Pikker.jpg
Nov 24, 2009 at 10:41 AM
saaketham
p.1 #4 · 3-D "effect" from non pro bodies?
Canon D60 + Sigma 100-300mm f/4
http://light.smugmug.com/Events/Races/2005F1Indianapolis/06192005-092308/712763226_pV5Bb-X2.jpg
Canon 30D + Canon 17-55mm f/2.8 IS
http://light.smugmug.com/Nature/Animals/IMG0174/709717520_AFmZh-XL.jpg
Nov 24, 2009 at 10:45 AM
Kolor-Pikker
p.1 #5 · 3-D "effect" from non pro bodies?
Don't we photogs just love nose shots?
Nov 24, 2009 at 10:48 AM
DavidP
p.1 #6 · 3-D "effect" from non pro bodies?
There is no such thing as a 3D effect.
If there is, somebody could actually define it.
Nov 24, 2009 at 10:50 AM
saaketham
p.1 #7 · 3-D "effect" from non pro bodies?
... I had a 500D attached to the lens and was shooting flowers when this puppy grew curious and came over to check out the lens. Your camel shot .. where was that taken @?
There is no such thing as a 3D effect. If there is, somebody could actually define it.
I agree. All it is, is subject stands out ... given the right lens, the right lighting and proper subject to background distance, any DSLR can produce this so-called "pop". But, I've read many-a-times about only pro bodies having this quality and this is confusing because I don't see how.
Nov 24, 2009 at 10:51 AM
Kolor-Pikker
p.1 #8 · 3-D "effect" from non pro bodies?
I think he means subject-background separation. obviously, it's possible to do with any-format camera, but I guess someone just felt the need to show off.
An amusement park in Moscow.
Taken on a table at a friend's house, same camera. Edit: hasn't had and PP, so yeah it looks a little meh atm.
http://i418.photobucket.com/albums/pp263/ThisIsHey/chrysanthemums3.jpg
Edited on Nov 24, 2009 at 10:59 AM · View previous versions
Nov 24, 2009 at 10:57 AM
paulfeng
p.1 #9 · 3-D "effect" from non pro bodies?
Huh... I didn't realize this claim was made about bodies; I thought it was usually about lenses.
Nov 24, 2009 at 10:58 AM
Kolor-Pikker
p.1 #10 · 3-D "effect" from non pro bodies?
Format size influences depth of field. a medium-format camera has (about) the same DOF with an 80mm lens @ f/2.8 & 1m subject distance, as a 35mm camera does with a 50mm lens @ f/1.1
Since DoF is usually a factor in subject isolation, a camera with a small sensor would be at a disadvantage.
Edited on Nov 24, 2009 at 11:06 AM · View previous versions
Nov 24, 2009 at 11:04 AM
saaketham
p.1 #11 · 3-D "effect" from non pro bodies?
That second camel photo .. if that's taken with the 70-200 f/4 IS .. that lens is so sharp then. Wow.
I thought so too, but I've seen this said many times here and on other forums, that the 1d series photos just have this "3d feel" to them, or "just seem to stand out", etc. And while I know very well that the 1D series is a totally different beast and no D60 or 30D can come close to the quality of that series, I have seen so many images from non-pro bodies that are equally "subject-popping" so to speak.
Kolor-Pikker
p.1 #12 · 3-D "effect" from non pro bodies?
I cropped the right half off of that photo, and yeah, the 70-200 holds up well against prime lenses at equivalent apertures. Edit: oh yeah, and I didn't use sharpening either.
Nov 24, 2009 at 11:10 AM
DavidP
p.1 #13 · 3-D "effect" from non pro bodies?
Since it's just a limited DOF thing, why not call it that, rather than 3D-effect?
Nov 24, 2009 at 11:23 AM
saaketham
p.1 #14 · 3-D "effect" from non pro bodies?
Once again, I agree .. this is what I've read some people call the "feel" of photos from pro bodies.
Nov 24, 2009 at 11:26 AM
Kolor-Pikker
p.1 #15 · 3-D "effect" from non pro bodies?
uhh... it sounds cooler?
Nov 24, 2009 at 11:28 AM
saaketham
p.1 #16 · 3-D "effect" from non pro bodies?
I didn't pick that term out Here's one example: https://www.fredmiranda.com/forum/topic/838182
Nov 24, 2009 at 11:36 AM
kennyluo
p.1 #17 · 3-D "effect" from non pro bodies?
all done by rebel xs/1000D
http://farm3.static.flickr.com/2473/4089013116_3791ef0722_b.jpg
http://farm3.static.flickr.com/2512/4088278743_d7ae0581d1_b.jpg
http://farm4.static.flickr.com/3539/3765232816_0f5e0934de_b.jpg
Nov 24, 2009 at 11:42 AM
saaketham
p.1 #18 · 3-D "effect" from non pro bodies?
That deer one is cool .. And so's the first one of the dinner table.
Nov 24, 2009 at 11:46 AM
gdanmitchell
p.1 #19 · 3-D "effect" from non pro bodies?
saaketham wrote:
Just to refute the argument that only pro bodies can produce that famed "3-D Effect", would you care to post some of your images that make the subject "pop", taken using non-pro (Rebels, xxD) bodies? I'd like to see if there's any truth to this or if it's all in the head of the people who keep saying such things. Not to diss any pro or pro body, but crop bodies need defending, IMHO. Please mention the lens used as well. Thanks.
Who ever made such an argument?
There would be no truth to such a claim if it were made.
Nov 24, 2009 at 12:01 PM
Nick Baker
p.1 #20 · 3-D "effect" from non pro bodies?
imo only the first photo and the camel eye really show the 3d effect. The rest are just background/subject isolation. (not saying they are bad photos in any wasy... just not good examples)
The so called 3d effect is NOT just subject background isolation. It is also a product of strong midtone contrast/microcontrast. Hang out in the alt lens forum and you will hear the zeiss junkies waxing eloquent about it. lol.
Ok, here is ultimate proof that not only is a pro body unnessary but that you also do not need an expensive lens.
Canon Xti + Canon 50mm 1.8 II (cost me 70$)
http://farm4.static.flickr.com/3454/3932623492_8587dbaf3f_b.jpg
Nov 24, 2009 at 12:10 PM
       2       3              14       15       end
       2       3              14       15       end
