2 end
Archive 2009 · Ball head battle
bp044
p.1 #1 · Ball head battle
Which of these moderately priced ball heads are of the highest quality for use with a light weight compact The usage is also occasional and not very vigorous . Reasonable smoothness and precision are needed .I know I should be looking at Markins ,Kirk or RSS but the budget is limited and I will never need the higher weight capacity.
The choices are Giotto , Cullmann ,Induro , Photo Clam or any other suggestions that meet the criteria . I need to stay under $200
Nov 23, 2009 at 12:41 AM
sjms
p.1 #2 · Ball head battle
what is it supposed to be holding. kinda difficult to determine without data. price may buy an item but will the item be sufficient to do the job?
Nov 23, 2009 at 01:15 AM
E-Vener
p.1 #3 · Ball head battle
Leica Large Tabletop Tripod head. No panning base but holds as much as the heads you mention and holds it very securely. Largest load I ever put on one was a Nikon F4s with a 300mm f/2.8. You can also put it in your pocket.
Nov 23, 2009 at 01:17 AM
sjms
p.1 #4 · Ball head battle
would this be what you're referring to?
Nov 23, 2009 at 02:03 AM
Smiert Spionam
p.1 #5 · Ball head battle
Induro is a rebadged and overpriced Benro, with internals stamped out of cheap crappy metal.
Nov 23, 2009 at 02:34 AM
bp044
p.1 #6 · Ball head battle
Ansers to last posts.
The ball head will be holding a 8 to 12 ounce compact camera
I have the Leitz ball head. It does not pan as was said and I need tension control
Thanks to your comment I have Elimanated the Induro
Nov 23, 2009 at 03:03 AM
sjms
p.1 #7 · Ball head battle
could you be a little more specific as to model of camera?
what is the importance/need for the tension control?
the reason is there are a limited amount of ball heads that have drag controls that support a 1/4-20 threaded connect at a reasonable price
Nov 23, 2009 at 03:44 AM
bp044
p.1 #8 · Ball head battle
I use a panasonic FX-500 camera weighing 7 ounces for Ebay photo shots of small and some very small objects requiring macro shots. I thought the drag control would help to accurately position the camera before locking it up for the exposure . The Giotto 1302-210C and the Cullmans have the 1/4 -20 screw to fit the camera socket. I also have several QR's and plates so the ball head I finally get doesnt need one
Nov 23, 2009 at 04:42 AM
sjms
p.1 #9 · Ball head battle
i think you are going to find that your camera may not move as nicely due to its lack of weight. the drag settings on the better ballheads are meant for the beefier products. i have done some macro work with my canon g10 and my rrs bh 40. the drag didn't really help vs a good quick lock up on the ball itself.
Nov 23, 2009 at 05:09 AM
bp044
p.1 #10 · Ball head battle
I may be under the wrong impression . I thought the drag control enabled you to help accurately frame the shot before using the locking knob and if you locked up straight away the camera would move slightly . If this not correct I would consider some other ball heads which dont have drag controls
Nov 23, 2009 at 02:58 PM
E-Vener
p.1 #11 · Ball head battle
That is indeed what I was referring to.
Nov 23, 2009 at 03:33 PM
E-Vener
p.1 #12 · Ball head battle
You have taken one apart I take it?
I'd look at the Arca-Swiss P0 as well: leight weight, very strong, panning function and tension control.
Nov 23, 2009 at 03:34 PM
sjms
p.1 #13 · Ball head battle
he did state his budget was under $200 though you are close.
Nov 23, 2009 at 03:41 PM
Smiert Spionam
p.1 #14 · Ball head battle
I took apart an Amvona/Dynatran labeled version, and compared it in hand to an Induro in the store. Same mechanisms, tooling marks, hardware, etc. OK in a pinch for fifty bucks, but the fatal flaw is the cheap metal and lack of any decent internal bearings -- the locks just bear down on, and wear grooves in, the cup the ball sits in.
They look pretty, but will not last. At the ~$200 that the Induros sell for, it's a huge ripoff.
Another option is to watch ebay for a Markins Q3. For a while, new ones from gray market sellers in Korea had them for less than $200. Looks like they've crept back up a bit, but that may change.
Nov 23, 2009 at 05:14 PM
AbramG
p.1 #15 · Ball head battle
I have had nothing but a positive experience so far with my photo-clam ballhead. I have the larger PC-44 model (44mm ball) but I plan to buy a smaller one for my travel tripod.
I know markins and RRS are fantastic (I use RRS plates) but honestly I can say the photo-clam is built exceptionally well, and I forsee it lasting me a number of years.
Worth checking out!
Nov 23, 2009 at 07:58 PM
runamuck
p.1 #16 · Ball head battle
I have Amvona/Dynatran knockoffs of the Manfrotto 3265 that just keep on going and going and going. For light weight cams and occasional use, you might as well go inexpensive. By the time you wore out a 40 dollar Dynatran you would probably be old as I am.
Nov 25, 2009 at 03:26 AM
kenyee
p.1 #17 · Ball head battle
Wow
Have you and Ellis tried every cool ballhead?
Nov 25, 2009 at 03:24 PM
Smiert Spionam
p.1 #18 · Ball head battle
While I can see how a copy of a simple, rugged Manfrotto design could be pretty tough, their copies of the much more complex stick/slip Arca-style heads are clearly inferior. I can only conclude that you're very young.
Nov 25, 2009 at 04:48 PM
E-Vener
p.1 #19 · Ball head battle
kenyee wrote:
Wow
Sigh. More than you can ever guess. Arca-Swiss (B1, B2 (I still own these), Graf, Foba, Acra-tech, Linhof, Kirk, Induro/Benro, Novaflex...but never the Really Right Stuff heads for some reason. Weird but true. But then its part of my job as an editor foir PPA's magazine. Never tried Markins either. They outright refused to let me review their heads a couple of years back when I was writing up a comprehensive survey of ball heads.
For stitched and rotational panoramic work my favorite head is a very heavy geared tilt Majestic head with an RRS PCL-1 clamp on top. I'd like to find an affordable double tilt FOBA head someday...
Nov 25, 2009 at 04:55 PM
rprouty
p.1 #20 · Ball head battle
I've had one of these since 1978...
Nov 26, 2009 at 05:41 AM
joosay
p.1 #21 · Ball head battle
I'm looking to get a ball head like this one:
http://www.bhphotovideo.com/c/product/368324-REG/Manfrotto_by_Bogen_Imaging_468MGRC0_468MGRC0_Hydrostatic_Ballhead_with.html#reviews
Should any ball head be compatible with any standard tripod? I have the Velbon El Carmagne 530..
Nov 26, 2009 at 01:40 PM
Erie Patsellis
p.1 #22 · Ball head battle
E-Vener wrote:
kenyee wrote:
Wow
Out of curiosity (and having gotten one very, very inexpensively), what did you find lacking in the Graf Studioball?
erie
Nov 26, 2009 at 02:26 PM
sjms
p.1 #23 · Ball head battle
the manfrotto head will come with a 3/8-16 threaded stud which is "standard" today. if you have any tripod that has a 1/4-20 thread stud a reducer is available for generall less the $5
Nov 26, 2009 at 02:51 PM
sjms
p.1 #24 · Ball head battle
thats abou the time i got my first one that i lost . do have another around the house that has an alloy knob which is older.
Nov 26, 2009 at 02:53 PM
bp044
p.1 #25 · Ball head battle
I have thr older one. The operation of the serrated ball does'nt seem smooth . Does it require lubrication ?
Nov 26, 2009 at 03:54 PM
2 end
