Photon Online Dedicated FM Upload & Sell: On
p.1 #4 · Question: Are these pics sharp on 100-400 lens 5d MKII? | |
Yes, the shot looks soft. Assuming that this was hand held, was IS on? Did you allow a moment for the image to stabilize in the viewfinder (which would indicate that IS had done its work)? It's a little hard to be sure from your sample, but the focus appears to be in the right place, so I'd suspect a bit of camera motion. If some of your shots are sharp, it is probably not a case of a lens defect.
Edit: My response was to the first shot only. The dog looks ok for 1/50 sec., which is a stretch for the older IS system of the 100-400. Still, the best way to test the optical performance of the lens would be on a tripod with a stationary, detailed subject. Next best would be in light that permits high shutter speeds (say 1/1000 sec, even with IS on). The suggestion of trying Microfocus Adjustment is good, if it turns out that your AF is not nailing things.
