Mark Booth Offline Upload & Sell: Off
How about using a traditional fog machine (party supply store) with a vacuum cleaner hose attached to it. Have an assistant shoot some fog into horn and then back away quickly. If you don't use ice in the fog machine the fog will have a tendency to float up rather than hug the ground. If it hangs in the horn too much, the assistant could blow gently into the mouthpiece. And if you use ice in the machine, maybe the fog would sit inside the horn and a gentle blow by the assistant might cause it to flow up and over the rim of the horn in a cool fashion.
I've never done this type of thing... just throwing an idea out there.
FWIW, I picked up a pretty nice fog machine on closeout at Party City the day before Halloween for $25.
Mark
