Cableaddict Offline Dedicated FM Upload & Sell: On
The chestvest looks pretty good, but I would not use one because the pouches sit too high. (for me.) Two reasons why this is so:
1: It makes it harder to get the lenses out quickly, as opposed to using a waistbelt & pouches.
2: I often hike with my belt-pouches and a full pack. This is not possible with the chestvest. I also use the exact same molle vest as sjms (although I use modified Lowepro pouches on it) for extra capacity, and this also would be problematic with the chestvest.
I like the Thinktank belts over the Lowepro, as the Lowepro's buckle is garbage. It loves to pop open. I also use the Thinktank large holster, but for smaller lenses I prefer the protection of the Lowepro pouches. Both companies belts & pouches can be used with each other. You'd also probably want to get one of the optional thinktank harnesses. (shoulder straps)
Having said all this, if you are ONLY going to use your pouches, without a vest or pack, and you don't need super-fast access, the chestvest looks really good. carrying the pouches slightly higher, as it does, would be slightly safer & probably more comfortable as well.
Edited on Nov 20, 2009 at 07:18 PM · View previous versions
