thrice Offline Upload & Sell: Off
Red/Cyan corners or left edge: as long as the lens is coded or selected in the menu it is purely firmware, in the meantime cornerfix takes care of it. The off-centre colour shift with non-wides is negligible, it's probably comparable to an SLR... really quite ridiculous. It isn't cuased by microlenses as Edward postulates, it's caused by the IR filter and overcorrection for cyan drift, Leica just need to correct their profiles which were probably made hastily.
Slow processing: firmware - it's dual processor vs single processor in M8, eventually most actions should be greatly improved in speed.
fuzzy image on LCD: firmware
lockups and other little bugs: firmware
Very few cameras are flawless out of the blocks, even my 5D-II had posterisation and "black dot" issue when first released. Once the firmware fix is available then we'll be laughing.
Lloyd doesn't know much about DRF's and this is apparent in his review. With the biogon design he should be coding it as a less wide lens due to the symmetrical design. I've seen M9 + C-biogon images on flickr with nowhere near the issue he has.
