hjanssen Offline Upload & Sell: Off
p.1 #8 · Resolution in Capture NX2 | |
DougLee wrote:
However, if I export from LR and set dimensions in pixels, I agree with you. DPI has no effect on file size. But, if I export in LR and set dimension in inches, DPI does have an effect on file size. I have no idea why this is, but it is. I am sure it is some setting in LR, but I haven't bothered to pursue it.
Of course when you export in physical dimension with a dpi value the output is effected by the size.
example:
10x15 @ 300dpi -> 3000x4500 pix
20x30 @ 300dpi -> 6000x9000 pix
But when you change the dpi in PS size window, you see change the photo size, but the "pixel" size stays the same(2000x3000).
So when you want to print real big, you can upsize your file with this tool and PS(LR, NX or whatever editor) resamples your file to a bigger file.
