cwebster Offline Upload & Sell: Off
catherine780 wrote:
are 50 products reasonable for a day's work?
That depends on what and how you're shooting. If they are tee shirts you are laying on a background and they don't have to be particularly neat, and you have an assistant to set up and tear down, yeah maybe you could shoot 50 pieces in a day.
But if they are high-fashion dresses that each need to be shot on a form, with twiddly details that have to be right, or wrinkles that have to be steamed out, you might not be able to do 10 per day.
This is where experience comes into play. And like so many other places, the first few always take much longer than the following because you're practicing.
Shooting a large quantity of anything also requires some logistics to ensure that every piece is shot and to match the catalog numbers to the frame numbers etc.
As I've said here before, I use a little different method of charging. I charge the customer by the day or half-day, but I specify how many pieces/views/setups I will deliver, so it's the equivalent of piece rate. I can do that because I know how many setups I can shoot in 1/2 day or a whole day.
Piece rate is fairest to the customer, because you aren't charging for your lack of expertise. Hourly rate is fairest to the photographer because you get paid, no matter how long it takes you. But the customer has to pay for your learning curve.
I suggest you go find some pieces similar to what you will be shooting for the client and practice in advance. That way you will have some clue about how many pieces you can do in a day, and you'll get your lighting etc. in order before you start on the customer's dime.
<Chas>
