Archive 2009 · CPL and EF-S 17-55 IS
jecoe
p.1 #1 · CPL and EF-S 17-55 IS
Can anyone tell me whether I need a slim profile CPL for this lens to avoid vignetting at 17mm? I found past threads addressing this issue with the 16-35, but not with this lens.
I am looking at the B+W MRC slim, but if I could get standard profile filter, I could save a few bucks, and still use a standard lens cap. That might be easier to live with.
Nov 18, 2009 at 10:44 AM
pinball_pw
p.1 #2 · CPL and EF-S 17-55 IS
I have not had an issue with mine and I don't use a slim one. Much easier with the lens cap this way. - Paul
Nov 18, 2009 at 01:17 PM
catfriend
p.1 #3 · CPL and EF-S 17-55 IS
+1
Nov 18, 2009 at 01:19 PM
kop.cppua
p.1 #4 · CPL and EF-S 17-55 IS
+1
+1
I use a Hoya standard CPL filter. Don't think this is an issue with a crop factor camera.
CP
Nov 18, 2009 at 02:18 PM
Will Patterson
p.1 #5 · CPL and EF-S 17-55 IS
I got a small amount vignetting on my 5D when I used a CP on my 17-40, it was a regular Hoya CP. On a crop body camera it'll be a non-issue though.
Nov 18, 2009 at 02:21 PM
Ariel Bravy
p.1 #6 · CPL and EF-S 17-55 IS
You don't. You might on a 16-17mm FF equivalent which would be about 10mm on 1.6x. 17mm on 1.6x is cropped away enough to where a normal filter will be a-okay.
Nov 18, 2009 at 02:23 PM
hrs749
p.1 #7 · CPL and EF-S 17-55 IS
I use a B+W normal CP on my 17-55 without any problem. Vignetting should not be an issue.
Nov 18, 2009 at 02:35 PM
jecoe
p.1 #8 · CPL and EF-S 17-55 IS
Thank you all for your help!
Nov 18, 2009 at 03:39 PM
skywalker11
p.1 #9 · CPL and EF-S 17-55 IS
But I have Vignetting issue at 17 to 20mm.
My CPL is B+W 77mm Kaesemann MRC SLIM CPL C-PL Filter. Could you let me know if the problem is len or it is just normal.
Mar 30, 2010 at 10:43 PM
hashbaz
p.1 #10 · CPL and EF-S 17-55 IS
I have a little vignetting on the wide end of my 17-55. This vignetting doesn't change whether the B+W 77 KSM C-POL MRC (non-slim) is on or off the lens.
Mar 30, 2010 at 10:57 PM
skywalker11
p.1 #11 · CPL and EF-S 17-55 IS
Thanks a lot. it is just normal for this focal range right?
http://img534.imageshack.us/img534/7918/img162511.jpg
Mar 30, 2010 at 11:01 PM
