Archive 2009 · Wideangle Ghost Question
lamonica66
p.1 #1 · Wideangle Ghost Question
Hi All-
Just bought a 14mm 2.8 to pair with my D3. I get a recurring ghost in the lower left corner of many shots.
Is this normal?
I am aware that wides tend to ghost, but always in the same spot?
Does this lens need repair?
Thanks!
Matt
Nov 17, 2009 at 09:25 AM
Two23
p.1 #2 · Wideangle Ghost Question
Now that is weird. Is the lens clean--no smudge (front OR rear)? You are using the lens hood always, right?
Kent in SD
Nov 17, 2009 at 09:39 AM
lamonica66
p.1 #3 · Wideangle Ghost Question
yes and yes
Nov 17, 2009 at 09:42 AM
Chris Dees
p.1 #4 · Wideangle Ghost Question
If it is dirt it would be on the right side corner of the portrait image.
Did you try other wide angles as well?
Nov 17, 2009 at 10:52 AM
gugs
p.1 #5 · Wideangle Ghost Question
something is strange and inconsistent: the ghost is always in the lower left corner, in portrait and landscape mode !!!
That means NOT at the same place depending on camera orientation !!!
I am puzzled to say the least.
Guy
Nov 17, 2009 at 10:58 AM
donaldy
p.1 #6 · Wideangle Ghost Question
that is weird as hell...
Nov 17, 2009 at 11:28 AM
wingcommander
p.1 #7 · Wideangle Ghost Question
Does this happen with all lenses? What if you turn the camera upside down?
Nov 17, 2009 at 01:08 PM
Andre Labonte
p.1 #8 · Wideangle Ghost Question
Guy
+1
Nov 17, 2009 at 01:09 PM
Tommy_D
p.1 #9 · Wideangle Ghost Question
Do you wear a shiny watch on your left wrist? It could be a reflection off the watch on to the lens.
Nov 17, 2009 at 08:39 PM
wingcommander
p.1 #10 · Wideangle Ghost Question
Most plausible suggestion yet. Would be confirmed if (1) only wideangle and (2) disappears without watch.
A very remote possibility- from INSIDE the camera, or a light leak into the camera. (Had that happen to me once, a long time ago).
Nov 17, 2009 at 10:17 PM
Two23
p.1 #11 · Wideangle Ghost Question
Put camera in a black bag, surround the lens too. Take some shots. That should tell you if you have a light leak.
Kent in SD
Nov 18, 2009 at 12:04 AM
NikonAndy
p.1 #12 · Wideangle Ghost Question
she doesn't look too happy about that ghosting in #3.
Nov 18, 2009 at 12:45 AM
nikt
p.1 #13 · Wideangle Ghost Question
Could be the flash. I've sent it before.
Could be a really slight misalignment within the lens also. If the case, it will be noticeable with slight variations of sharpness in each corner.
Nov 18, 2009 at 06:31 AM
lamonica66
p.1 #14 · Wideangle Ghost Question
Only happens w/ that lens.
Thanks Everyone!
You are all awesome.
Nov 18, 2009 at 07:24 AM
HerbChong
p.1 #15 · Wideangle Ghost Question
it's a different shape in each image. it looks like odd flare.
Herb...
Nov 18, 2009 at 11:43 AM
AGeoJO
p.1 #16 · Wideangle Ghost Question
I had this lens before; I thought it could be a smallish alternative albeit on the wide end only of the 14-24G. Boy, was I wrong; it was definitely prone to flare although I don't remember mine was that bad like your pictures show. Yours showed some flaring even on that brick wall shot . The 14mm setting of the 14-24mm puts this prime lens to shame. The notion about prime lenses being better than zoom can be thrown out of the door as far as two lenses concerned. I sold the prime lens shortly after finding that out. I would send the lens in to Nikon for evaluation and eventually adjustment/calibration.
Nov 18, 2009 at 11:53 AM
