What are the criteria?
Archive 2009 · Desert Twilight Moon
jemark
p.1 #1 · Desert Twilight Moon
Help!
I've spent hours and maybe days trying to make this image what I want. Perhaps the issue is that the time of day, and my technique in capturing the the image leave something to be desired.
What I'm looking for is advice on how to make it pop more.
Issues I've noticed include noise in the sky and blocked up shadows in the bush when I try levels adjusting.
I've tried "highlight/shadow" but it was too much too.
Shot with a Canon 1Ds Mark II, tripod, I use CS4 for editing.
I've tried noise reducing to smoothen the sky, but it still remains blochy. Client really wants a 20x30 and I'm about to say that's not possible.
I've recently tried put grain on as a layer to 'unify' the image and hide the blochy-ness of the sky. This is the most challenging sky I have ever had since the color gradient is so very very gradual.
Suggestions?
I have Lightroom too, but I've not been happy with it either. Probably operator error.
This is I think my first time posting to this forum so let me know if I need to add something. I did also post an edited version which I like, but I'm not estatic about it.
Help??
Mark
Nov 13, 2009 at 05:32 AM
Bobster2
p.1 #2 · Desert Twilight Moon
This is a simple trick: create an levels adjustment layer, set the blend mode to multiply and play with the adjustments a little bit.
Nov 13, 2009 at 06:04 AM
jemark
p.1 #3 · Desert Twilight Moon
Thanks for your note and helpful advice. I had forgotten about the 'multiply' mode. Still the sky appears blochy going from blue to red. Perhaps there is nothing to be done about that. Shoot film someone will say, and scan hi-res
Nov 13, 2009 at 06:31 AM
tchan748
p.1 #4 · Desert Twilight Moon
I dont have your orginal file so i cant really see what you can push but have you try increasing the color saturation to bring out the colors ? It looks much more vibrant.
Nov 13, 2009 at 07:49 PM
sbeme
p.1 #5 · Desert Twilight Moon
I'm thinking seeing the original or the full-sized jpeg is probably the best way to go. Maybe you can post a link or email copies. I see more noise, then "blotches", perhaps from the added "grain" and heightened by the multiply effect.
Scott
Nov 13, 2009 at 09:21 PM
jemark
p.1 #6 · Desert Twilight Moon
Thanks for the comments above and from others.
I think it turns out to be a matter of expectation. Anything I do saturation or otherwise is going to bring out the blochiness during the color shift from pink to blue. Plus the printer I used could not handle the contrast.
I've reworked it to a more subtle shift of colors and dodged the blocking up of the blacks in the brushy foreground.
When the prints get back I'll know if it worked.
Thanks again.
Mark
Nov 14, 2009 at 02:35 AM
Bob Jarman
p.1 #7 · Desert Twilight Moon
Mark,
Hope you don't mind - played a bit with it in LightZone - moon is crappy -didn't take the time to mask properly but anyway - NR in sky then blur to mask the mottling, readjusted some luminosity, etc...
Doubt it'll (my re-work) hold together for an 8x10, let alone 20x30
Bob
Nov 14, 2009 at 03:12 AM
patrickphoto
p.1 #8 · Desert Twilight Moon
try capture. It handles gradient rendition better than adobe raw convertors.
Nov 14, 2009 at 03:17 AM
prh5551
p.1 #9 · Desert Twilight Moon
sure it's not NSFW
prh
Nov 14, 2009 at 03:24 AM
AuntiPode
p.1 #10 · Desert Twilight Moon
Try:
1) Add a duplicate layer.
2) Working with the duplicate layer select the Filter>Blur>Gaussian Blur and select something around say 2.3 pixels for example. That should blur the image enough to lose the noise.
3) Now to return sharpness to the needed parts, set the erasing tool to 100% and pick a suitable brush. Erase the duplicate layer over the sand and brush. Choose a suitable brush size and erase the layer over the moon.
4) Flatten the image.
5) Create a new duplicate layer and set the blending mode to Soft Light. Use the Opacity slider to pick a version that pleases, perhaps about 30%. (A higher blending mode will probably leave more banding. A lower blending percentage less banding. I suspect if you can work in 16 bit mode, banding may not be a problems and you may be able to use a stronger Soft Light blend.)
I've taken the liberty to illustrate the result. If that's somewhat like what you had in mind, experiment to find what you prefer.
Nov 14, 2009 at 09:16 AM
simdoc1
p.1 #11 · Desert Twilight Moon
It may not be what you want to do or what your client wants, but my inclination would be to clone out the small wisps of grass in the left foreground. They seem to distract from what is otherwise a great image.
Nov 14, 2009 at 02:40 PM
jemark
p.1 #12 · Desert Twilight Moon
Wow, thanks to everyone for the great thoughtful replies. The cloning of grass etc will of course be done. I did try the layers and masking, also the gausian blur, but I may not have tried it in the right order or to the right level. SO I'll try it again. I think it was or is a interesting challenge because a, of it's subtleness and b, it's not changing the "reality" of the shot but trying to capture it in a faithful way.
If I go away from it for a day and try again, I'll have a fresh perspective.
Thanks again to all.
Mark S.
PS I'm also considering what to print it on, as that may mask the "problem", like canvas or other textured papers. But I can not print a 20x30 at home (for now) I've found a lot of canvas printers but are there many online, who will print on papers other than the matte or luster, at that size?
Guess that is a new topic.
Nov 14, 2009 at 03:51 PM
sbeme
p.1 #13 · Desert Twilight Moon
Mark,
For the printing issue, why not post on the Printing and Post-Processing Forum.
I have had (limited) experience with Canvas On Demand with good results with their gallery wrap. I doubt any noise would be an issue on canvas.
Scott
Nov 14, 2009 at 04:17 PM
Kaden K.
p.1 #14 · Desert Twilight Moon
... and yet so pubic!
Nov 14, 2009 at 06:09 PM
jemark
p.1 #15 · Desert Twilight Moon
I wish you hadn't said that, because now it's obvious even to me. I guess that's what happens being in the public.
Nov 14, 2009 at 06:19 PM
Kaden K.
p.1 #16 · Desert Twilight Moon
What?!?
Nov 14, 2009 at 06:35 PM
AuntiPode
p.1 #17 · Desert Twilight Moon
Be aware, in addition to order, the pixel size of the blur matters and can be fussy. Too small and the blur doesn't completely smooth the noise. Too large and it can leave an obvious edge between the blurred portion and the not blurred part.
Nov 14, 2009 at 08:52 PM
newhaven
p.1 #18 · Desert Twilight Moon
You can also try the luminosity painting technique to bring out the contours in the dunes. Create a new layer filled with 50% gray in overlay mode. Paint with black to darken and white to lighten.
Nov 21, 2009 at 07:18 PM
