2 3 4 end
Archive 2009 · Zeiss ZE 21 mm Review on Photozone
jhg photo
p.1 #1 · Zeiss ZE 21 mm Review on Photozone
Zeiss Distagon ZE 21 mm Reviewed on 5D II on Photozone:
http://www.photozone.de/canon_eos_ff/470-zeiss_zf_21_28_5d
Doesn't look so much better than 16-35 L II at 20 mm f11, does it?
Nov 12, 2009 at 12:57 PM
slungu
p.1 #2 · Zeiss ZE 21 mm Review on Photozone
Well, it does have about the same weight, same filter size and same number of lenses as the 16-35L II. Other than that, performance wide open is better on the edges and in the corner - one thing that actually started the run for the Zeiss 21mm Distagon if I remember it right from some years ago. But, I really don't care that much about this type of review, I rather like to see how a lens does in real life. Then again, I see great images made with crap equipment that are better than technical perfect-sharp-to-the-corners nothing telling images and start asking myself why I hang out around here anyway . This is the point I start to look again into the picture threads here on the alt forum - because poeple here are not only knowledgeable about equipment, they are also very good photographers
Regards, Stefan
Nov 12, 2009 at 01:18 PM
tsdevine
p.1 #3 · Zeiss ZE 21 mm Review on Photozone
I have both the 16-35 II and the Zeiss (ZE)....I see noticeable differences at all apertures. I might be able to post some comparison shots later...
-Tim
Nov 12, 2009 at 01:47 PM
gasrocks
p.1 #4 · Zeiss ZE 21 mm Review on Photozone
I think it will be interesting when Photozone posts their test of the new EF 24 T/S lens. That will be something to compare to as well.
Nov 12, 2009 at 03:48 PM
edwardkaraa
p.1 #5 · Zeiss ZE 21 mm Review on Photozone
How much better did you expect it to look like?
I can see the Zeiss is visibly better especially at wider apertures, the zoom catching up but not quite from 5.6 upwards. I have to say this is quite an achievement for the Canon zoom. The test does not show how the lenses perform in micro-contrast and color rendition.
It would be illuminating to see Lloyd Chambers real life photo comparison between these 2 lenses and his conclusions
Nov 12, 2009 at 05:02 PM
photomadnz
p.1 #6 · Zeiss ZE 21 mm Review on Photozone
LLoyd has been a lover of the CZ21mm ever since the original and then the ZF came out. He raves on and on about it. Funnily enough if you are a subscriber, he pits it against the likes of the 14-24 zoom and in alot of the tests the zoom wins! I think there is alot of good lenses in this range now and it doesnt stand up like it used to. I have been testing this against the 24mm T/S and the Canon wins on all counts. I think the hype got a little out of control.
Nov 12, 2009 at 07:20 PM
edwardkaraa
p.1 #7 · Zeiss ZE 21 mm Review on Photozone
I am a subscriber too, and while it is not fair to disclose the results here, what you claim that the zoom wins in a lot of the tests is not accurate.
I have no reason to doubt your claim that the Canon 24 T/S is better (regardless of the different focal length) but myself and several members here have expressed our interest in seeing some comparisons. Hopefully you can show us some.
Nov 12, 2009 at 07:32 PM
tsdevine
p.1 #8 · Zeiss ZE 21 mm Review on Photozone
I've seen quite a few people say the new 24mm TSE II is amazing. You gain the perspective control with it, but it's significantly more money. The 14-24 looks incredible too, but if you want the same integration as the Zeiss, you need a special adapter. It's also more $$.
It's funny to now see the Zeiss as a "bargain."
Nov 12, 2009 at 07:35 PM
Yakim Peled
p.1 #9 · Zeiss ZE 21 mm Review on Photozone
If I was after a non-Canon UWA on my Canon I'd rather take the Nikon 14-24/2.8. Other than size and weight I can't see any reason to take the Zeiss. Then again, I'd much rather take the 17/4 TS instead.
Happy shooting
Yakim.
Nov 12, 2009 at 07:55 PM
photomadnz
p.1 #10 · Zeiss ZE 21 mm Review on Photozone
Fair enough about to disclosing to many results. I think you should re-read the test result pages against each other and then re-read the conclusion. Pretty clear to me.
Nov 12, 2009 at 08:24 PM
photomadnz
p.1 #11 · Zeiss ZE 21 mm Review on Photozone
I am about to head away for a couple of days but if someone can give me a quick and dirty way of showing 100% crops etc then I will post some tests when I return. Thanks
Nov 12, 2009 at 08:25 PM
freaklikeme
p.1 #12 · Zeiss ZE 21 mm Review on Photozone
That's not actually a test of the ZE. It may sound nit-picky, but testing an adapted ZF isn't the same. The optics may not have changed, but adding auto-aperture into the mix is a fairly significant change. And there's the Nik to EOS adapter- the quality of that could certainly affect a lab test.
Nov 12, 2009 at 08:40 PM
cogitech
p.1 #13 · Zeiss ZE 21 mm Review on Photozone
I think it is worth it to note that they tested the ZF, not the ZE.
Quote: "Unfortunately we weren't able to get our hands on the ZE version so we had to use the ZF variant via adapter. However, there aren't any differences apart from the mount specific aspects so our conclusions will be fully valid for ZE lenses as well."
As we all know too well, adapting lenses can certainly result in less than ideal performance. I'm not saying this is the case here, just that it might be.
(freak beat me to it, as I had this all typed up and then got called away from my desk)
Nov 12, 2009 at 08:51 PM
wiseguy010
p.1 #14 · Zeiss ZE 21 mm Review on Photozone
I am a subscriber too and what you are saying here is not true at all. I think you should re-read the test result pages yourself.
You repeatedly made some statements about the supposed superior Canon 24 over the Zeiss 21/2.8, but up to now you didn't post any picture that confirms this statement. Besides that, how can we know that your focussing was done properly in this "test"? As you may know it is not difficult to make an unsharp-picture with a MF-lens. Are you sure you are able to manual focus accurate?
I don't understand why Photozone tests a ZF-lens with an adapter on a Canon. Why not test it on the D3x they have? Now it is possible that the use of the adapter results in a less reliable test.
Edited on Nov 12, 2009 at 10:30 PM · View previous versions
Nov 12, 2009 at 09:29 PM
Graham Mitchell
p.1 #15 · Zeiss ZE 21 mm Review on Photozone
Canon quality control variability was always an issue with the original 16-35, iirc. Is it the same with the mark II? In cases of high variation from a given manufacturer, it is always hard to judge anything from just one sample of the lens - especially if it was hand picked by Canon for the review.
Nov 12, 2009 at 09:44 PM
snowboarder
p.1 #16 · Zeiss ZE 21 mm Review on Photozone
Yakim Peled wrote:
Other than size and weight I can't see any reason to take the Zeiss...
This is probably the funniest thing I've seen in a while
Yeah, there is no reason to get the Zeiss 2.8/21 ZE, none.
Nov 12, 2009 at 09:49 PM
trumpet_guy
p.1 #17 · Zeiss ZE 21 mm Review on Photozone
Graham,
I think the quality control problem exists with the 16-35 mkII as well as with the older version.
The mkII also had, apparently, different design goals and improved the wide open performance
considerably but took a hit to the stopped down resolution in trade off. Castleman's tests showed this,
and my experience with the two lenses agreed with this.
I kept the mkI version and it is doing the job on my 5D, but I'm sure I'd enjoy having more resolution
from my lens if I stepped up to a 5D2 or 1Ds3.
I confess to being reluctant to fork over the kind of money Canon is asking for the 24 TS-E mkII
given that Canon QA is still sub-par in my estimation.
Tim
Nov 12, 2009 at 09:54 PM
Yakim Peled
p.1 #18 · Zeiss ZE 21 mm Review on Photozone
Yep. When you quote only part of what I said no wonder it sounds silly. It's size and weight advantages when compared to the 14-24/2.8. Now, the obvious optical reasons to prefer the Zeiss over the Nikon would be......
Happy shooting
Yakim.
Nov 12, 2009 at 10:14 PM
philber
p.1 #19 · Zeiss ZE 21 mm Review on Photozone
How about posting some pics of this very interesting test, please?
Nov 12, 2009 at 10:31 PM
wiseguy010
p.1 #20 · Zeiss ZE 21 mm Review on Photozone
My guess is that we will never see these pictures.
Nov 12, 2009 at 10:40 PM
wiseguy010
p.1 #21 · Zeiss ZE 21 mm Review on Photozone
..... colour, contrast, lack of any CA, excellent flare-control, the ability to use filters .......
Nov 12, 2009 at 10:44 PM
Doo-bop
p.1 #22 · Zeiss ZE 21 mm Review on Photozone
photomadnz wrote:
LLoyd has been a lover of the CZ21mm ever since the original and then the ZF came out. He raves on and on about it. Funnily enough if you are a subscriber, he pits it against the likes of the 14-24 zoom and in alot of the tests the zoom wins! .
I read somewhere that he uses the 1DIII for his zeiss reviews, maybe that is why?
Nov 12, 2009 at 11:22 PM
Seaboarder
p.1 #23 · Zeiss ZE 21 mm Review on Photozone
Received my ZE copy on Monday and used it for the first
time today on a job (a building contractors machines).
I have never seen anything better coming out of my 5Dmk2.
The interesting thing is the images don't look all that superior
on screen but printed the quality is very clear.
Great addition to my kit.
Nov 13, 2009 at 12:08 AM
SKumar25
p.1 #24 · Zeiss ZE 21 mm Review on Photozone
There is not much of a difference between the distagon and the Canon 24 TSE II sharpness wise.
Here is a comparison between the 2 that someone did:
http://www.fredmiranda.com/forum/topic/832031/0#7734761
I think the FOV difference and manual focussing make it very hard to compare the two. Both are plenty sharp.
This is a unprocessed wide open shot with the 24 TSE II on a 5D II:
EXIF:
Camera Model Canon EOS 5D Mark II
Shooting Date/Time 9/30/2009 4:11:03 PM
Shooting Mode Aperture-Priority AE
Tv( Shutter Speed ) 1/640
Av( Aperture Value ) 3.5
Metering Mode Evaluative Metering
Exposure Compensation 0
ISO Speed 100
Auto ISO Speed OFF
Lens TS-E24mm f/3.5L II
Focal Length 24.0mm
Image Size 5616x3744
Image Quality RAW
Flash Off
Full Picture:
Center Crop:
Left Side Crop:
Left Top Extreme Corner Crop:
Nov 13, 2009 at 02:09 AM
NCAndy
p.1 #25 · Zeiss ZE 21 mm Review on Photozone
I did a few comparison shots of my ZE21 and the 16-35mk2 today. Neither lens is sharp in the extreme corners at f2.8 but the Zeiss is better with much less CA (really next to none on the ZE). At f5.6 the ZE21 is sharp in all but the very tip of each corner while the Canon is a bit better than wide open but not close to the Zeiss. By f11 the two are pretty close. The Zeiss is sharp right into the extreme corner tip and the Canon is almost as good. Any difference is only apparent at 100% on my monitor. The Canon still shows substantial CA stopped down.
My test wasn't perfect of course but I used a 5D2 at infinity focus with mirror lockup and cable release at ISO 400 to keep the ss up due to the wind. My 16-35 is due to go back to Canon for a cleaning after going through the Grand Canyon on a raft with me and I'll ask to have it calibrated then too. I doubt it will improve much but it never hurts to try.
I can post corner crops if anyone is interested.
Nov 13, 2009 at 03:21 AM
2 3 4 end
