2 end
Archive 2009 · 28mm 1.8 sharpness
fmikio
p.1 #1 · 28mm 1.8 sharpness
I MA my 28mm 1.8 and want your opinion guys:
This was shot at ISO 100, 1/250 (430EX II), 1.8
And the 100% crop:
Thanks !
Nov 08, 2009 at 02:33 AM
Will Patterson
p.1 #2 · 28mm 1.8 sharpness
Mine's sharper than that. I just used it this morning at a botanical conservatory, shot a lot at 1.8 and 2.0 and they came out fantastic.
Nov 08, 2009 at 02:43 AM
Dudewithoutape
p.1 #3 · 28mm 1.8 sharpness
MA = micro adjust?
Also did you focus on the bottle? Because at this range and at that aperture, I believe the DOF is very shallow, so even if you focused on the Snitch, it may off just because he isn't flat like the bottle.
Nov 08, 2009 at 02:48 AM
Dawei Ye
p.1 #4 · 28mm 1.8 sharpness
Looks OOF, I would try again with Manual Focus in Live View. Your MA may not be correct
Nov 08, 2009 at 02:51 AM
fmikio
p.1 #5 · 28mm 1.8 sharpness
Dudewithoutape wrote:
MA = micro adjust?
Yep. MA=Micro adjust.
I focused on the bottle but not using the center point. I used the nearest focus point.
Nov 08, 2009 at 02:52 AM
Dawei Ye
p.1 #6 · 28mm 1.8 sharpness
You can't use autofocus to test for sharpness as it introduces an uncontrolled variable into the mix
Nov 08, 2009 at 02:59 AM
fmikio
p.1 #7 · 28mm 1.8 sharpness
But, how could I check if the adjust I did is ok if I don't use an autofocus ?
Nov 08, 2009 at 03:09 AM
Will Patterson
p.1 #8 · 28mm 1.8 sharpness
Yea you said the same thing with my tests. WE GET IT, you don't like to use AF.
Fact is, when you use your lens, it's being used in AF mode, not MF. So why not test what it does in AF mode?
Nov 08, 2009 at 03:10 AM
fmikio
p.1 #9 · 28mm 1.8 sharpness
Alright... so I redid my tests and see what I've got.
Using the left focus point:
100% crop using the left focus point:
Using the center focus point:
100% crop using the center focus point:
Nov 08, 2009 at 03:16 AM
Tad Killian
p.1 #10 · 28mm 1.8 sharpness
I bought my 28 in here used about a year ago. I compared it to my 85 1.8, and it failed wide open, no contest. Contrast and sharpness was not usable for me. I sent it into Canon for checking, spent around $125, got it back and it's still unusable to me at 1.8. The lens did seem better at 2.0 and up after I got it back. I chalked it up as basically, it's a 2.0 lens now. No problem. If they made it any better, it would probably take away rom their 24 and 35 L sales.
The bokeh is actually pretty nice. Build and focus feel fine to me. Not ready to ditch a mid-range zoom for it though.
Nov 08, 2009 at 03:28 AM
Dudewithoutape
p.1 #11 · 28mm 1.8 sharpness
Is this FF or crop? Perhaps your copy just isn't sharp in that area? It could also be something wrong with that AF point. One way to test if its the lens of the camera AF is to make sure its on the same plane (like the first pic) AF center point on it (half shutter press) and then (I forget the technical point) but move/shift the camera to the right, so that its in the same area as the first shot. I feel stupid, I cannot think of the term right now, OMG.
Edit - Pan? Frame? ugh.
Edit 2 - I realize I have no idea what MA actually does, I mean I have an idea from the term, but my Rebel doesn't have that so, I'm trying to help with very limited knowledge, sorry.
Nov 08, 2009 at 03:59 AM
fmikio
p.1 #12 · 28mm 1.8 sharpness
Don't worry about all those technical terms...
I thought that if I shoot and recompose, it would be worst because I would move more than choosing the nearest focus where I want to focus and using 1.8, that would affect my focus point (I think... )
I think it's something about the limits of this lens. I've heard that it's not (that) sharp at 1.8 and I wanted to know if my copy falls into the acceptable range. I guess not
I tried several adjustments with micro-adjust and -5 was the one that I had the best results... maybe I'll try it again.
Thanks !
Nov 08, 2009 at 04:10 AM
Gochugogi
p.1 #13 · 28mm 1.8 sharpness
Which camera is this? Most of the XXD models have "high precision" AF at F2.8 or larger with the center point and normal precision with outer points. The Rebels only have single axis AF sensors on outer points. So basically the center point should be much better than outer points.
Nov 08, 2009 at 04:11 AM
fmikio
p.1 #14 · 28mm 1.8 sharpness
It's a 50D. The test I redid using the center focus is much better than using the outer focus.
Nov 08, 2009 at 04:15 AM
Dawei Ye
p.1 #15 · 28mm 1.8 sharpness
Ok but your thread title clearly says "28 f/1.8 Sharpness" not "AF performance" I'm just saying they are two separate issues and if you wanted to confirm whether your lens was sharp or not - use MF first. THEN do your stuff with MA and whatever. It's important to get the temporal sequencing correct and not fudge about with 2 uncontrolled variables in the same test
Who knows whether the softness is caused by the lens being soft, or being out of focus, or both. At least once you have confirmed sharpness with MF, you can be sure that any softness in AF results is due to AF inaccuracy, rather than lens optical issues
This has nothing to do about how the lens is used in practice. It's about identifying the causal reason why performance is not up to scratch. To do this, you have to eliminate conflicting variables. Otherwise, how can you possibly know whether it is because the lens is not optically up to scratch, or whether an AF intolerance is the reason for the softness?
But...But...you say, "I use my lenses as AF lenses." This is besides the point. Being a wedding photographer like yourself, if you take your lens to canon because you think it's not working well - do you expect Canon to send its technicians to a random Wedding on the weekend to do some test shots using AF in order to check the optical specifications of your lens? hey...is that not how the lens is being used?
The reason MF must be used when testing for lens sharpness is the exact reason why a Tripod is used (to eliminate another factor as a cause (in the tripod's case - motion blur). If you want to test for AF accuracy, then fine, but the topic of the thread is "28mm 1.8 sharpness"
Nov 08, 2009 at 04:17 AM
jrscls
p.1 #16 · 28mm 1.8 sharpness
The center AF shot looks pretty decent to me.
Nov 08, 2009 at 05:07 AM
Will Patterson
p.1 #17 · 28mm 1.8 sharpness
what use is a sharp lens if it isn't focusing accurately?
Nov 08, 2009 at 12:23 PM
kakomu
p.1 #18 · 28mm 1.8 sharpness
Will Patterson wrote:what use is a sharp lens if it isn't focusing accurately?
The point is that you'll want to figure out what the problem is in order to take an appropriate action. If the lens isn't sharp at all, then you can just return the lens from where you bought the lens.
But, if the lens is sharp, but doesn't auto focus correctly, then you can micro adjust the lens to your camera or send it to Canon for adjustment.
Each problem requires a different solution.
Nov 08, 2009 at 02:04 PM
garyvot
p.1 #19 · 28mm 1.8 sharpness
I treat mine as an f/2.0 lens too. At this aperture it is very sharp in the center of the frame, with good contrast and flare resistance. It does soften up outside of the center much more than the 'L' primes. Still, a good lens for candids and reportage.
Here's an example I've posted before shot at f/2.0, full res on a 5D2:
Nov 08, 2009 at 03:30 PM
Will Patterson
p.1 #20 · 28mm 1.8 sharpness
I have no problem using mine wide open -
  Canon EOS-1D Mark II N    28 mm    f/1.8    1/1250 sec    100 ISO    0.0 EV
Nov 08, 2009 at 04:01 PM
Will Patterson
p.1 #21 · 28mm 1.8 sharpness
also 1.8
  Canon EOS-1D Mark II N    28 mm    f/1.8    1/1250 sec    400 ISO    -0.7 EV
Nov 08, 2009 at 04:05 PM
Dudewithoutape
p.1 #22 · 28mm 1.8 sharpness
Ah, yes, recompose, DUH. I feel the center focus shot is very sharp, but the thing is you have to recompose to find out if the lens is sharper further away from the center or if its an AF point problem. Some lenses just need to be stopped down in order to get sharpness through out the frame, center sharpness is easy to obtain in most lenses (even the 18-55 IS is known to be sharp wide open at the center). Thats why you have to recompose. Lets see a shot that way, yeah?
Nov 08, 2009 at 04:15 PM
Will Patterson
p.1 #23 · 28mm 1.8 sharpness
Nov 08, 2009 at 04:23 PM
fmikio
p.1 #24 · 28mm 1.8 sharpness
I'll try some "in the field" tests with MA set to 0. Having an idea of your nice pictures at 1.8, it will be easier to know if mine is at least acceptable.
Thanks !
Nov 08, 2009 at 05:16 PM
fmikio
p.1 #25 · 28mm 1.8 sharpness
So I couldn't go out so decided to run some more tests in my christmas decor.
Again, all those straight out of the body with MA set to 0 and the focus in the Post Office.
@1.8
@2.0
@2.2
@2.5
@2.8
Nov 08, 2009 at 11:09 PM
2 end
